95 keeps fouling plugs, thoughts? | FerrariChat
Discussion in '348/355' started by Orange Crush, Feb 18, 2017.
  1. Orange Crush
    Orange Crush Karting
    Dec 30, 2009
    101
    Wichita KS
    Rob
    A few weeks back I came out and started the car when it was really cold out(I know, I read now that's a no no) and it sounded rough and flat. Shut it off and had it towed and found all the plugs black and gas fouled. He replaced a bad thermocouple and O2 sensor and replaced all plugs and I got it back and It seemed fine for about 50 miles.. then I pull it out of the garage and drive it to a store 5 miles away and run in real quick, come back out and start it and sure enough same flat tone and feeling of fouled plugs. No warning lights, 70 degrees today so now I'm just frustrated. Could it be a temp sensor thinking it's cold and dumping fuel in? Both times it fouled under startup, hasn't happened while driving yet. Thanks for any help you can give, tired of throwing money at it to see it keep cropping up !
  2. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,635
    SoCal LA/OC/New Mexico
    Tim Dee
    Leaking injector?
  3. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    That happens on occasion with other cars so it'd be my first thought in this case since I believe you have two fuel pressure regulators, which pretty much eliminates them from the list of candidates. Wouldn't be a bad idea to replace the CTS (coolant temp sensor) for good measure, but even if you don't I'd suggest treating the connector pins with DeOxit D100 for a while, then cleaning them with spray cleaner and following up with DeOxit Gold a couple of weeks later. Any resistance in the wiring between the CTS and the ECUs changes the temperature that the ECUs see.
    Disclaimer: I'm not a 355 owner, but I've chased these issues on other Motronics cars and those procedures have worked well.
  4. ClydeM
    ClydeM F1 World Champ
    12,051
    Wayne, NJ
    Clyde E. McMurdy
    Time for an Italian tune-up
  5. plugzit
    plugzit F1 Veteran
    7,787
    Redondo Beach, CA
    Bruce Bogart
  6. F355Bob
    F355Bob Formula 3
    What plug are you using? 95's take a different plug than other years because they are known to foul if you just start and shut off. They run richer than other years. I have piggy back computers to change fuel and timing and the tuner took out a lot of fuel on the low end. Don' t turn off until you are off the enrichment cycle and make sure you are using the correct plug.
    Spark is weak on these cars.
  7. joe1973
    joe1973 Formula Junior
    Nov 12, 2016
    286
    NJ
    Driving a 355 in the 20s is not a 'no no'. I've driven mine here in NJ at that temp as long as there's no snow/salt on the roads. There should be no problem with cold weather driving at all.
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,044
    Indio Ca/ Alberta
    Grant
    Except lighting up the tires!!
  9. F355Bob
    F355Bob Formula 3
    Check plug heat range. 95 run a hotter plug than other years to prevent fouling.Avoid running a few minutes and shutting off. Should run until fans come on so you are in the 190 degree water temp and off enrichment. 95's run rich.If still running rough on occasion and plugs are good, check thermocouple ECU. For a few years my car would suddenly feel like running on 4 cylinders. It would happen randomly. Turned out bad thermocouple ECU that would shut down a bank so I was running on 4 cylinders When you ran to store and shut it off, what was your water temp reading? If low, like 100 degrees you were still in enrichment cycle which is really rich on the 2.7 cars. I went through all these problems with my 95 in the 17 years of owning one. They are different than the other years.
  10. phrogs
    phrogs F1 Veteran
    7,355
    Kzoo Michigan
    Yeah you better have winter tires below 45 degrees.
    Tires are the most ignored safety feature on cars.
    Might as well be driving on ice.
  11. flat_plane_eddie
    flat_plane_eddie F1 Rookie
    Owner Regional Sponsor
    Mar 30, 2013
    3,168
    DC
    Eddie
    As others have said I would try both the intake and exhaust related sensors. MAF: clean it. Would a bad O2 or thermocouple not give an error code? I don't get why he would say they're both bad, I mean the chances of both being bad, especially the thermocouple are pretty slim from what I know.
    More likely the ECUs are bad if anything.
    Also, if one injector was bad I don't think all your plugs would be fouled but it doesn't hurt to have them all cleaned. I cleaned mine and the car runs a bit smoother.
  12. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,272
    CT
    John Kreskovsky
    Bad TC or TC ECU would generally not result in fouled plugs. Worst case is that it would cut off fuel to a bank which would not fouled plugs. Bad O2 sensor would throw a code. So would a bad MAF. You might consider checking spark when the engine runs rough. Could be an intermittent ignition problem. Been there. Start and drive one day, perfect. Next day, start and it not hitting on all eight. A day later, fine again. Can be a ***** to diagnose but fortunately coil, ignition module and crank sensor are cheap if you know where to get them. Just search on the Bosch part number.
  13. Orange Crush
    Dec 30, 2009
    101
    Wichita KS
    Rob
    Appreciate all the advice! I went out and started it today and she fired right up strong. Drove her around a bit to get to operating temps and ran well the whole way. Looks like I'll be doing some searching as I can tell it's still richer than normal. If a temp control sensor went bad will it throw a code on an OBD1 car?
  14. m.stojanovic
    m.stojanovic F1 Rookie
    3,296
    Serbia - Niš
    Miroljub Stojanovic
    Not necessarily, depending on how bad it is. If the coolant temp. sensor is just out of calibration, it may be signalling that the engine is still cold causing the ECU to provide enriched mixture.
  15. markcF355
    markcF355 F1 Rookie
    Jun 6, 2004
    3,493
    Schmeckelstan
    Mark
    I had a problem with two plugs fowling and it turned out to be the wires.
  16. Orange Crush
    Dec 30, 2009
    101
    Wichita KS
    Rob
    Getting ready to send her to the dealer to see if they can diagnose.. is there a way to disconnect the temp sensor when warm to see if it stops running rich? I took it out for a short drive and after about 5mins on low rpm it definitely fouled a plug and sounded off. Once I got to 3500rpms however it cleaned up and she ran great the west of the way home? Let her idle for a while and never fluttered again after at all. So confusing.
