95 Berlinetta weight reduction and modifications. | Page 12 | FerrariChat
Discussion in '348/355' started by INTMD8, Mar 25, 2017.
  1. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,643
    Elliott Caras
    Sensational! Would love to see how this rips when it’s back together.
    INTMD8 likes this.
  2. OCKlasse
    OCKlasse Formula Junior
    711
    Newport Beach, CA
    Brandon K
    Wow! So sick!!
    INTMD8 and clean512 like this.
  3. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,849
    Lake Villa IL
    Thanks guys! I’m putting forth my best effort but think probably not worth the effort?
    If I knew how much work it would be, would probably have just ordered Tubi’s
    taz355 likes this.
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    But they would not have been nearly as awesome
    INTMD8 likes this.
  5. ShineKen
    ShineKen Two Time F1 World Champ
    20,172
    Southern California
    Nostradamus
    It’ll be worth it if you start selling them :).
    OCKlasse likes this.
  6. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,849
    Lake Villa IL
    Haha, I guess but I'm too picky to get them done in anything that would be considered a reasonable amount of time.
    I'm out there for hours to get them down to a tenth of an inch the same in length and a degree in all angles. Not really necessary of course but that's what I've been doing.
    sfcarguy likes this.
  7. sfcarguy
    sfcarguy Formula Junior
    534
    Earth
    Honestly if you started selling them in limited quantities I bet some of us would buy them. They can't be more costly than the Tubi's at full retail (7.5k)!
  8. PeteyP
    PeteyP Formula Junior
    May 3, 2005
    830
    NJ
    Petey
    7k for equal length headers is an absolute steal.
    I can only imagine what a 355 with a Capristo and those headers will sound like! :)
  9. JoeCab
    JoeCab Formula Junior
    485
    Colorado
    Joe C
    Hey guys I think we should wait until he finishes his project before we start begging him to sell us headers!
    I know whenever I am in the middle of something I never want to do it again; once it wraps up I start to feel better about the work...
    INTMD8, Teffers, carnutdallas and 2 others like this.
  10. Johnnieblack115
    Johnnieblack115 Karting
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    Aren’t they equal length stock?
  11. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,849
    Lake Villa IL
    They are pretty good but not entirely equal. For an oem header a very good design functionally. I measured 19.75 shortest primary and 22.25 longest primary. So within 2.5 inches or so?
    Certainly an effort was made but could be done better.
    Equal length is what I wanted to do but probably the least important thing in terms of improvements that were made.
    GTUnit, jimmym, OCKlasse and 9 others like this.
  12. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,146
    Josh @jtcarprojects
    Well done. Can't wait for the start up.
    INTMD8 likes this.
  13. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,468
    Los Angeles
  14. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,468
    Los Angeles
    Are you deleting that ticking time bomb gearbox oil warmer in the V or just haven't installed it yet? I want to delete mine.
    INTMD8 likes this.
  15. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,849
    Lake Villa IL
    carnutdallas likes this.
  16. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,468
    Los Angeles
    Very nice. How did you handle the gearbox oil lines? That's the part I can't visualize (because I haven't had my engine out yet). I assume you can't just plug them, you have to fab a line, right?
  17. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Why not just replace it with the upgraded one.
    That’s what I did a few years ago and my original was also perfect
  18. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,849
    Lake Villa IL
    Maybe I'm remembering wrong but I thought Elliot did just that and filled his trans with coolant.
    You can't plug the lines but you can take one of the originals and loop it to the 2 ports on the trans if you weren't going to run an external cooler.
  19. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,774
    The length of the tube ends up dependent on the diameter of the tubes.
    With larger diameter tubes needing to be longer.
    So, if the tube diameters are larger, the length should be a bit longer to stay at the same "tune".
    It is not a lot of length difference but it is not zero !
  20. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,468
    Los Angeles
    Do you think this is something feasible with the engine out or could it be done in situ? I need to replace my thermostat as well. Also have a pair of aluminum radiators waiting to be installed....hmmm....
  21. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,849
    Lake Villa IL
    Sure I don't see why you couldn't do that with the engine in the car.
  22. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,849
    Lake Villa IL
  23. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Sure easier to get to those nuts without secondary air
    INTMD8 likes this.
