95 Berlinetta weight reduction and modifications. | Page 13 | FerrariChat
Discussion in '348/355' started by INTMD8, Mar 25, 2017.
  1. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    Yes, and they have a 10mm head as well. (Porsche)
  2. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,959
    Richmond
    Pete
    It's tricky, there are two ways for a good launch. If you have a fresh ish clutch, 4000rpm and release it quickly but not a dump. Clutch will slip for a second and grab and you'll get a really good tire spin free launch. Not great for the clutch and if you get it wrong you smoke it. Other is 5500 rpm and dump it with l wheel spin, let it drop to 4k and hook. Both will give you a sub 5 0-60... The latter is more fun and looks/sounds cooler but I don't know if I'd do it on a prepped track. It could also depend on tires, some do well with some slip and others don't.
    INTMD8 and FloridaIsland348 like this.
  3. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    It made 340rwhp 250rwtq before all of this. The plan of course was what I quoted above. (and header lengths were focused on the same).
    The results are what I was intending and the numbers are much better than I expected.
    308 GTB, crinoid, OCKlasse and 2 others like this.
  4. JoeCab
    JoeCab Formula Junior
    492
    Colorado
    Joe C
    So: + 32.67 rwhp and only - 3.7 rwtq?
    That sounds like a fantastic trade-off to me.
    How does it feel? I would imagine that much of a high-rpm power bump is very noticeable.
  5. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    I've got to get my car on a Dynojet again. This is what I got on 4-25-13 with one faulty fuel injector and one of my OEM exhaust manifolds which was leaking at the time...
    Since then, all fuel injectors were serviced and calibrated and the OEM headers were replaced with tubi exhaust manifolds.
    INTMD8 likes this.
  6. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,477
    Los Angeles
    Very nice. Did this involve remaping the ECU? or is this stock tune?
    INTMD8 likes this.
  7. ShineKen
    ShineKen Two Time F1 World Champ
    20,217
    Southern California
    Nostradamus
    STOCK 2.7 ECU ;)
    INTMD8 likes this.
  8. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    The ECUs were remapped and the redline raised to 9,000. I forgot to mention that the catalytic converters were gutted prior to my purchasing the car.
  9. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    It feels amazing, I'm super happy with it.
    Part of it would be due to the new weight. (I need to work on corner weights next) And paint the hood.
    308 GTB, MAD828 and ShineKen like this.
  10. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    Yeah I was hoping to do the same but was unable to get Felix to send me chips with a higher rev limit.
    I'll probably address engine management but it's been so long I just wanted to get it together and running.
  11. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,643
    Elliott Caras
    Congratulations on a fabulous outcome!
    jimmym and INTMD8 like this.
  12. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    Thank you!
  13. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,959
    Richmond
    Pete
    372 rwhp? That's stock f430 territory...
  14. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    F430 would be much higher I think but no surprise there.
  15. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,959
    Richmond
    Pete
    Highest I've seen for a stock f430 is ~390rwhp.
    INTMD8 likes this.
  16. ShineKen
    20,217
    Southern California
    Nostradamus
    F430 isn’t 2800 lbs either :).
  17. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    A few more things if interested, here is the inlet trumpets after porting. They were originally a bit smaller than the throttle bodies and had less than ideal transition from the top to bottom piece. Couldn't make them any bigger without the flanges probably cracking off. Had to enlarge the rubber gasket openings as it is.
    ShineKen and 308 GTB like this.
  18. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    jimmym, ShineKen and 308 GTB like this.
  19. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
  20. flat-12
    flat-12 Formula Junior
    Mar 18, 2011
    375
    Germany
    Most owners would be happy with 330 hp
    How did you notice that one of your injectors was faulty? I‘m interested because I never checked mine. New ones are not available and I don‘t know the quality of the aftermarket „rubber“ parts. So still running the old injectors and never checked them … i feel guilty
    308 GTB likes this.
  21. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    ShineKen, flat-12 and 308 GTB like this.
  22. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,860
    Lake Villa IL
    Also would add that the wide open throttle air fuel ratio previous to the most recent work was a bit lean up to 6500rpm or so.
    After injector cleaning the new dyno results show nearly perfect air fuel ratio, despite the modifications.
  23. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    #323 308 GTB, Dec 22, 2024
    I had a couple of hydro-lock episodes which prevented the engine from turning over during start-up. We were able to remedy this by putting the car into 5th gear and having my tech crew push my car forward until it overcame the resistance I felt. Then it started normally.
    Having indwelling fuel pressure gauges at the time helped my technician isolate the affected cylinder bank.
    I now have a single heavy-duty Aeromotive fuel pressure regulator with an indwelling FPR...
  24. fatbillybob
    Aug 10, 2002
    29,487
    socal
    I have been including fuel injector service from RC engineering every 5 years during my major service to get ahead of any fuel mixture related problems.
    INTMD8 and 308 GTB like this.
  25. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    FBB,
    I've added regular fuel injector cleaning and calibration Q5 years to my car's service routine too.
    Barry
    fatbillybob likes this.
