'95 Air in the radiator issue | FerrariChat
Discussion in '348/355' started by ClydeM, Sep 6, 2020.
  1. ClydeM
    ClydeM F1 World Champ
    11,975
    Wayne, NJ
    Clyde E. McMurdy
    I changed the coolant & flushed it early Spring.
    I thought these are auto-bleeding systems. I did have an issue a number of years ago where I thought it was the Rad temp sensor but it turned out to be air in the system. I forget how I got it out.
    The other day after months of running fine, while at a light, I'm watching the temp climb way too high. I dont hear the radiator kicking on.
    I make it home just fine. Coolant level is fine. Here it is about a week later & I just threw her up in the air, pulled the fender lining. Ran her to normal temps & still no fan. jumped 12V to the fan - it came on. I jumpered the upper temp sensor. Fan kicked on. Dang, upper sensor. I've read these fail often. I cautiously open it to swap it with the old one I had. Almost no water came out and no hissing from air escaping. Fine. I put the old one in, add coolant to the tank (in case) and fire the car up. 3 min later when it's back to normal temp, the fan kicks on. So I'll toss the newer sensor into water & see if she tests ok.
    But it does make me think the system isn't self bleeding right. where's there a thread on a better way to bleed the system. Of course, from another thread I found the coolant reservoir hose was almost closed and I replaced it when it cracked. Perhaps the other hose is swollen shut. But I would have thought air would get through to purge.
    Anyway, if someone can point me in the right direction of a better air bleed?
    thanks.
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    I can only tell you what I do
    Just start the car with the reservoir off idle for 5 min until water gets very warm to touch.
    Shut off and repeat 2 to 3 times
    Do not forget to turn heater on to circulate through there as well.
  3. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    make sure the car is level or even better yet, make sure the rear is higher than the front
  4. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    761
    Vermont
    john truskowski
    One step that I take on any car, is to take note of how much coolant or oil etc I removed and be sure to replace the same amount.
  5. The Outcast
    The Outcast Formula 3
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    My Ferrari dealer told me about this one:
    Use Redline "Water Wetter". Worked for me. I've done 3 coolant changes and never had a problem.
  6. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Water reduces surface tension which helps eliminate microscopic bubbles stuck to the surface of the cooling theoretically causing the car to run a bit cooler and more efficiently but it doesn't remove trapped air bubbles which is what this sounds like. Be sure to run the heater on high the heater pump is up front in the boot. Bubbles flow uphill so back end up helps a bit.
    After driving before cooling down the sysyem is pressurized so crack the bleed valves on the firewall behknd the passenger to bleed air. Usually takes a few drives doing that. Wear thick gloves it's hot.
    Sent using FerrariChat.com mobile app
  7. sevminasyan
    sevminasyan Formula 3
    Jun 24, 2008
    1,156
    Glendale, CA
    Steve
    You may have started a small leak from one of the clamps and where there is a leak air will be vacuumed in causing low pressure not allowing your thermostat to open at the right temp
    check the clamps and the hoses
  8. ClydeM
    11,975
    Wayne, NJ
    Clyde E. McMurdy
    Thank you. Rechecking the system is on-tap for this weekend.
  9. ClydeM
    11,975
    Wayne, NJ
    Clyde E. McMurdy
  10. ClydeM
    11,975
    Wayne, NJ
    Clyde E. McMurdy
    Ordered new silicone hoses from GT Car Parts. Figured why fool around - do them both. As noted in another thread, move the P/S reservoir out of the way & it's easy to change them.
    The newer one I put on developed a crack in it. it was leaking air, but not coolant. The older one I snipped in 1/2 to see if it was as constricting as the other I had already replaced. Nope.
    it looked good.
    But anyway, took her for a spin, the air flushed out of the system & the rad fans kicked on like they are suppose to. so far, so good.
