91 TR Diff & Hub Bearings / Seal # ?? | FerrariChat
Discussion in 'Boxers/TR/M' started by todd6363, Jan 31, 2015.
  1. todd6363
    todd6363 Formula Junior
    Jan 20, 2007
    270
    Ohio
    Todd
    Hello All - I'm looking for the SKF rear hub bearings #s , I found 62207-2RS2- C3HVQ505F7 & F2 off a bearing post, but local SKF supplier could not locate that # anywhere. Also have SKF 17750 as the hub seal- is that correct? For the Diff I have Timkin 28580/28521 & 368A/362A for bearings (correct?) but I'm still looking for that seal #, any help would be greatly appreciated. And a THANK YOU to all that have posted the priceless information I've found here.
  2. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    Numbers from my original removed parts (1988.5 TR):
    - Outer hub bearing: SKF "62209-2RS2/LHT30BVQ059" (Ferrari 144807)
    - Inner hub bearing: SKF "62207-2RS2/LHT30BVQ059" (Ferrari 145805)
    - Outer seal: "Forsheda V-65" (65mm) (Ferrari 110579)
    - Inner seal: "Rubber - Dike 60 X 45 X 10 / 13" (Ferrari 115968)
    You'll also need PN 102289 ring nut and a 44mm ring nut tool to remove
    I tried to source thru an independent and they came up with nothing also so I ended up ordering from FerrParts. I did find 62209-2RS1 and 62207-2RS1 on the internet but it is recommended to use the 2RS2 bearings as they incorporate a better (Viton) seal. Let me know if you need any help with the hub, I'm working on my second one currently.
    Sorry, haven't been into my diff...yet
  3. todd6363
    Jan 20, 2007
    270
    Ohio
    Todd
    Thanks Tim, on my list to make ring nut tool this week. Full # of seal off TR cross thread,
    SKF 17750 - CR 45x60x8 CRW1 R
