95 355 1-4CEL has me stumped | Page 2 | FerrariChat
Discussion in '348/355' started by JPNF355, Jun 10, 2012.
  1. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    If the CEL is due to the valve the code should be 1123.
  2. Qavion
    Qavion F1 World Champ
    14,601
    Ian Riddell
    Yep... my mistake... just rechecked my diagrams.
    Good point. So we need a new theory. What is the bypass system doing to the main cats which would trigger the 1211 codes?
  3. Qavion
    14,601
    Ian Riddell
    Assuming it was generating a 1123 (bypass solenoid valve) code, you're saying you couldn't use a diode or something more sophisticated to fool the LH ECU into thinking everything was behaving normally? Maybe you could even piggyback an additional vacuum solenoid on top of the OEM one? (if you didn't have the issue of the Capristo using vacuum to close the valve)
  4. kencalz
    kencalz Rookie
    May 30, 2020
    4
    Ken
    on my 2.7 Installed a new Capristo Bypass Valve (the OEM one did not hold vacuum and looked like it stayed close) and 200 Cell Cats. After about 10 minutes of driving I get CEL on both 1-4 & 5-8 and they seem to go off and right back on. Never had a CEL with the previous setup = test pipes and OEM valve so I did buy some replacement thermoprobes but looking at this thread it seems like it is the Capristo Bypass Valve. I don't hear an audible change from low to high rpm so it may not be closing and throwing a CEL code?
  5. Qavion
    14,601
    Ian Riddell
    Did you change the solenoid valve, too, to a Capristo solenoid valve? The Capristo works in the opposite sense to the old exhaust: Vacuum = valve closed, not valve open (OEM), so needs a different type of solenoid valve.
    Or you had a vacuum issue in the first place. Low vacuum? Leaking pipes. If you suspect a vacuum issue, check all your pipes and one way valves:
    Here's an example of someone with a vacuum issue:
    https://www.ferrarichat.com/forum/posts/149138257/
    blox79 likes this.
  6. johnk...
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    Codes?
  7. kencalz
    kencalz Rookie
    May 30, 2020
    4
    Ken
    Original valve would not hold vacuum when tested directly (attached pic/basically it loses pressure quickly from 15 to 0 psi in about 15 seconds so I add assumed valve was failing and didn't look for other causes). Capristo solenoid valve installed and double checked. One of the hoses into the T-fitting looked loose/not a tight seal so I did put some glue for a more air tight seal. Still no difference maybe I should clamp it with a stainless fitting. I just ordered 2x of the one way check valves (the black/white one close to the engine) so hope that will help
    Qavion likes this.
  8. blox79
    blox79 Karting
    Jan 19, 2014
    57
    Germany
    Check the connections to the metall pipe (part# 145155) on both sides closely. There is no need to use glue or stanless steel fittings. The nippels of this metal pipe can break... mine did that ( a workshop messed this up on an engine out a couple years ago) and visually i could'nt see the micro crack. Found the crack, or better could hear it, when i tested the pipe separatly
    Cheers blox
    Qavion likes this.
  9. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    489
    London
    Steve C
  10. redwedge
    Sep 30, 2012
    489
    London
    Steve C
    Also, you could try to run a length of vac hose from the solenoid directly to the valve to see if the connections to the metal pipe, or the pipe itself, are leaking.
    blox79 likes this.
  11. kencalz
    kencalz Rookie
    May 30, 2020
    4
    Ken
    Thank you for your suggestions and will try them out. Capristo also send me a new solenoid.
