95 355 Bypass valve control circuit | FerrariChat
Discussion in '348/355' started by yelcab, Feb 15, 2016.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,647
    San Carlos, CA
    Mitchell Le
    My 95 355 bypass valve does not open. I have isolated it to electrical signal, but now I am stuck.
    It stands to reason that a signal from one of the two ECUs (2.7 Bosch) has to send a signal to the control valve that opens the vacuum to the bypass valve. On the 5.2 ECU, there is such a signal at pin 63.
    On the 2.7 ECUs, I have looked on the official Ferrari schematics and found no such signal from either bank 1 or bank 2 ECU.
    Does anyone know which pin from which ECU controls the bypass valve relay switch?
  2. yelcab
    Nov 29, 2001
    13,647
    San Carlos, CA
    Mitchell Le
    Found it.
    Pin 21, bank 2 is the signal controlling the bypass valve.
    Pin 21, bank 1 is the signal controlling the secondary air pump.
    Both circuits are powered by a K relay. My relay is dead.
  3. F355Bob
    F355Bob Formula 3
    Where is the relay located?
  4. yelcab
    Nov 29, 2001
    13,647
    San Carlos, CA
    Mitchell Le
    In the footwell, a K relay, with dual circuits one feeding the bypass valve and the other feeding the secondary air pump
  5. F355Bob
    F355Bob Formula 3
    Thanks yelcab for the update.
