95 Berlinetta weight reduction and modifications. | Page 5 | FerrariChat
Discussion in '348/355' started by INTMD8, Mar 25, 2017.
  1. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    I don't know if this applies to the 355, but on the 348 the fuses are at the passenger's feet behind a surprisingly heavy plate of steel. Easy to change to a piece of aluminum and save a bit of weight for cheap.
    Any idea what the factory carpet weighs? Might be more than you think. Maybe replace with chintzy thin stuff depending on how far you want to go.
    If you were crazy obsessive with time to burn you could try to figure out how to pull the gas tank and replace with a 5 gallon plastic jug. Trying to fit the fuel pumps could be problematic. Either way you'll want to calculate fuel needed for each trip and not carry any excess gas.
    Speakers have neodymium magnets? Or how about (as you can see, suggestions get increasingly absurd as you progress through this note) tire weight? I'm always amazed how much those wide tires weigh. Do different brands of tire have significant weight differences, or are they all pretty much the same?
    Then, of course, if you're really serious, take some Lasix an hour or 2 before you hop in for a drive...
  2. yvesolution
    yvesolution Karting
    Apr 26, 2010
    182
    Cabo Verde
    do you know how much the stock door weights?
  3. GerryD
    GerryD Formula 3
    May 5, 2010
    2,448
    North of TO
    Guido
    The stock doors weigh a ton. If Jim thinks the car handles great now, just try decreasing the unsprung weight in the wheels and It will feel twice as good.
    ShineKen likes this.
  4. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,853
    Lake Villa IL
    Thanks guys!
    Elliot, I'll probably take it in the fall so the temp/density altitude is similar.
    Grant. My 1/4 mile times are from before the weight reduction, when it was still 3199.
    Still slightly lighter than original because it had a Capristo/cats/y-pipe.
  5. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,493
    Tucson, Arizona, USA
    Robb
    I am really impressed! Looks fantastic. Must feel like a new car!
    Robb
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Yes I know I am hoping they get better.
    Maybe you should send Ferrari the new official times so they could ammend your WSM accelarations because they are clearly not correct.
  7. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,853
    Lake Villa IL
    Paul, I will check that fuse box plate, thanks.
    Thanks Robb!
    Grant I suspect it will be a little better. 2 tenths/2mph would be my best guess.
    To be fair I would have to run my car with the stock cats/y-pipe/muffler to compare with Ferrari's official time. What do they show it as, 12.9? Probably would be close.
  8. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,853
    Lake Villa IL
    #108 INTMD8, May 31, 2017
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    James is it me or is the front center area also drive more air underneath, it kinda looks bigger?
  10. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,853
    Lake Villa IL
    That area looks similar to me but I will try to take some measurements and compare the profile.
    If it is different I don't think by much.
  11. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,853
    Lake Villa IL
    #111 INTMD8, Jun 10, 2017
    I've been wanting some kind of heat shield for the air boxes.
    Thought about the challenge parts but they look like they are just fiberglass sprayed with a heat reflective paint?
    I ended up getting a sheet of Zircoflex 3. It's triple layer aluminum and each layer sprayed with ceramic heat barrier.
    Worth doing? Make a difference? No idea, but it's done and isn't super noticeable once installed.
  12. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
  13. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,853
    Lake Villa IL
  14. Flavio_C
    Flavio_C Formula 3
    2,445
    Insubria
    Have you thought about adapting carbon-ceraminc brakes? They are what, 4kg ligher per corner?
  15. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,853
    Lake Villa IL
    The racing brake setup which uses ZR1 rotors is 5.7lbs lighter each front rotor and 4.5lbs lighter each rear rotor.
    Then you have mounting brackets and bigger calipers, total weight loss would not be much but would have less rotating mass. (even then how much less polar moment of inertia with a larger diameter rotor).
    RB-CCB Kit - 380mm/380mm Carbon Ceramic Rotors w/RB Forged Aluminum Calipers for Ferrari 348/355 (P/N 2C14 & 2C48)
    So, 14k for the above and they won't fit under the stock wheels.
    Movit can make a set that will fit under the stock wheels but they are about 23k.
    So yes, I have thought about it but do not think it's worth the cost at this point.
  16. Flavio_C
    Flavio_C Formula 3
    2,445
    Insubria
    #116 Flavio_C, Jun 14, 2017
    Indeed, not worth the cost.
    Some years ago I remember seeing a photo of a F355 with original calipers but with carbon-ceramic rotors from this company:
    Sicom Brakes | Custom made performance
    Since then they completely revamped their website and that F355 photo is gone. Perhaps it's worth contacting them and see what they have to offer.
  17. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,853
    Lake Villa IL
    Great idea, I will check it out :)
  18. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,853
    Lake Villa IL
    #118 INTMD8, Jun 15, 2017
    Senshi458 and ShineKen like this.
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Really looks killer, Jim. Great work, but that's no suprise coming from you :)
    Who did the wheel?
  20. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,853
    Lake Villa IL
    Ha, thanks Dave, I can't take any (well not much) credit for the wheel.
    It was done by Craft customs in Texas.
    Problem was they used leather that was thicker than original. Soooo, the center of the steering wheel didn't fit anymore. Overlapped the wheel by 1/8in or so.
    Since the wheel looked so nice rather than have them re-do everything in thinner material I cut the ends off of the horn pad, sectioned a piece out of each one and welded it back together.
    That allowed room for everything to fit again with the thicker material.
  21. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    The credit you deserve is the ongoing kick ass work you do. Everything is always done right - no hack jobs. You have amazing talent, Jim. Total respect.
    Oh....and you can jump on a box 54" high too :)
  22. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    #122 308 GTB, Jun 15, 2017
    Jim, the perforated leather on your steering wheel looks great.
    Since you passed on the MOMO Competition wheel, I bought it and added a push-to-talk switch for UHF radio communication...
  23. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Looks good Jim
  24. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,643
    Elliott Caras
    Jim was the 3 spoke section recovered on the wheel too? If so they did a great job matching the pressed circles.
    Interior really looks stunning. Great job.
  25. Robb
    Robb Moderator
    Feb 28, 2004
    14,493
    Robb
    Wheel looks fantastic!
    Robb
