355 - ‘97 355 misfire | FerrariChat
355 ‘97 355 misfire
Discussion in '348/355' started by MartinPO, Feb 11, 2024.
  1. MartinPO
    MartinPO Rookie
    Aug 28, 2016
    31
    Port Orange FL
    Martin Clark
    I wonder if anyone has experienced this please? 1997, 5.2 misfire on idle after the coldstart ends. It will miss for 40 or so seconds, fire on all cylinders for about five seconds then start missing again. Under load while driving, it runs and pulls fine with no miss.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    This is what you should do, from easy to hard.
    1. Read the code to see if there is a specific cylinder misfiring. Change that plug.
    2. Perform compression test with warm engine, find the offending cylinder
    3. Check fuel pressure at the rails
    4. Perform smoke test for the intake
    5. Perform smoke test for the exhaust
    6. Read live data from O2 sensors
    7. Change all plugs
    8. Change ignition wires
    9. Change ignition coils
    10. Clean injectors
    Did any work just get done on this car? Like an engine out?
    19633500GT and Qavion like this.
  3. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,895
    Richmond
    Pete
    Is it throwing a CEL or are you judging by ear?
    Qavion likes this.
  4. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,230
    CT
    John Kreskovsky
    Fuel delivery would be my guess.
  5. Qavion
    Qavion F1 World Champ
    14,312
    Ian Riddell
    Would this suggest a problem with closed loop operation (i.e. a sensor or evap system issue) or is perhaps heat causing an issue? At wide open throttle some sensors are not used, so perhaps that’s why the car is ok under load.
    Can you identify which bank the misfire is on? Unfortunately, with a 5.2, you’re limited with respect to what you can swap between banks for diagnosis purposes. Do you have a scanner?
    Are your CEL and Slow Down lights working?
  6. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    Grab your Long term fuel trims on each bank while plugged in.
  7. MartinPO
    MartinPO Rookie
    Aug 28, 2016
    31
    Port Orange FL
    Martin Clark
    Thank you for your help! 7, 8, 10, all performed, I believe it's been misfiring since an engine out.
  8. MartinPO
    MartinPO Rookie
    Aug 28, 2016
    31
    Port Orange FL
    Martin Clark
    Very possibly a sensor I feel, thank you. Both CEL and SDL lights work, but are not activated with this fault. Scanning will be next, thank you for your input!
  9. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,895
    Richmond
    Pete
    If no CEL, it might be the ITB's out of sync and not a misfire. I'd use an IR thermometer and check the temp at each exhaust flange and see if you actually have a cylinder missing or if it's just a choppy idle.
    MartinPO likes this.
  10. squid
    squid Karting
    Oct 5, 2006
    153
    Check for codes. On my 1995 cleaning the MAFs cured the cold weather studder.
