95 355 SLOW DOWN 1-4 Light | FerrariChat
Discussion in 'Technical Q&A' started by DistinctRides, Aug 30, 2007.
  1. DistinctRides
    DistinctRides Karting
    Aug 22, 2007
    63
    Long Island, NY
    Joe Distinct
    For the first time the last light on the dash right side came on. It reads SLOW DOWN 1-4. According to the manual it has to do with the cats. It's weird b/c it seemed to happen about 20 minutes after filling up at BP with 93 octane. It seems it only flashes at or over 3000 RPM (which is almost all of the time). It flashed several times then went away. Then a while later came on and stayed on for a few minutes. Now it's gone. Any thoughts for me??
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Purchase a cheap laser thermometer (~~ $20 @ Harbor Freight) to see if the right side cat is over 700 degrees.
    An extremely overheated cat (in danger of catching the car on fire) can glow a dim red in the dark.
  3. Ricambi America
    Sponsor Owner
  4. Telerding
    Telerding Formula Junior
    Sep 30, 2004
    362
    Santa Maria/CA
    Tom Elerding
    I had the same problem on my '95 F355. It was intermittant, and caused by corrosion in a connector.
    Eventually the light would come on and stay on. Cat ECUs were replaced under the 8 year emissions warranty on my car, along with a lot of other emissions related items like the cats themselves.
  5. DistinctRides
    Aug 22, 2007
    63
    Long Island, NY
    Joe Distinct
    It's pretty scary b/c in the owners manual it says to pull over and have the car towed. The car didn't feel any different and It all happended when driving on a highway at 72-77 MPH cruising. Under normal operations. Kind of freaked me out. Can I test the ECUs seperately to see if it's just one or should I just do both??
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    It's just two bolts to swap each exhaust ECU. If the SLOW DOWN light switches sides, that usually means a faulty exhaust ecu.
    ...but, don't do that test if a cat is glowing red. A glowing cat is a real problem...a bad exhaust ecu is not.
  7. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    I got a slow down light yesterday too, but it was my own doing (fairly sure). Messing with my exhaust valve it seemed like it wasn't opening, so I wired it open to see what it should sound like. Since I was expecting to be tinkering a bit I didn't put the heat shield back on so I could get to it. So last night it came on when driving slow in stop and go traffic; once I got some speed it went off. Put the shield back on, didn't come back on today. I'm thinking the inlet air temp tripped it...
    Today was fine, with outside temps around 87F. And I just can't bear to take that wire off the valve, it sounds too good!
  8. tamf328
    tamf328 Formula Junior
    Mar 9, 2005
    477
    I had that slow down light thing going off in my 348.
    It would flash, stay on, go off, shut down a bank of cylinders, etc.
    made no sense when it did it. just random, intermitant crap.
    turned out to be the exhaust ecu.
    found it be swaping sides.
    new one from ricambi fixed the problem.
    Oh, the old one had a black epoxy on it, the new ones have
    green. the one that failed was black. it had separated from the
    plastic. the first time it failed was after the car was in heavy rain.
  9. DistinctRides
    Aug 22, 2007
    63
    Long Island, NY
    Joe Distinct
    Thanks for all the feedback. I spoke with Alevio at Algar Ferrari N.America who advised me to swap the ECUs. It looks like all of you guys have been dead on with the ECU. In the process of switching the ECUs now, I'll post when completed.
  10. DistinctRides
    Aug 22, 2007
    63
    Long Island, NY
    Joe Distinct
    I swapped the 2 ECUs and ran the car for about 35 minutes... No light. I guess the computer may need time to re-set. None-the-less, no lights came on which mean it's not the cats. Good news!!
  11. DistinctRides
    Aug 22, 2007
    63
    Long Island, NY
    Joe Distinct
    So after driving it for about an hour straight 2 times the light only came on once. It flashed 3 times then went away. I am thinking that maybe it is within the ECU connection 1-4 Bank.
  12. Ricambi America
    Sponsor Owner
  13. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    Be careful with that.... If wired open the cats never get full flow of exhaust gas during closed loop operation and same for the O2 sensors. Result is that the engine will run rich. Very rich. Potentially this can cause damage to the cylinder liners via washdown.
  14. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    I'd suggest treating it as a real problem with overtemp, since that cat ecu is there to help prevent you from being burned alive in your car.
    Did you spend $20 for a laser thermometer? Shoot the laser at the right side cat. If it's cold, then you can play around with ecu connections, new exhaust ecus, etc.
    But if the cat is getting raw fuel dumped into it to heat it up wildly, then you are treading at the very edge of where driving turns from safety into a nightmare.
  15. UConn Husky
    Nov 11, 2006
    4,425
    CT
    Jay
    Thanks David, never saw that reasoning before in my searches. Good enough for me, no sound is worth any risk of engine damage.
