'95 348-ECU codes never flash | FerrariChat
Discussion in '348/355' started by Texas Bumblebee, Jul 12, 2023.
  1. Texas Bumblebee
    Texas Bumblebee Karting
    59
    Texas US
    Roger
    Guys:
    US model 1995 348. Trying to pull ECU codes but CELs never flash after ECU buttons pushed. After each ECU button pushed that CEL remains constantly lighted and never flashes.
    Very recent engine-out service by excellent Ferrari specialist. First drive after service both CELs came on and remain on. I’m trying to do the ECU diagnostics but, after pushing the ECU buttons, the CELs never flash.
    Thanks for your suggestions.
    Roger
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Pushing and holding for for 5 seconds to start the process? Did your excellent Ferrari specialist test drive the car, seems odd he did not see it?
  3. Texas Bumblebee
    59
    Texas US
    Roger
    Please disregard my message. Some earlier owner or mechanic had disconnected the test buttons from the ECUs. I originally pushed the test buttons through the vent holes in the cover so as to avoid removing the cover. After I sent this earlier message I removed the cover to determine if the connections needed Deoxit and found the button wiring disconnected. Reconnected and was able to successfully read the codes. Thank you.
    Qavion likes this.
  4. Texas Bumblebee
    59
    Texas US
    Roger
    Thanks for your reply. Car drove fine returning from the drive home from the specialist but when I drove it for the first time after, about a week later, CELs came on and remained on. I just read the codes (I found an earlier owner or mechanic had disconnected the test buttons from the ECU) and 4121 and 1111 are on both sides. Thanks again. Roger
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    4121 - cats too hot
    1111 - MAF
    But the car typically wouldn't idle well or respond to throttle if the MAFs were out.
  6. m.stojanovic
    m.stojanovic F1 Rookie
    3,219
    Serbia - Niš
    Miroljub Stojanovic
    #6 m.stojanovic, Jul 12, 2023
    According to the manual:
    4121 - Exhaust temperature ECU (bad or disconnected Thermocouple ECU)
    4122 - Exhaust temperature too high
    These two codes do not trigger the CEL-s so look at the cause of 1111 (the MAF-s).
