94 Doablo Turn Indicators | FerrariChat
Discussion in 'LamborghiniChat.com' started by indytech, Jan 15, 2012.
  1. indytech
    indytech Guest
    May 24, 2006
    143
    Winchester Ca.
    Ken
    Well, got everything working well on my 94 Diablo VT, ecept the damn turn indicators. Every time I drive it I have to fiddle around with the Head lamp switch, and other switches, to get the turn indicators to work. They simply do nothing unless the head lamps are on. Getting ready to take to an electrical specialists, was wondering if there is a simple fix. Additionally the power windows don't work either, as they seem to be on the same circuit. Help Indy
  2. Champboat/Champcar
    Champboat/Champcar Formula Junior
    Jan 29, 2007
    885
    Freeport NY
    Eric T
    There are some small screws that hold the plastic pieces that cover the steering column ,pull it apart , see whats going on in there , alot of times people wire a K40 or a alarm system in there , you can tell whats added on , sounds like something is crossed or loose , you can also check under the passenger side foot rest to see if there is something tapped in there or added on + check the fuses there too ., also there is a big round connection near the front bumper on the bottom that could be loose that works the lights . also this sounds silly but it could be one bad bulb shorting out .
