97 355 5.2, Power Steering Fluid & Plugs | FerrariChat
Discussion in '348/355' started by Gary Logan, Apr 15, 2012.
  1. Gary Logan
    Gary Logan Karting
    Dec 19, 2009
    54
    West Vancouver, BC
    Gary Logan
    Gentlemen: Just finishing up the spring tune-up including all fluids. Noticed my power steering fluid, measured hot, is down a bit. I would like to top it up but unable to find a product recommended for the engine other than what is in the manual. What are you guys using please?
    Also, plugs, NGK R PMR7A or 8A, a little cooler? Lastly, having difficulty getting the boot off the plugs. There is a beige plastic piece over the top of the plug with a wire across the top, similar to an electrical coupling to stop it from loosening. I have pulled quite hard to try to remove the fitting but unable to move it. I am thinking the small wire has to be pulled up or pushed off to remove the tension on the top of the plug? Alternatively, they may just have a "heavy duty" seal on the plug for moisture protection.
    Thoughts on the above appreciated.
    Gary
  2. f355spider
    f355spider F1 World Champ
    18,045
    Hi Gary,
    I did not get your picture via email, perhaps you can post it here? The wire and plug extension does not sound like the oem set up....but a picture would help us to confirm it.
  3. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Gary,
    I have a 99 355 and just replaced my plugs. There was no wire holding it in place, yes they are a little tight. Maybe you have some aftermarket setup. Like f355spider said a pic would help.
  4. Gary Logan
    Gary Logan Karting
    Dec 19, 2009
    54
    West Vancouver, BC
    Gary Logan
    Brought to my attention by a very knowledgable 355 owner, Dave Handa. I am looking at the fuel injectors not the ignition wires. I apologize for the poor post and lack of attention. I am capable of much more.
    Gary
  5. BLAMPEE
    BLAMPEE Man Card Status: Never Issued
    Dave Handa is da MAN! :D
