95 Berlinetta weight reduction and modifications. | Page 9 | FerrariChat
Discussion in '348/355' started by INTMD8, Mar 25, 2017.
  1. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,850
    Lake Villa IL
    Pete is your top speed pro exhaust the titanium version?
  2. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Yeah I dont run the hanger in my lightweight exhaust systems. They float well
  3. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,952
    Richmond
    Pete
    No, when I got it that wasn't an option.
  4. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,850
    Lake Villa IL
    Asked only because they advertise the titanium system at 7.15lbs so I was surprised to see your steel system coming in at 8lbs.
  5. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,850
    Lake Villa IL
    Finished the y-pipe and test fit everything.
    Not sure that part was worth the trouble.
    The stainless y-pipe I made with the spacer is 6lbs.
    The titanium y-pipe is 2.4lbs.
    Not using the exhaust hangers anymore, they come in at 3lbs.
    So total weight loss of exhaust/y-pipe/hanger removal is 27.5lbs?
    LOL. Next, -may- be rear subframe.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    radback, jimmym and ShineKen like this.
  6. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,643
    Elliott Caras
    That’s so nice! Great weight savings off the most important area.
    INTMD8 and OCKlasse like this.
  7. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,995
    Northeast U.S.
    Jim
    Getting close Jim.:)
    INTMD8 likes this.
  8. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,850
    Lake Villa IL
    I -really- thought my guides would be tight and valves sealing awesome based on my cars performance.
    It ran awesome. Great numbers on the dyno and at the track. Didn't smoke or use oil.
    That being said, I was really surprised at how bad the heads/guides are upon disassembly. Measurements? Have none. I didn't take any. Just observed that it was horrible and decided I need to fix it.
    Also. I have not CC'd port volumes but have taken a bunch of measurements. From the start of the intake port to the guides, my early 2.7 heads are very similar in size to the later 5.2 head I bought.
    After removing valves in my 2.7 heads, I've found the early heads seem to have a ton of material removed in the bowl area compared to the later 5.2 heads.
    Also notable, (to me at least) is, while my early heads are much bigger in the bowl area of the heads, the quality of the work is unimpressive. Lumpy transitions and just looks rushed.
    In comparison, the later 5.2 head I bought looks beautiful. Looking at the port work I thought, it would be hard to improve upon it. Just super nice.
    Mark HT likes this.
  9. Mark HT
    Mark HT Rookie
    39
    Mark HT
    Yeah, no need to waste your time measuring those guides! o_O
    Would be awesome if you could post some pics showing the differences between the 5.2 and 2.7 heads. :)
  10. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,850
    Lake Villa IL
    I don't think I will be able to capture the difference with photos. (I can try, don't think anyone could see the difference). Even looking at it in person it's hard to tell. Becomes more clear when you feel both of them.
    Best I can describe it is, on the long side of the intake port, the 5.2 head has a perfect, long radius to the seat.
    On my 2.7 head, that same long side overshoots meeting up with the seat. So below the seat/long side/top of port almost forms a bit of a bubble below the seat before meeting it. (overshoots then turns back to the seat)
    5.2 head, appears ported by a master. Just super nice the entire port, on every cylinder.
    One of my 2.7 heads looks to be ported very nice, but not quite as nice as the 5.2 head I have.
    The other 2.7 head I have looks to be ported by someone else entirely with very little skill/attention to detail.
    No worries, I will fix it myself. Just a bit surprised to see the variance between the 2 heads.
    ShineKen and Mark HT like this.
  11. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,472
    Los Angeles
    That video is wild. I don't understand how the valve heads weren't beating the crap out of the seats and causing sealing problems. I had a 911 engine with a couple guides that worn and the seats were in bad shape.
    Are you sending the heads out or doing yourself?
  12. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,850
    Lake Villa IL
    I believe they didn't seal well, all things considered.
    Cold compression test was 150-170psi. Looking at the valves/ports there was evidence of poor sealing in the way of carbon/black traces up the valves.
    As excellent as -some- of the port work is, the valve job on both the new and older head appears to me to be a single angle valve job. One angle seat cut and very wide margin.
    I think that's why my car didn't exhibit any symptoms. Guides sloppy as hell....still... easy to seat the valve with no precision to the massive seat.
    ^ To your question, I would prefer to send them out. Problem is, I don't really trust anyone.
    So from here I will order sample guides from multiple manufacturers to determine which I prefer.
    I'll remove all guides from my heads then port them to match as best as I can.
    Install best guides, then have the seats/valve job machined best as possible.
    Not sure how much improvement will be found. Still surprised it made 340rwhp and (with weight reduction) ran 12.4 @ 116.8 with the above issues.
    My best guess is the F355 valves could still do a decent job of sealing due to their small size. (and really less amplified by center valve 10deg retarded)
    In comparison, same generation 2-valve (and basically hemi combustion chamber) Porsche, could suffer much more with same or less guide wear, I would think.
    ShineKen, MAD828 and Targatime like this.
  13. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,952
    Richmond
    Pete
    You're only .2 and 3mph off of a 360 challenge stradale in the 1/4 - with properly sealing valves I wouldn't be surprised to see you at the same power/weight. Impressive!
    ShineKen and INTMD8 like this.
  14. radback
    radback Formula Junior
    808
    France
    Very interesting thread. (from the only guy who did provide me usefull info in another thead while all others were bashing me for daring asking what would be the proper launch for this car ;) )
    Congrats INTMD8! Very nice work (and attitude :)).
    INTMD8 likes this.
  15. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,850
    Lake Villa IL
    ShineKen, tres55, Mark HT and 4 others like this.
  16. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,472
    Los Angeles
    Sexy looking ports. Any room for improvement? Sure look nice right out of the box.
    INTMD8 likes this.
  17. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,774
    The biggest problem with 5-valve heads; is cooling, airflow is about as good as it gets.
    A few hours with a rotary file might get 1%-3% (but if you take material from where it should not be taken, you can just as easily lose that 3%.)
    On the exhaust side: a ramp from the port to the header adds considerable flow to the port without enlarging the interior volume. That is, come off the port at the 15º angle starting at 38mm and progressing to 42mm over 10mm. The 38mm end will need to be shaped to the port. Then the exhaust pipes should remain 42mm to the collector(s).
    INTMD8 likes this.
  18. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,850
    Lake Villa IL
    As for the port work I'm going to blend/smooth some of the lumpy work that was done but I don't intend to enlarge them any more than needed or re-shape significantly. The design looks very nice to me.
    On the exhaust side I had header flanges made that match the exhaust port angle.
  19. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,147
    Josh @jtcarprojects
    Love this. Great work what your doing.
    INTMD8 likes this.
  20. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,850
    Lake Villa IL
    The stock exhaust port is, as mentioned, an upward angle relative to the flange.
    The original headers do not match that angle so while the size matches fairly nice (header maybe slightly smaller than port) the angle does not, as you can see-
    ShineKen likes this.
  21. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,850
    Lake Villa IL
    The new flanges are- slightly larger.
    Original primary tube OD I measured at 1.573 or 40mm
    New primary tubes will be 1.625 or 41.27mm
    Slightly larger but really only because 1.625 mandrel bends are as close I can find in the US without going smaller than original.
    Focus is on, flange design being an extension of the port, rather than disrupting it, larger radius bends and slightly altering tube lengths.
    tres55, ShineKen, audi_328 and 5 others like this.
  22. Mitch Alsup
    Nov 4, 2003
    9,774
    Yes, yes, yes, exactly !!
    Figure 2 in both posts shows the dramatic difference well.
    taz355 and INTMD8 like this.
  23. FloridaIsland348
    Aug 5, 2022
    118
    Pensacola Beach
    Scott Wheatley
  24. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,850
    Lake Villa IL
