355 - 95 Cat ECU location | FerrariChat
355 95 Cat ECU location
Discussion in '348/355' started by Yassa, Jan 9, 2020.
  1. Yassa
    Yassa Formula 3
    1,266
    London
    Dr Yassa Hughes
    Can someone please post a pic with the location of the cat ECU on a 2.7 355. I searched the forum but only found pics for the 5.2.
    I am looking to disconnect it as I'm running test pipes.
  2. fboutlaw
    fboutlaw Formula Junior
    Dec 3, 2014
    260
    Woodside, CA
    Don't have a photo on me, but it's directly under the ECU on each side.
    Go under the ECU connector, and reach your arm further into the side of the vehicle. You'll feel a box with 2 connectors into it. Those are the Cat ECU's.
  3. Qavion
    Qavion F1 World Champ
    14,312
    Ian Riddell
    #3 Qavion, Jan 9, 2020
    Yassa likes this.
  4. ShineKen
    ShineKen F1 World Champ
    19,892
    Southern California
    Nostradamus
    Should be an even easier solution by messing around with the thermocouple wiring. Forgot exactly what needed to be done. Will look for a thread.
    Yassa likes this.
  5. Yassa
    Yassa Formula 3
    1,266
    London
    Dr Yassa Hughes
  6. Qavion
    14,312
    Ian Riddell
    Yassa likes this.
  7. Yassa
    Yassa Formula 3
    1,266
    London
    Dr Yassa Hughes
    Awesome. Thanks
  8. Yassa
    Yassa Formula 3
    1,266
    London
    Dr Yassa Hughes
    Thanks. And which of the two connectors do you disconnect? The one with the wiring I'm guessing the other has what looks like a ground cable to it...
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,574
    San Carlos, CA
    Mitchell Le
    The ground cable is the shielded thermal couple. After you remove the TCU, the thermal couple is no longer needed.
  10. Yassa
    Yassa Formula 3
    1,266
    London
    Dr Yassa Hughes
    Got it. Thanks
