My 348 stopped running on the highway | FerrariChat
Discussion in 'Technical Q&A' started by PassionIsFerrari, Mar 4, 2006.
  1. PassionIsFerrari
    PassionIsFerrari Formula 3
    Aug 15, 2004
    2,454
    I'm freaking out! my 348 was running fine on i95 and then all of the sudden I head a high pitch sound like a turbo and a noise like a playing card hitting a fan. it was very fast and the motor shut off right after. the motor will not turn over. the starter kicks in and just spins really fast...got to be a belt...had the car towed to shelton to find out what is wrong..can it be anything else then a timing belt? car has 30.5k miles and the belts were replaced in 00' with 9k miles on it. I just would be in shock if it was a timing belt. Could it be another belt? if it was another belt would it toast the motor also or would I be ok? this is all surreal to me....after endless arguments about timing belts I just can't fathom the thought. all thoughts or opinions would be very much appreciated.
    thanks....
  2. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    I hate to diagnose over the Internet, but having experienced a catastrophic failure (on a BMW), the symptoms are identical. On my BMW, the camshaft snapped because the timing chain jumped off of the gear. Bent valves, etc. Sorry, but I think you have a major problem.
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    "High pitch sound like a turbo".
    It probably seized a bearing in the water pump or belt tensioner, then lunched the belt. I'm afraid there isn't much possibility that you DON'T have a broken t-belt and bent valves. Sorry.
  4. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    Holy cr@p... it hurts just reading this (especially since I just got off a fast highway run in the 328 five minutes ago). :(
  5. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    I'm freaking out just reading this. I have no idea about the symptoms, so I will put a vote in for it being some other problem than a broken T belt, valves, etc... Like they said in the Shawshank... "They can't take away your hope." I HOPE all is easily fixed, keep us up to date.
    BT
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    I've got a great guy up here in Birmingham who can rebuild your motor on the cheap (well, cheap isn't actually a Ferrari word).
    Honestly, it's the valves, pistons, and various seals, gaskets that are the killer for costs.
    Taking the engine out isn't actually that much of a big deal. Replacing the belt and tensioners and water pump isn't a big deal.
    Consider purchasing an existing running engine. You can swap out the water pump for $200, go with the Hill tensioners for another $450, and put on a new timing belt for less than a $100...
    ...Which will be far, far cheaper than buying new pistons ($1,000+ each), valves ($100 each times 32 valves), valve guides, and $1,500 worth of seals/gaskets (and God help ya if you snapped a crankshaft) for your existing engine.
    Sorry for your pain. I've just been through it myself.
  7. MDshore348
    MDshore348 Formula 3
    Dec 24, 2004
    2,460
    Maryland
    Darron
    sounds exactly like the time i blew a belt in my moms bmw .... damn
    unfortunately you are the example that the 5 yr 30k major service whichever first rule applies.
  8. Mike in ATL
    Mike in ATL Karting
    Nov 2, 2003
    127
    Sorry to hear about your ordeal, at least you are OK. People are nuts on the highway, I would be scared just being on the shoulder.
    So if I read your post right the belt was approx 5-6yrs old & 20K miles if thats what failed.
  9. MDshore348
    Dec 24, 2004
    2,460
    Maryland
    Darron
    let all of us 348 brothers have a moment of silence... :(
  10. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,962
    MD and NE
    Robbie
    Sorry to hear about---cross your fingers and hope for the best--you never know!!! I will say a prayer for your car tonight-that it is something simple and not a major deal...
  11. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I would guess you would need to make a quick check to see if you blew the timing belt. First if you can reach under the timing belt cover and see if the belt is there. You also might want to look under the car to see if there is a belt hanging. And if you can't do this then pull the distributor cap and have someone click the starter and see if the rotor turns. If you snapped the belt while you were running and you also turned over the motor after it went dead this proceedure won't damage the motor any more then it is now. So if the water pump bearing gave up and you heard squeeling and then the motor stopped you may have toasted the timing belt. Give it a try.
  12. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    OUCH!!!!
    Yeah I hate to say it but, I think your engine has had it. The "cards hitting a fan" sound is more than likely the valves and pistons beating the crap out of each other.
    If you wanna buy a used engine that's ready to go get ahold of Fchatter Plugzit. Unless he already sold it, he has a spare engine ready to go. Here it is in the ads section. http://www.ferrarichat.com/ferrariads/showproduct.php?product=132&sort=1&cat=13&page=6 Just plug and play.
  13. plugzit
    plugzit F1 Veteran
    7,783
    Redondo Beach, CA
    Bruce Bogart
    I feel your pain. Heard that noise in a Maserati Biturbo. $400 tow bill, many parts. Good luck-let's hope your motor just swallowed a squirrel. PM me if you need the complete motor-may be way cheaper than fixing it.
  14. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Well, I just rebuilt my top end (full valve job) on my 348 engine, and I can assure you that buying Plugzit's running motor for $7,500 is a bargain...because you can sell your blown 348 engine whole, or in parts, for $4,000.
    And $3,500 ($7.5k for Plugzit's minus $4k for your engine) is *cheap* for taking care of a blown Ferrari motor.
    Now Plugzit, what's your story? Why do you have an "extra" 348 engine?!
  15. 348SStb
    348SStb F1 Rookie
    Wow. :(
    I'm going to be taking care of that "whistling" sound I've been talking about as soon as possible.
    Sorry to hear about this. I hope your 348 comes back to life soon. Don't be too discouraged!
  16. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    The 348 doesnt have a distributor. It has coil packs. Although on a car with a dizzy,thats the quickest and easiest way to tell if you have a broken belt ;)
  17. PAP 348
    Dec 10, 2005
    100,220
    Pap
    I think so :( I will be raising the ferrari flag in my driveway at half mast today :( Hopefully not too much damage was done mobileguy :(
  18. jjstecher
    jjstecher Formula Junior
    Jan 21, 2002
    962
    Rochester Minnesota
    John Stecher
    Sorry to hear about what happened man. As grim as most people are on here about what happened I would wait to jump to conclusions until you can actually get the engine out and look at it all.
    It doesn't sound good as the turbo like noise I have no doubt was a bearing going crunch...HOWEVER I had my alternator make the same sound when the bearing in it seized up twice now. Each time that was followed by what I say could possibly sound like cards hitting the fan as the belt flops around. The car then stopped each time shortly there after due to the alternator not feeding voltage into the ignition system. To check it out just jack the car up and slide under the font of the car to the belts area and check it all out.
    Easy way to tell if you crunched the pistons is to simply drain the oil out of the crank case and check the metal content. I have never seen a busted up engine not drop off something that you cant find in the oil. Next step then would be to pull off the oil pan and take a look to see what you can see.
    Sorry to hear about it buddy...trust me I know your pain.
  19. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    I would agree with you John but, the starter spinning really fast is making me think it's the cam belt. However I hope your right and its just the alternator belt.
  20. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Yep,you are correct ernie.Its spinning over quickly because it has no compression or no timing belt opening and closing the valves. Or bent valves,cracked pistons/bent rods ect...:(
  21. SFchallenge
    SFchallenge F1 World Champ
    Jun 28, 2004
    11,945
    Sgp, KL, HK & London
    Jon Wijaya
  22. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,972
    The Cold North
    Tom
    Oh lets not rub salt in the wounds guys!! Sorry to hear about this. If there is anyway i can help please let me know.
  23. davey_jones
    davey_jones Formula Junior
    Sep 28, 2002
    781
    wherever it's sunny
    Dave
    Sorry to hear about this. Keep us posted.
    Maybe a ferrari-fund is in order - in cases of catastrophe, your brothers are there to help.
  24. jjstecher
    Jan 21, 2002
    962
    Rochester Minnesota
    John Stecher
    Ernie - I guess I should have read it a little better. You are right if the starter is spinning her real fast it probably is the t-belt but lets not give up hope and please tmobile check the alternator belt first.
    I still would wait to get the engine out and at least take a look at the t-belt before you buy a new engine. Who knows it might just be you bent a few valves and can fix it pretty easy (well not easily but for less cash than buying a new engine).
  25. dakharris
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Unlikely. A whole engine may sell at a discount to removing and completely disassembling an entire engine. In many cases, when valves hit pistons, pieces come off that score the cylinder wall. This necessitates re-sleeving the engine. The whole thing has to come apart.
    Generally, when you do such a major overhaul, you do many things that aren't normally done. This is an opportunity to polish and bore things to improve performance. Since the cost of parts is already ridiculous, upgrading isn't that big a deal. The only positive angle on this is to make it an opportunity to upgrade performance. Otherwise, there's no way around the fact that this sucks.
