91 TR Paint Detailing | FerrariChat
Discussion in 'Boxers/TR/M' started by tommie, Sep 6, 2014.
  1. tommie
    tommie Rookie
    Feb 28, 2013
    42
    well took it to a good auto detail shop yesterday to have him detail the outside and remove the swirls in the paint (appears to be from prior owner wiping it when dry?)
    it looks better but most of the swirls are still there !
    by the way its a nero/ black car.
    he said he was coming up with black on the polishing pad and appears the car has no clear coat . well i don't think they put clear coat on them in 1991 ?
    comments and suggestions welcome
  2. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,575
    Avvocato
    Of all the black cars I've owned, 3 of them, they all showed swirls much more than other colours. Even after a polish, after a few washes the swirls would come back. I wouldn't sweat it , unless these were deep swirls.
  3. mjh366
    mjh366 Karting
    Jul 26, 2007
    172
    Kerrville Texas
    Mike hoskins
    I have done this for a living, I now have 9 cars most of them came to me in horrible condition paint wise. Find a pro !! I now use a rotary with wool pad for the bad stuff, followed with a yellow or orange pad on a Porto Cable random orbital then go to a black pad using Sonax Perfect finish then seal it with Permanon Platinum. Most of these products are new technology, I never use wax. Check out Todd Copperrider on Google. i.e. Detailimmage.com. Good Luck
  4. msdesignltd
    msdesignltd Two Time F1 World Champ
    20,292
    NYC. / E. Hampton
    Michael
    If you do it yourself the swirls come out
    I have done 3 cars this year
    All swirls come out, griot has polishes that work
    You need patience
    And finish with a hand polish
    https://m.youtube.com/watch?v=5lgH8bxgpRs
  5. MS250
    Dec 10, 2003
    26,575
    Avvocato
    How long does it last before you see swirls come back ?
  6. TKO
    TKO Formula Junior
    Oct 22, 2004
    790
    SoCal
    Tom Kearns
    All depends. Swirl marks can be caused my many things. Touching a not perfectly clean paint with a car-cover or by washing/rubbing the paint with 'dirty' or 'contaminated' tap water. And then frequency of these things would also come into play.
  7. msdesignltd
    20,292
    NYC. / E. Hampton
    Michael
    #7 msdesignltd, Sep 7, 2014
    Start here
    https://m.youtube.com/watch?v=Z78pih89kPs
    actually he is so right, your cloths are more importantant than polishes..
    Modern clear coat finishes are not as effected as our vintage naked paints.
  8. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    The TR has a clear coat - if your pad comes up black, it is likely the clear coat is gone. I would not recommend polish or wet sanding at this point.
    My personal experience shows that the paint is pretty darn thin on the TR - not a lot of room for polishing/ wet sanding.
    Time for some discussion with a high end paint shop.
    Could it be a respray with a different paint system?
    Rgds,
    Vincenzo
  9. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    I don't think this is correct (at least not the 1st generation Testarossa). Paint was single stage. If you have a clearcoat it has been re-sprayed.
  10. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    You may be right.... I have yet to find a definitive reference.
    Way back when, I did some research and concluded that the Glasurit Line 55 was used on my 1990 - but was never 100% sure.
    If you have a definitive reference - please let us know.
    Thanks,
    Vincenzo
  11. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Cars were single stage with exception of metallic colors.
    R
  12. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,263
    Mel
    At least all 512TR's have a clear coat imo ...
  13. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
    That sounds like the process my new detail person does. We just went over this the other day. He was able to clean up the TR nicely. His specialty is black cars. I've seen a few , no swirl marks.
