930 Turbo Carrera | Page 334 | FerrariChat
930 Turbo Carrera
Discussion in 'Porsche' started by joe sackey, Nov 7, 2011.
  1. Casino Square
    Casino Square Formula 3
    1,728
    Hong Kong / USA
    Andrew
    ....agreed..."what a car'... ! Love the paint and graphics on your car.
    cnpapa24 likes this.
  2. cnpapa24
    cnpapa24 F1 Rookie
    Jan 19, 2014
    3,657
    NOLA
    Chris
  3. 959
    959 Rookie
    38
  4. idart
    idart Formula 3
    2,326
  5. cnpapa24
    cnpapa24 F1 Rookie
    Jan 19, 2014
    3,657
    NOLA
    Chris
  6. idart
    idart Formula 3
    2,326
  7. E_Man
    E_Man Formula Junior
    Jan 21, 2008
    735
    Eric
    I own a '77 3.0L survivor, Ice green metallic with black leather and tartan inserts. approx. 70k miles, well sorted and all numbers matching. I just put $14k into refreshing motor, trans and suspension. Hagerty would most likely say this car is a 3. Can someone give me a value range, I'm thinking of letting it go.
  8. cnpapa24
    cnpapa24 F1 Rookie
    Jan 19, 2014
    3,657
    NOLA
    Chris
    Tough to say. Some photos would help. Nice spec!
  9. simon930Berlin
    simon930Berlin Karting
    Apr 25, 2013
    157
    Gents,
    I am trying to find camshafts for my 77 3.0, and it seems very difficult. If anyone knows of a good source, please let me know here? Part numbers are:
    930.105.142.0R
    930.105.143.0R
    Cheers from Euroland!
  10. cnpapa24
    cnpapa24 F1 Rookie
    Jan 19, 2014
    3,657
    NOLA
    Chris
    pnorell likes this.
  11. rdwinelover
    rdwinelover Formula Junior
    Feb 27, 2015
    489
    San Francisco
    Jamie
  12. cnpapa24
    cnpapa24 F1 Rookie
    Jan 19, 2014
    3,657
    NOLA
    Chris
    Looks great!
  13. kburke996
    kburke996 Rookie
    Mar 11, 2011
    2
    James Burke
    229 silver car was UK delivered through PCGB but C23 coded ie Aussie compliant.
  14. RodSav911
    RodSav911 Rookie
    Apr 1, 2016
    44
    Question:
    I got a 75 930 (#150). Is there any special treatment you can apply to the magnesium case after blasting?
    I heard Gibbs is probably the way to go
  15. 356racing
    356racing Formula Junior
    Sep 24, 2004
    541
    Paradise Valley, AZ
    Did you already blast it? With what media? Gibbs is great on magnesium but it's not going got be much use once the engine is built(temporary solution). You can send the case out for dichromate after the machine work is completed.
  16. pquadrat
    pquadrat Karting
    Jan 6, 2015
    73
    The engine block and trasmission are aluminium, not magnesium on all Turbos. But You should never use blasting on engine parts, it always affects the surface.
  17. tonypeoni
    tonypeoni Karting
    Aug 14, 2006
    249
    rdwinelover likes this.
  18. WPOZZZ
    WPOZZZ F1 Veteran
    Aug 22, 2012
    6,507
    Honolulu, HI
    Congrats, Jamie!
    Shlobeck and rdwinelover like this.
  19. idart
    idart Formula 3
    2,326
    Boomhauer likes this.
  20. cnpapa24
    cnpapa24 F1 Rookie
    Jan 19, 2014
    3,657
    NOLA
    Chris
    Nice piece, congrats!
  21. qereti
    qereti Rookie
    Jan 14, 2007
    41
    Metro Detroit
    Question for the MY75 930 experts. First, the early 930's came with aluminum front cross members just like any 911 of the period. Im working on a 75 930 that has such an aluminum crossmember. However, the Pet clearly shows the aluminum crossmember and earlier tubular steel cross member in the diagram though it states no part number for the steel version. When I was removing the front fuel pump. I could see that the aluminum front cross member had a 1985 casting date on it so obviously the crossmember was changed at some point, which made me suspect that the car started life with the steel crossmember. if my assumptions are correct, the early 75 930's started out with steel crossmembers and at some point switched to the aluminum versions. When did the switch take place? If i am correct, I have an aluminum crossmember for sale.
