95 B cats and y-pipe | FerrariChat
Discussion in '348/355' started by INTMD8, Feb 27, 2015.
  1. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,505
    Lake Villa IL
    #1 INTMD8, Feb 27, 2015
    For those interested I thought I would show the process of putting together a set of cats and y-pipe for my 95B.
    I will build headers for it as well but that will wait until the next engine out.
    For now the plan is to build replacement cats with Magnaflow 59904 metallic cores.
    I would do test pipes but prefer to keep the exhaust smell to a minimum.
    I'm also going to build a new y-pipe. Materials are ordered and flanges are being cut by a local water jet company. (I couldn't find any ready available with the proper bolt spacing).
    First step is as pictured, building simple fixtures off of the original parts-
  2. carwhisperer
    carwhisperer Formula Junior
    Sep 29, 2014
    426
    Sacramento, CA
    Brian
    Looks really cool but why not just build it up on the car instead of doing all the jigging?
  3. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,505
    Lake Villa IL
    #3 INTMD8, Mar 6, 2015
    If I'm building something from scratch, no problem building on the car but if I have a factory part and I want to match the dimensions, I find it easier to fixture the part and build it on the bench.
    This way I can also avoid tack welding the tubes in the car.
    Still waiting on some parts. Cats have not arrived yet and the flanges I'm having made are also not finished.
    I did start on the y-pipe. Using mandrel bends and merge collector from SPD.
  4. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    Really nice work so far!
  5. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,814
    Tinton Falls, NJ
    Bob Ferraris
    Talented Jim.
  6. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,967
    Northeast U.S.
    Jim
    That is some pretty nice looking welds there.:)
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,570
    SoCal LA/OC/New Mexico
    Tim Dee
    Nice gold welds, keep that heat down
    Looking great !!!
  8. Fast mustang
    Fast mustang Karting
    Nov 15, 2014
    173
    Island lake Il
    Ron
    Like always from you jim nothing but the best
  9. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,505
    Lake Villa IL
    Thanks guys! I appreciate it. :)
  10. 8500rpm
    8500rpm Formula Junior
    May 20, 2014
    546
    San Francisco Bay
    Chan
    Very smart-looking welds there. I also had my cats rebuilt with aftermarket metallic cores (my 5.2 cats cracked). Aside from cost, there's no reason to ride dirty with today's sport cats.
    May I ask if something is wrong with your original Y-pipe, or the reason you wanted to build a new one?
  11. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,505
    Lake Villa IL
    Thanks Chan. I don't like the fuel smell with no cats which is the reason for keeping them on the primary side.
    As for the y-pipe, no problem with it, I just wanted to build a replacement for better flow, sound and lighter weight. I don't think the metallic cores in the y-pipe are restrictive but the "Y" section could be improved upon as the internal transitions are not very smooth.
    Much to be gained in power? I doubt it, but it's winter so it gives me something to do :)
  12. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,967
    Northeast U.S.
    Jim
  13. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,396
    Richmond
    Pete
    Looks great! I would like to do the same, cats on primary and secondary open. Should help calm my exhaust sound in normal driving as well.
  14. 308 GTB
    308 GTB F1 World Champ
    11,190
    New Jersey
    Barry Wolinsky
    Very, very nice, Jim!
    Barry
  15. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,570
    Tim Dee
    Anything homemade is better then bought in my book
  16. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,184
    Atlanta
    John!
    That looks very nice indeed. Let us know if you are offering a recore service
  17. ShineKen
    ShineKen F1 World Champ
    16,663
    Southern California
    Nostradamus
  18. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,505
    Lake Villa IL
    Thanks Ken. That Kreissieg piece looks really nice! I originally thought about doing it that way (build the merge out of the mandrel bends themselves) but SPD was going to charge me another $250 for setup to do 2 60deg (I think that's what it was) bends as they are not a stock item.
    I do like the look of the 2-1 merge collector as well, takes up a bit more real estate :)
  19. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    SCHWING!!!
    Nice job!
    I wish I had welding skills.
  20. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,505
    Lake Villa IL
    #20 INTMD8, Mar 17, 2015
  21. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,967
    Northeast U.S.
    Jim
    Nice work Jim. :)
  22. madturk
    madturk Formula 3
    1,508
    Williston, ND
    Seyhan Kilincci
  23. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,505
    Lake Villa IL
    #23 INTMD8, Mar 18, 2015
    Thanks Jim! Seyhan, 5.2 is a bit more work but shouldn't be too bad :)
    I fabbed up the cats tonight. All the parts are ready now. Just have to wait for my Capristo 2 to arrive so I can install all this stuff.
    Also I showed a few pics of backpurging with argon to prevent sugaring. (This shields/protects the root of the weld).
    You can see how the inside of the pipe at the weld joint is shiny when this is done.
    I also welded a scrap piece and took a photo so you can see how it gets crusty inside with no back purge.
  24. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,814
    Tinton Falls, NJ
    Bob Ferraris
    That is some neat work Jim. Where did you learn how to do this?
  25. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,505
    Lake Villa IL
    Thanks Bob. I taught myself some years back building turbo systems for my own cars.
