New Owner's Diary: Part 2 | FerrariChat
Discussion in '308/328' started by Bullfighter, Mar 6, 2006.
  1. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,601
    Gates Mills, Ohio
    Jon
    Another long post bound to bore the old timers here with plenty of "well duh" insights, but hopefully first-time and prospective Ferrari owners will get something out of it.
    Two weeks now, and my new-to-me-'87 328 GTS has continued to make all the right noises and get more fun to drive. No major metal parts left behind on the freeway, and the 'timid new owner desperately seeking clutch pedal' feeling is giving way to the 'hell yeah, these pedals and gears are brilliantly located!" feeling.
    1. Baptism: I waited a week till after delivery to wash the car. First, black metallic doesn't show dust as plainly as black does, and the car was in a clean enclosed trailer for the NC-CA trip so it was fairly clearn to start. But, more importantly I figured I'd turn the hose on it and the whole thing would go up in display of sparks and I'd later find guppies in the distributor caps.
    As I described last time, my passenger window was dead on arrival and the driver's door courtesy light switch was working part time. A trip over to Gary Bobileff's put that right (dirty contacts in the window switch, new switch installed on door post for the courtesy lights) and, while there, he provided some tips on washing these cars. Simple stuff: don't get it real wet, cover the engine bay inside - esp. the electrical bits, and don't wash it more often than you have to. I put a towel over the cold engine and used the "mist" setting on my hose nozzle, relying mostly on my sheepskin wash mitt. Washing your own first Ferrari is about the coolest thing you're ever going to do on your driveway. For the big detailing this spring I'll have it done somewhere, but for the occasional rinse, the DIY approach really helps you get to know and appreciate the car. Also, it must make you look more down to earth than the elitist Ferrari owners who have Jeeves do it, right? Pininfarina must have had a bottle of the best wine to celebrate this design when it was done, just as the Ferrari factory guys did while they were building it.
    I didn't have the proper solutions on hand to dress the top and spoiler, so those will wait till next time. They look very good but not great right now. Note to self: find out what Charness uses. After washing I took a short drive to finish the drying process. (Potential concern: "Sorry officer, I was trying to get all the moisture out of the undercarriage...")
    2. Real drive: Saturday was flawless in San Diego (none of that brutal 50-degree wind chill we've been having...) and time for an extended drive. When you get the car at first, you don't trust it. It's older, and after reading about grenaded engines on F-Chat it seems stupid to actually drive the thing when it's looking perfectly gorgeous in your garage. Wrong. Stick the key in, turn it, let the oil pressure build, let the idle settle and back out. 2nd gear is verboten (in my car at least) till the oil temp gauge moves. I don't know what gear oil is in it, but it's new and I don't feel like changing it for kicks so in it stays till the next service later this year.
    On an extended cruise, I see no other Ferraris, but a nice Bentley GT on La Jolla Scenic Drive (overlooks the ocean from the height of La Jolla) and then onto the freeway. Speedo says -- well, says I'm moving with a proper sense of uh, urgency. Yeah, that's it. Nice silver 330i is hanging with me and I notice that whatever I do with the accelerator I seem to have a pack of cars around me. California weekend traffic? Groupies? I don't see how the rosso TR guys can actually drive anywhere without the roving cluster. My car's a lot more subtle and I'm still going to contact Q branch about some front-mounted bumper missiles.
    10 minutes into the drive all gauges are reading happy, including coolant, and I'm getting my first tubi lessons at 6000 rpm; gearbox is shifting beautifully, now that the owner is getting his act together.
    Big blind spots in a 328 - those rear quarter grilles look they would help but - they don't. Mostly Pininfarina put them there to attract women. Flying buttress design looks great, requires some adjustment and reliance on the tiny side-mounted mirror. Fortunately the factory fitted the car with a long narrow pedal in the right part of the driver's footwell that moves all cars rearward at a decent clip for safe passing. Off on I-15 and then onto Pomerado - a 45mph road through eucalpytus that's the back way to my house. The gated gearbox actually feels normal; 2nd gear is easy and strong. Won't be using 5th again on these back roads.
    Ground clearance in a 328 isn't bad. I avoid a ramp on near my accountant's office on the way back because (1) it looks cracked and steep and (2) my accountant's office is a complete bore and St. Enzo would curse me with a leak for taking his car there.
    3. Fill up: This car inhales gas. Granted, I don't really care because it's a weekend driver, and I feel like a celeb when I pull into Mobil. I'm still single so I plan to fill up 2 gallons at a time every other day or so. I don't trust the auto shut off, so on level ground it looks like I'm at 1/3, which ought to be 6 gallons in those 18-gallon (total) tanks, so I add 10 of the high octane stuff and shut if off myself. Surprisingly, getting gas proves to be a normal experience. The car didn't explode, people didn't run for cover, and the prices didn't auto-adjust to $8/gallon when a Ferrari parked alongside the pump. Maybe a faulty sensor in the pavement...
    4. Top off: A GTS, top removed, going at -- uh, well, moving with the aforementioned sense of urgency -- is a delight, even with the windows down. The top is a hassle to stow under its cover because that fits too tight. So I end up unfastening the bottom snaps and tucking it behind with the top ones secured. The latches are nicely done, and thing is light and easy. More importantly, I feel comfortably shielded from view in the cockpit. It's a lot more private than a full spider, and frankly the car looks even better with the top stowed.
    5. Not your father's Lexus: There's always something. Major stuff you hope will never happen, minor stuff that needs doing and "some day" stuff that will bug you and no one else. Everything's working now, but minor stuff included replacing a missing rubber part behind the rear quarter grille and figuring out how to secure the dash mat after cleaning up the gooey mess from the old velcro sticker that came with the car. The car has a bit of a "petro-chemical" smell to it, which could either be charming or a problem. No visible leaks, and Gary said the cars aren't exactly odorless right after an extensive servicing. Funny, my Jeep is. But something to keep an eye - or nose - on. The brakes have a minor squeal to them, but records say the rotors were turned recently and the pads (Porterfield) look OK. Jot all this down for the first oil change/inspection here in San Diego.
    6. Oil check: Modern cars don't burn oil after break in, Ferrari's supposedly do. Owner's Manual says wait 15 min then check, so I do. Note to new owners who don't want to look like idiots: the elegant handle on the dipstick is actually metal, and 15 minutes in the engine bay after running ain't gonna cool it off. Keep a shop rag nearby and use it to navigate your hand around all the sexy but hot engine parts while you're checking.
    So far, so good. Even when I'm not driving it, pulling into the garage and having those four tail lights peering out at you is a very good thing. Was hoping to see another F-car driver for some silly reason - maybe the fraternity thing - but that didn't happen. Well, it almost did. Grocery run afterwards - switched to the Jeep for that, and of course a gleaming rosso F355B scoots up to the light across from me.
    Ah, maybe next time. ;)
    (First part here: http://www.ferrarichat.com/forum/showthread.php?t=95718, for background info)
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    I had that squeal on my 348 even with nearly new stock pads. I installed the Axxis MetalMaster pads (about $44 for a pair) and no more squeal even 6,000 miles later (also, almost no brake dust).
    I suspect that if the pads aren't set properly when first installed that you will continue to have that squeal until you change pads.
    Now, as for that smell...replace the rubber seal inside the gas cap/tank filler neck. It should be cheap to do, and if that fixes your problem, all the better.
  3. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Brilliant storytelling! I enjoyed Part 2 even more than Part 1. Just fantastic!!!
  4. Bullfighter
    Jan 26, 2005
    22,601
    Gates Mills, Ohio
    Jon
    The fuel filler neck hose was replaced last month. Maybe it's the seal inside the cap itself? Maybe I need to call Daniel...
  5. Vlad328
    Vlad328 Formula Junior
    Mar 16, 2004
    279
    New Orleans, LA
    Vladimir Zuzukin
    Thanks Bullfighter. You make us prospective owners feel like we're right there with you in the car. Great visual storytelling.
  6. ferraripete
    ferraripete F1 World Champ
    i'm glad to hear how much you are enjoying your car. not only a great starter ferrari...but a great keeper! they simply do not make them any prettier than your car today! a car never to be mistaken for anything but a ferrari.
    jon, we should get together for a drive soon...
    pcb
  7. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,295
    Colorado
    Dave
    Jon,
    You are well on your way. One thing that separates Ferraris from mere mortal cars is that cleaning them is a joy, especially since they are pretty small. Also, you will get to know every little idiosyncracy of the car's build when washing and waxing. You will find panel fit is not Lexus-like. The 2 sides will vary from each other a little bit. You will likely find little waves in the metal, this is normal. No 2 are truly alike.
    I am a bit surprised someone has turned the rotors already. Normally, at least with stock pads, these do not wear appreciably. My 20K car has the originals and only has some very shallow lines, still with original pads. I have tracked it some as well. It is thought that once rotors are turned, heat will build quicker due to reduced mass and warping is much more likely to happen. For street driving, this will probably not be an issue.
    You will get over the fear of taking long drives. Unless they have deferred mainenance, these cars are pretty bullet proof. The little motor in the back just likes to sing all day without missing a beat. I've put 13K on my current 328 with no issues. This is pretty typical.
    Enjoy,
    Dave
    Enjoy,
    DAve
  8. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    Good write up (again). The quirks are something that take a little getting used to, but these cars are much better built and far more reliable than my old 58 Alfa. Also, in the 348 the 25 gallon tank will only take 16 gallons to fill up when then gauge is reading near empty, so there is a large reserve in the 348. Don't know if the 328 is the same. Just for fun, you should fill it up when you have 1/4 reading to see how much gas is left. Keep driving it, I know the weather is San Diego can rarely be used as an excuse for not getting out. We had some S.D. like weather here in Palm Beach this past week, and it was great!
    :D
    BT
  9. Bullfighter
    Jan 26, 2005
    22,601
    Gates Mills, Ohio
    Jon
    True - the first time I saw a 328 I was sure it had been wrecked at some point. Then a second one. Then I figured out it was normal. This one does have its share of waviness, and it's a dark color which may emphasize it even more. Call it character. If I'd wanted a Lexus...
    Rotors were turned, and pads replaced a few times, because this car was tracked back in Atlanta by another F-Chat'er. I suspect next time I'll replace the rotors and get the best pads for street use.
    Peter - Thank you, and PM sent!
  10. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
  11. MARQ
    MARQ Formula 3
    Feb 9, 2002
    1,924
    East Coast US
    Marq
    A great follow-up to Part 1. Most enjoyable! Keep it comin' as I'm reliving the initial days after the purchase of my 328 through your write-up. Thanks for sharing.
  12. desmomini
    desmomini F1 Rookie
    4,111
    Upstate SC
    Jeff
    Wow, I was starting to feel guilty for not posting more of my initial impressions of 328 ownership. You've taken a great burden off of me. Now I can be a lazy guy and just sit here and say, "Yep, me too!"
  13. 308 GTB
    308 GTB F1 World Champ
    11,730
    New Jersey
    Barry Wolinsky
    Once again, Jon, a great diary. You're obviously enjoying the new ownership. Funny thing is, that feeling never diminishes with the passage of time.
    You've yet to experience the "Walter Mitty moments." Or maybe you alrerady have.
    Barry
  14. LT-1
    LT-1 Karting
    May 13, 2005
    238
    San Francisco
    Robert
    I remember,very clearly, the day I stumbled across that little jewel of knowledge.
    Great write up.
  15. 308 GTB
    11,730
    New Jersey
    Barry Wolinsky
    Rev her up to 8500! We're going through! The pounding of the cylinders increased: ta-pocketa-pocketa-pocketa-pocketa-pocketa. Now, accelerating out of the apex of the final turn, I head for the finish line......
  16. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    What are "Walter Mitty moments."?
    BT
  17. AJS328
    AJS328 F1 Veteran
    Apr 23, 2003
    7,520
    New Jersey
    Augustine Staino
    This all brings back wonderful memories. :)
  18. MARQ
    MARQ Formula 3
    Feb 9, 2002
    1,924
    East Coast US
    Marq
    Memories that are easily relived, if you care to! Go get another, or two....or three.
  19. Bullfighter
    Jan 26, 2005
    22,601
    Gates Mills, Ohio
    Jon
    Maybe they're "Michael Schumacher" moments. I've had a couple of brief episodes... haven't wanted to push things in a new-to-me-old-car with NC temporary tags.
    But let's just say there's a lady in a white minivan who now knows who's boss.
  20. Cajun
    Cajun Formula 3
    Mar 20, 2004
    1,618
    Da BY-U
    MJG
    Nice write up.
    Your car is GORGEOUS!!!
  21. 308 GTB
    11,730
    New Jersey
    Barry Wolinsky
    Bill,
    "The Secret Life of Walter Mitty" is a short story by James Thurber. There was a 1940s movie by the same name starring Danny Kaye based on it. Here's a link to the story. It makes a nice read:
    http://www.geocities.com/SoHo/Cafe/6821/thurber.html
    (Sorry for the literary diversion here, Jon. I was so involved in my reverie that I misspelled "already.")
    Barry
  22. AJS328
    AJS328 F1 Veteran
    Apr 23, 2003
    7,520
    New Jersey
    Augustine Staino
    Oh, okay. So I can borrow yours then? Excellent! I'll pick it up Friday. ;)
  23. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,962
    MD and NE
    Robbie
    Well worth the read--thanks Jon!!!!!!
  24. 134282
    134282 Four Time F1 World Champ
    40,647
    California
    Carbon McCoy
    Jon - great read...!!! Thank you very much for sharing, that was a wonderful, visual story. I hope you continue with these "diary entries"...
  25. branko
    branko F1 Rookie
    Mar 17, 2003
    3,710
    Birmingham, Alabama
    Branko Medenica
    Yes, I learned that one the hard way. In fact, I now keep a leather glove handy just for checking the oil. Great thread! Looking forward to #3.
