95 355 Battery, help.... | FerrariChat
Discussion in 'Technical Q&A' started by Rjones355, Aug 20, 2004.
  1. Rjones355
    Rjones355 Karting
    Jul 6, 2004
    62
    Rancho Murieta, CA
    Ryan Jones
    Im sorry because the owners manual probably has this answer, but I dont have one. What kind of battery does my 95 355 take? Can I just get one at any auto parts store?
    Im pretty sure I need one, my car wont hold a charge for over a week. The last time I jump started it, I got about 15 miles and just as I pulled into the driveway the battery light and some other lights came on and when I tried to restart the car it was dead. Hopefully the alternator is not bad. Im sure its dead if it wont hold a charge for more than a week.
  2. f355spider
    f355spider F1 World Champ
    18,045
    You should be able to find out the size designation from your local Ferrari dealer. Try giving them a call. Then go to Costco or Sears... ;)
    Two things you should consider also:
    1) There is an extra ground strap from the alternator to chassis for the 95 355, make sure you get one of those from your dealer (unless your car has already been updated. They started making this standard sometime during the 96 model year. This could be contributing to your charging issues.
    2) Get a battery tender, to keep your battery topped up with a full charge. Your battery will last much longer. This is the cheapest on-line source I have found: http://snipurl.com/7cod Then get a cigarette adapter plug from Radio Shack, and splice it onto one of the adapters and it will be very easy to connect/disconnect when you park in your garage (and you'll never forget to disconnect before driving off). http://snipurl.com/5rl7
    No manual? You absolutely should get one. You can download one for free if you register here: http://www.owners.ferrari.com/ But having the original one handy in the car is best. Your dealer can order you one.
  3. redhead
    redhead F1 Rookie
    Dec 26, 2001
    4,869
    ~Red~
    its a group 91. Which share group sizes with 48.
    Delco 48/91
    Interstate MTP-91
  4. redhead
    redhead F1 Rookie
    Dec 26, 2001
    4,869
    ~Red~
    p.s.- another idea that we do for the battery charger, we hard wire the charger lead onto the battery iteslf. Then we run the wiring up to the front compartment. Then you can keep your charger in the front and just pop the bonnet, connect the leads and plug into the wall.
  5. redhead
    redhead F1 Rookie
    Dec 26, 2001
    4,869
    ~Red~
    Ryan--
    Read this post from Vincents Alt. dying. It tells you about the wire harrness I was talking about on the phone and Dave is above. HTH
    http://ferrarichat.com/forum/showpost.php?p=134323698&postcount=80
    Rich
  6. RF128706
    RF128706 Formula Junior
    Apr 8, 2004
    280
    I got a replacement battery for my 355 from Costco here in the UK. The 355 was listed in the application guide in the store. I got a Bosch Silver Battery cheaper than anywhere else I could find.
