95 F355 acting up but no codes again? | Page 2 | FerrariChat
Discussion in '348/355' started by Orange Crush, Aug 31, 2017.
  1. Orange Crush
    Orange Crush Karting
    Dec 30, 2009
    101
    Wichita KS
    Rob
    He noticed something a little odd.. the Driver side ECM at pin 39 was connected but the passenger side pin 39 was disconnected and covered with tape. Looks like a DIY Hack, anyone know what pin 39 does on the ECM?
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    Main ECU ground.
  3. Orange Crush
    Dec 30, 2009
    101
    Wichita KS
    Rob
    I wonder why a main ecu ground would be taped off?!??
  4. Qavion
    Qavion F1 World Champ
    14,606
    Ian Riddell
    Is it really the main ECU ground? According to the wiring schematics, that ground is applicable to USA cars only. What happens to Euro cars which don't have that? Does grounding that pin activate something inside the ECU?
    Rob, do both ECUs have the same part number?
  5. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    All the ones I have seen did.
    And you can swap bank to bank.
  6. Orange Crush
    Dec 30, 2009
    101
    Wichita KS
    Rob
    A couple more updates.. ecu #s were the same and upon inspection he found that the actual fuse socket wasn't working for the one that controlled the o2 sensor. Got that fixed and it's not rich anymore! He is chasing a pesky issue now where it is missing occasionally at idle and under low revs. Looks to be just one cylinders Clears up over 3k rpm though?
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Maybe an injector
