95 Berlinetta weight reduction and modifications. | Page 4 | FerrariChat
Discussion in '348/355' started by INTMD8, Mar 25, 2017.
  1. tres55
    tres55 F1 Rookie
    3,573
    Canada
    80lbs for $4k doesn't seem too bad.
    I love this thread. One day I'll be using it as a guideline. :)
  2. timeckart
    timeckart Formula Junior
    Apr 9, 2015
    558
    Wildeck in Germany
    Tim Eckart
    #77 timeckart, May 4, 2017
  3. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,852
    Lake Villa IL
    The door looks nice! But.... does it fit like factory?
  4. tres55
    tres55 F1 Rookie
    3,573
    Canada
    Wow!
    What's the stock one weigh?
  5. Yassa
    Yassa Formula 3
    1,266
    London
    Dr Yassa Hughes
    Very nice doors! Are those made in Germany? If they're the ones I think they are they're expensive and build time was an issue last time I spoke to a friend of mine there. I think he waited a year for a set.
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Looks like its worth the wait. Hiw much??
  7. Yassa
    Yassa Formula 3
    1,266
    London
    Dr Yassa Hughes
    I heard 7k EUR plus shipping and import duties.
  8. timeckart
    Apr 9, 2015
    558
    Wildeck in Germany
    Tim Eckart
    one door about 2000€
  9. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,852
    Lake Villa IL
  10. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,852
    Lake Villa IL
    #85 INTMD8, May 20, 2017
  11. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,852
    Lake Villa IL
    #86 INTMD8, May 27, 2017
    Making some progress.
    The body shop invoice made me contemplate eating a bullet. Apparently sanding revealed pinholes in the sealer which they had to chase through multiple coats of paint.
    And, while they look very nice and most people would not tell the difference, I can tell that the carbon material is so thin that when block sanding, the bonded mounts behind the thin material kind of transferred through to the surface? Not sure else how to explain it but lets just say they don't block sand as flat as when they are 1/4 inch thick fiberglass.
    I will say that I like the absence of side marker lights.
    When I first installed the Capristo I thought there was enough clearance between it and the rear heat shield. Guess not. Apparently it grew enough to wear right through that part. I fiberglassed it up and replaced the heat reflective material with Zircoflex 3. Expensive stuff I bought for the air boxes, guess I'll order some more.
    ShineKen likes this.
  12. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,492
    Tucson, Arizona, USA
    Robb
    Looks great!
    Robb
  13. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Don't eat that bulit Jim! Hey - 95 rear bumpers did not have vent slots - time to start over :D
    Looks great, buddy. Excellent work bastardizing your pristine car :)
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Jim - is the front bumper wider than OEM? Or I'm I just seeing things? (Very possible)
  15. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,643
    Elliott Caras
    My 95 bumper has vents. I think only the very early 94-95 built cars had no vents.
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Actually I recall looking this up - late 95's had them - probably near the transition to 96.
  17. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,852
    Lake Villa IL
    Lmao, thanks! :D The good news is I can always bolt the old parts on if I want it to be 200lbs heavier again.
    The bumper is wider than original. Why I don't know. Were the kevlar Challenge bumpers wider? (not sure what he pulled the mold from).
    Thanks Robb
  18. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Or I could get in and you would be more than 200 lbs heaver :D
    Jim - You really have a great paint shop - the work looks impeccable :)
  19. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,852
    Lake Villa IL
    #94 INTMD8, May 29, 2017
    Ok, she is finally back together.
    Total weight reduction is........ 212lbs.
    Baseline weight 3199, now 2987
    Had to spin down the coil overs a lot. I think it ended up 12 turns front 10 turns rear.
    Ride height is now (measured from center of lower control arm bolt)
    6.4in front
    7.5in rear.
    Nearly out of threads on the front shocks so couldn't go much lower even if I wanted to without changing springs.
    I only drove it a few miles but feels great! Love the seats and overall feel of the car.
    Still have to swap out the steering wheel from the 456 to early 355 but so far really happy with the result :)
    Basic rundown again of what was changed-
    -Front and rear bumpers replaced with carbon. No side marker lights. Euro corner lights.
    -Antigravity lithium battery
    -titanium wheel bolts
    -removed metal support structure from behind dashboard
    -removed airbags/non airbag steering wheel
    -Installed carbon 550 seats with fixed mounts (no sliders)
    -removed washer/wipers
    -removed trunk liner and tool kit (naked 'frunk')
  20. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,643
    Elliott Caras
    That is awesome - I bet it really feels alive now!
    When will you take it to the strip for a quarter mile run?
  21. 355dreamer
    355dreamer F1 World Champ
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    Nicely done.
  22. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Everything Jim does, is. :)
  23. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    Nicely done, Jim!
    Barry
  24. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    [ame]http://www.youtube.com/watch?v=2P5RCurT8Yw[/ame]
  25. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Just so you know James I quote your times to others as how fast our cars are in the quarter.
    I guess thats a little fib!!
