95 obd1 rough idle misfire | FerrariChat
Discussion in '348/355' started by 490times, Apr 4, 2020.
  1. 490times
    490times Rookie
    Nov 14, 2018
    47
    Syracuse
    Timothy
    Hello. I've reached my first issue with the infamous maintenance nightmare 355 :)
    Ran great off the trailer, parked it in the garage. Start it up, pull it out of the garage. Work on interior bits. Pull it back in the garage. Repeat for half dozen days. Replace stock muffler with topspeed pro1 challenge (basically straightpipe). Put back in garage.
    Pull out of garage: runs rough. idles at 1200 rpm. Tap gas, rough rev. Sounds and feels like misfire. Back in garage. Disconnect battery, let sit for 2 days. Reconnect battery. Fire up. Idles rough. Starts "coughing" like, sputters, not quite backfires...
    I'm about to start pulling spark plugs.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,413
    San Carlos, CA
    Mitchell Le
    #2 yelcab, Apr 4, 2020
    Should never, ever, absolutely never do that to a 95 355. Pull plugs, clean or replace all eight plugs. If that does not work, then we can talk next.
    I rather park it outside in the driveway, put a plastic bag over the engine, cover the car with 2 car covers, and leave it in the rain than to abuse the car by driving it 20 feet, 12 times.
    My 348 has been outside for two weeks now under 2 covers, untouched, unmoved, because of this exact issue. I refuse to start the car and move it 10 feet.
  3. 490times
    490times Rookie
    Nov 14, 2018
    47
    Syracuse
    Timothy
    I done messed up.
  4. Qavion
    Qavion F1 World Champ
    13,918
    Ian Riddell
    If in doubt, go to the last modification you did on the car.
    When you changed the exhaust, what parts did you remove/disturb/forget to reinstall
    490times and 308 GTB like this.
  5. 490times
    490times Rookie
    Nov 14, 2018
    47
    Syracuse
    Timothy
    The exhaust was straight forward. No sensors or anything. Pop off the old, pop on the new. But look at the orange and white residue on my fourth plug wire :'(
  6. yelcab
    Nov 29, 2001
    13,413
    San Carlos, CA
    Mitchell Le
    That is rust from intruding water since burnt off.
    490times likes this.
  7. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Could be a lot of things. Plugs, wires, electrical connection, fuel, etc. While it is running start jiggling wire connectors, especially the fuel injector connectors and see if any of them aren't making a good connection. I had to replace several of the AMP connectors. That fixed a miss, but replacing plugs and wires made a big difference in smoothness.
  8. 490times
    490times Rookie
    Nov 14, 2018
    47
    Syracuse
    Timothy
    All the plugs were dry with little soot. Cleaned them off anyway. The wires and connections all looked good (except for #4 with the rust residue) clean on both the coil and the plug ends. Reconnected the battery and fired her up. Sounded improved! For a few minutes... by the end of the 10 minute ECU relearning idle, the rpms had settled to around 1k and it was still muscle car sounding, but no longer coughing/sputtering.
    Qavion likes this.
  9. 308 GTB
    308 GTB F1 World Champ
    11,661
    New Jersey
    Barry Wolinsky
    That's what an F355 with a Top Speed Pro-1 Challenge Race Exhaust sounds like at idle, Tim.
  10. 490times
    490times Rookie
    Nov 14, 2018
    47
    Syracuse
    Timothy
    I was beginning to suspect such... I'm thankful to be part of a helpful community :)
    308 GTB likes this.
  11. 308 GTB
    11,661
    New Jersey
    Barry Wolinsky
  12. 308 GTB
    11,661
    New Jersey
    Barry Wolinsky
    bobzdar {Pete} has the Top Speed Pro-1 Challenge muffler on his F355 Berlinetta. It sounds like this...
    Yours will too. :)
  13. yelcab
    Nov 29, 2001
    13,413
    San Carlos, CA
    Mitchell Le
    I had a friend who bought a 95 355 with that essentially-straight-pipe set up. It was loud, it was obnoxious, and it was [he decided] uncivilized. He changed to Capristo Stage 2 and was much happier. I was happy with my Tubi muffler.
    The straight pipe reminded both of us why we did not like Harley Davidson bikes with no straight pipes.
  14. 308 GTB
    11,661
    New Jersey
    Barry Wolinsky
    I agree, Mitchell. The Challenge exhaust is loud, obnoxious and uncivilized. Its place is on a race car on a race track. When I'm on the track, just a small percentage of my senses are devoted to exhaust sound. I'm too busy doing other things in a prioritized fashion.
    Yes it's loud, obnoxious and uncivilized. :)
  15. 490times
    490times Rookie
    Nov 14, 2018
    47
    Syracuse
    Timothy
    I agree, it's fairly loud and screams "look at me" while driving even conservatively...
    I had seen bobzdar's video but went with it anyway. The rumbly idle kinda threw me off because I didn't find any decent audio quality videos except for his 5 minutes of no stop sign corner-pulls.
    I may return to the OEM muffler if I get sick of the drone.
  16. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I find many aftermarket exhausts make the cars sound like muscle cars at idle. Its worse with the 348. Its hard to not like OEM on the 355.
