'95 left fan not running | FerrariChat
Discussion in '348/355' started by ClydeM, Jun 2, 2016.
  1. ClydeM
    ClydeM F1 World Champ
    11,987
    Wayne, NJ
    Clyde E. McMurdy
    #1 ClydeM, Jun 2, 2016
    I replaced the fan over a year ago with a new thermostat for it.
    The other day, the cars temp shot up at a light. The fuse was fine. Figuring it was the temp sensor, I bought a new one & just installed it. I also ran 12V direct from a spare battery to the fan & it spun up fine. Checked the Relay - clicked with power applied
    During the 25mph test drive, same thing - Temp started to climb. Parked & checked - no fan spinning.
    Next to check?
  2. Pangea
    Pangea Formula Junior
    Mar 27, 2011
    442
    Nick
    Had exactly this on my 348. Fan ran off spare battery. Turned out to be a faulty connector on the loom side. Worth a look with a meter to check feed.
  3. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Check your water
  4. ClydeM
    11,987
    Wayne, NJ
    Clyde E. McMurdy
    Water level is fine,
    though taking out the thermostat plug in the radiator, very little spilled out. maybe 1/4 cup.
  5. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Working on my right fan same issue today with same working parts as yours Clyde. Changing temp sensor and adding coolant today.
    Going to check wiring continuity today. I did just swap l/r relays as a relay check although it sounds like yours is working.
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,264
    CT
    John Kreskovsky
    Relay clicking doesn't mean it's good. Contacts could be be shot. The other issue would be the temperature switch at the top of the LH radiator. You can pull the connector and short the terminals in the connector with a paper clip to bypass the switch. If the fan runs the switch is bad.
  7. ClydeM
    11,987
    Wayne, NJ
    Clyde E. McMurdy
    Besides clicking, I checked for continuity. It seemed fine. Relays swapped anyway. A new one is on the way. I'll jumper the switch & see if the fan sparks to life.
    Good luck with yours, Bob. While mine is probably mechanical, yours might be electronic. That's just hassle & Cost :(
  8. Ferrari Fanatic
    Ferrari Fanatic Formula 3
    Apr 2, 2003
    1,317
    SoCal
    Check both sides on your fuse box in the passenger side foot well. I have seen the terminal at the fuse box / fuse holder melt.
  9. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Look at the pics I posted on my thread Clyde. Ugh
  10. ClydeM
    11,987
    Wayne, NJ
    Clyde E. McMurdy
    And you with such an immaculate car! How could that happen? :)
    I jumpered my fan sensor & the fan kicked right on.
    So it's either a bad (new) sensor, the relay that I swapped yesterday (I'll swap it back) or the water isn't getting to it. Maybe an air lock :(
  11. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    #11 drbob101, Jun 3, 2016
    Some contact cleaner and compressed air and they look fine. I think they used some kind of paste/conductor in those. The same that was on the headlight motor inside. It gets funky. Not sure it's a problem but looks bad.
    Cleaned up well
  12. ClydeM
    11,987
    Wayne, NJ
    Clyde E. McMurdy
    I swapped the relays back - the fan still fired up when the temp switch was jumpered.
    Pulled the switch out & popped it into a pot of water - it opens up as it should at about 85.
    Check what I think is the OEM switch - 85/76
    one from superformance about 1 yr old - 88/82
    one from GT Car parts (newest) - 88/82
    so at this point, I have to say it's an air bubble in the system and I"ll have to figure a way to get it out.
  13. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    Open the coolant tank cap,
    Fill it to the right level with coolant
    Run the engine until it gets hot.
    Close the cap.
  14. ClydeM
    11,987
    Wayne, NJ
    Clyde E. McMurdy
    Son of a gun, that did it (or so it seems).
    temp climbed past 190. Shortly after I had a bunch of air bubble out and it settled back down. The temp dropped to 190 where it usually sits. Then the fan came on. So much for self-bleeding coolant system :(
  15. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    It is self bleeding, but you have to open the cap so the bleeding can happen.
  16. ClydeM
    11,987
    Wayne, NJ
    Clyde E. McMurdy
    Took her for a 20mile drive. It's about 87 here & a bit humid. Started out great.
    Then I noticed the temp gauge would swing from a mark below 190 to a mark above 190 at lights. Start going & it would drop to average 190. My last recollection of the guage is it is generally rock-steady at 190.
    Get home, fan is not on. The fluid is fine. I'm still thinking air bubbles :(
    Anybody?
    And I'm thinking the system shouldn't need the cap ajar to bleed air. I'm thinking any air bubbles it's way up and into the tank. Pressure > 90lbs (as memory serves) and the cap releases pressure/fluid into the overflow.
  17. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    The gauge should oscillate bit around 190 when sitting still. It gets hot, the fan comes on, it cools down, fan stops, cycle repeats. Although a whole mark above 190 seems high and your fan is not on is not good.
    Again, check fuse, relay, short out the switch to make sure fan comes one. I think you have a new thermal switch, right?
    Then, open the cap and run the engine until the fan comes on. If the fan comes on while you are idling, it should come on while you are driving unless your radiator is blocked.
    How is your water pump?
  18. m.stojanovic
    m.stojanovic F1 Rookie
    3,284
    Serbia - Niš
    Miroljub Stojanovic
    These are typical signs of a small leak at a cylinder head gasket. Small amount of combustion gasses are being pumped into the cooling system with every combustion stroke eventually forming a larger air (gas) pocket. A way to diagnose this is run the engine with the tank cap open and look for a few bubbles coming up after every brief engine rev. Better way is with a combustion leak tester.
    If gas leak is confirmed, you can try re-torquing the heads. If this doesn't work, new gaskets.
  19. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    The potential of some sort of a combustion chamber leak also crossed my mind as I read through the symptoms. Hope that's not the case, but fairly easy to confirm or deny.
  20. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    None of that is short work. If you are correct, that's a big deal.
  21. ClydeM
    11,987
    Wayne, NJ
    Clyde E. McMurdy
    new thermal switch - yes, checked fuse, put a new relay in.
    let the engine idle again, fan didn't come on. I saw the fluid circulating in the tank.
  22. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Clyde. Put that dc soutce directly back on the fan. Maybe it's intermittently dying.
  23. ClydeM
    11,987
    Wayne, NJ
    Clyde E. McMurdy
    That's the plan, as is jumpering the thermal switch again.
    but tomorrow.
  24. ClydeM
    11,987
    Wayne, NJ
    Clyde E. McMurdy
    Think I found the problem: the wiring loom's female connector at the fan collapsed. It was making intermittent contact. WIth a couple dentist picks, I was able to open it back up. For another day, I'll buy a pin extractor & do it right.
  25. ClydeM
    11,987
    Wayne, NJ
    Clyde E. McMurdy
    #25 ClydeM, Jul 17, 2016
    this is every tri-state's nightmare - hot, humid & stuck at a river crossing. For me, today, it was twice.
    This morning about 8am I sat in 3 miles of 45min traffic on the crossbronx. she held constant at just a smidge above 190. Outside was 65%humidity & 98 degrees.
    I think the engine bay got so hot, the starter got stuck 'cause I shut her down briefly and not even a click when I went to start her. For those familiar with traffic and the tristate, your probably shivering now. Yep, 3 lanes squised down to one and folks in this heat passing a Red Ferrari on the shoulder. There was no sympathy here. to the guy in the pickup truck who shouted "Should have bought a Chevy". yah. ha ha. Park yours next to mine and we'll watch yours rust.
    then coming back the GPS routed me through mid-town. You know its bad if your best option is across mid-town.
    30 min in stop-and-go traffic at Dyer at the Lincoln. my cell said 111 degrees. the radiator temp gauge said 190 (ish).
    so at least she wasn't overheating. and I took RifleDriver(?) suggestion - slip a plastic sheet on the top of the door/body breather barriers to the radiator with two-way tape (rather than rivet) to separate air flow & hot air return and sure enough, even with this kludge she ran smoother.
