97 456 GTA - Price Estimate for Maintenance Help | FerrariChat
Discussion in '456/550/575' started by Giulio Capolino, Jan 7, 2021.
Tags:
  1. Giulio Capolino
    Oct 13, 2020
    19
    Hello everyone,
    I hope you are all healthy and safe! This fall and winter, I have been caring for a relative's 1997 456 GTA and, despite a few problems with the battery (replaced) and the pop-up lights (one did not go up - tried to switch the relays but that didn't do it. Likely a larger wiring issue), the car seemed to run smoothly. I took it for drives and never had problems turning on (battery was always plugged in when in the garage) and the only thing I really noticed is that the hood would remain a bit hot after each drive (which I considered normal).
    I am not exactly sure how long has it been since its last full maintenance, but since I soon have to hand it back to my relative, I decided to bring it in to a supercar shop to do a checkup and see if they think there's anything that could use a refreshening. To my surprise, they got back to me with a large list of crazy expensive fixes that I definitely did not anticipate. I would love to hear from you if this feels like a fairly legit list+pricing, or if you feel the smell of a ripoff...
    As I said, the car runs smoothly and has a brand new battery. Freon is also new and the AC was working fine (did not try the heater since I was in FL). Never in 4 months of me keeping it have I noticed any leaking signs on the floor of the garage. Here's the list:
    1. The vehicle currently over heats because the coolant leaks out from the hoses which run underneath the intake plenum. We recommend changing all the coolant hoses. $2,987.33 + tax.
    2. There are several engine oil leaks, all filters and fluids should be changed, all accessory and timing belts, valve cover gaskets and cam seals. $13,400 + tax.
    3. There is a large leak from the rear shocks load leveling system and they require replacement.$8,664.96 + tax.
    4. The tires are dated 2012 and should be replaced and a four wheel alignment performed. $2,195 + tax.
    5. The brake hoses are original and need to be replaced. $1,695 + tax.
    6. The power steering pump is leaking and is insanely expensive so we are looking for rebuild options. Will remove and advise on pricing when established.
    7. The engine mounts are sagging and need replacement. $1750 + tax.
    8. The wiper arms are misaligned and wipers streaking. Windshield washer fluid sprayers / nozzles are broken. $250 + tax for new wipers and repairs.
    9. There is no heat and we need to double check once the coolant leak is solved.
    10. The drivers flip up headlight is not flipping up and will need to diagnose the issues.
    11. The protective shield underneath is broken. $1,709 + tax.
    12. Front rotors are heavily rusted and would recommend replacing them. $1,576 + tax.
    What do you guys think? I appreciate all the help in advance!
    Giulio
  2. Ferrari55whoa
    Ferrari55whoa F1 Rookie
    3,294
    Los Gatos, CA
    Eric
    Wowsers....just fast math is that $34k-ish?
    Out of curiosity how many total miles on the car?
    That gives me a tummy ache.
  3. Giulio Capolino
    Oct 13, 2020
    19
    Total miles is about 7k. Very, very little..
  4. tazandjan
    39,023
    List sounds reasonable, prices are outrageous. Find another shop.
    tantumaude and Mirek like this.
  5. Mirek
    Mirek Formula 3
    1,463
    Los Angeles, CA
    Mirek
    Prices are way out of whack.
    Just look at #3 for example.
  6. Davidspop
    Davidspop Formula Junior
    Dec 23, 2019
    400
    Lance Malcolm
    The list is not unreasonable, but if parts/labor at a shop can be ridiculous.. as Mirek points out, the rear suspension... is suspect. I bought my 456 in July, and was advised the rear suspension needed repair, shocks rebuilt, and accumulators replaced... quote was not much less than what you received. I bought replacement accumulators for around $200... replaced the speed sensor for around $200 in parts, installed the parts myself and have no other issues... so an $8000 quote was actually fixed for 400 in parts and a couple hours of my time.....if you cannot do the labor yourself, fully understand as you gotta want to DYI on these cars... but I'd find another shop.
  7. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    This is pretty much a complete shopping list of items associated with the model. Can the motor mounts need replacing with 575 mounts? Yes. But maybe not this minute. Can the coolant hoses of the intakes age and leak because it gets really hot up there? Yep, well known. Is today the day? If there has been nothing on the garage floor, probably not! Did the car overheat when you drove it? They sure seem to think that it is. Roughly, I'd say you are getting the whole "how to restore a 456" list. And priced pretty damn high at that!! Those are not nice people at that shop.
    "In the first 20 minutes of a poker game, you don't know who the mark is, you're the mark!"
  8. ttforcefed
    ttforcefed F1 World Champ
    19,218
    i just got quoted 2200 for a shock on my 456. im going with a rebuilt one for 800
  9. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    Delta Vee on the rebuild? And who quoted a new one, I thought they were NLA.
  10. ttforcefed
    19,218
    yes pretty sure delta vee. i did not make the call myself, and independent quoted it for me. From the factory there was a lead time so it makes sense they are not in stock
  11. Salami
    Salami Karting
    Oct 31, 2020
    219
    Oregon
    Funny, that long list and no mention of cam belts. Definitely need a different shop. That one item could lead to catastrophic engine kaboom, and it could happen any time. The rest seems normal to me, welcome to Ferrari prices. A different shop could slash all those in half though and still make a profit.
    white out likes this.
  12. ttforcefed
    19,218
    The car’s valuations doesnt justify that repair bill… That’s the problem, even if you cut that bill in half it’s a tough pill to swallow
  13. tazandjan
    39,023
    Timing belts are cambelts.
  14. Mirek
    Mirek Formula 3
    1,463
    Los Angeles, CA
    Mirek
    The list also does not include replacement of all of the degrading rubber bits in and around the gas tank and fuel pumps - which most likely has been occurring and can cause subsequent expensive misdiagnosis as it goes into the engine (fuel pump replacement, injector flushing, fuel filter replace, etc....)
    How are the door seals ?
  15. ttforcefed
    19,218
  16. papou
    papou Formula 3
    1,716
    plantation Fla
    daniel ross
    Bilstein UK do a rebuild for $200, very quick turnaround,DeltaVee great work if you can be without
    the car at Rob’s convince not yours.
  17. Salami
    Salami Karting
    Oct 31, 2020
    219
    Oregon
    Oops, thought I read it well enough, but I did not.
  18. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    Item # 2 on his list included all belts.....a mere $13.4k +
  19. Giulio Capolino
    Oct 13, 2020
    19
    Thank you guys, this is wonderful info. I will definitely take this into account. The thing that throws me off the most is that the car has been driven by me fairly frequently these last 5 months (at least once a week) and never had a problem except battery (known 456 problem) - the fact that they're asking for so much for a perfectly working car makes me worried about what to think and whether all those repairs are accurate/needed or not. I did not take the car to track so I cannot tell you if the max speed was there or not, but it seemed like it was running pretty smoothly overall..
  20. rviani
    rviani Karting
    Jun 22, 2005
    81
    NJ
    Ron Viani
    I purchased a 456gt (95) in 2000 with 7000mi and it currently has about 27000. I agree with "laserguru' and would offer the follwing comments:
    1) Coolant hoses are a tough call with no signs of leakage on your driveway they are likely OK. However failures tend to be dramatic and will leave you immobile. I changed mine in 2002 at 16000 mi and they appeared fine. I would be suspicious that overheating and no heat (despite AC working) might simply be due to low coolant / air in the system
    2) Changing fluids is reasonable. My car has always had very minor oil leaks (not enough to leave a puddle on the garage floor) which I elect to leave alone and have not gotten worse. I changed cam belts in 2010 at about 24000 mi. These were the original belts and appeared in perfect shape. Many people on this list will be horrified that I operated with the same belts for 15 years but my opinion is these degrade with mileage but not significantly with age.
    3) I also had a leaking shock which was repaired by Bilsten for free (a long story) rebuilding yours should offer a much cheaper solution.
    4) Tires are also a tough call 10 years is usually considered the maximum you should go regardless of mileage. However depending on how they were stored and how you will use them a visual check for degradation may be sufficient.
    5) I don't know anyone who changes brake hoses as a maintenance item. Changing brake fluid is a good idea however.
    6) My power steering pump was leaking around the shaft seal and was rebuilt by the manufacturer (ZF Industries) in 2000 for $300. It is the same as a VW / Audi pump # 054 145 165 LX and was done through an outfit named Power Steering Specialists in Westerville Ohio. Not sure if they still exist.
    7) Engine mounts seem to be a common problem - not sure what "sagging" means however - mine have never been changed and appear fine.
    8) $250 for wipers seems well "over the top"
    9) see above #1
    10) I have had this happen several times on both sides. The solution has been to carefully lubricate the external moving parts.
    11) There should be " some way" to repair this - I have not had the problem
    12) Rotors rust from disuse - they should be able to be machined and reused unless they are less than the minimum thickness after machining which seems unlikely given the low mileage.
    Just my opinion - hope this helps
  21. Giulio Capolino
    Oct 13, 2020
    19
    This helps a ton, absolutely. And for a full picture, the car has approximately 7000 miles and has always been stored in garages.
  22. rviani
    rviani Karting
    Jun 22, 2005
    81
    NJ
    Ron Viani
    Forgot to mention that my car also developed a major leak from the radiator in 2002 - apparently not an unusual problem for these cars. I removed the radiator (a bit more troublesome than I anticipated) and took it to an ordinary radiator repair shop, Not sure what the actual cause was but they repaired it for a grand total of $56 and it has been OK since. If you are actually loosing coolant a pressure check of the system might be a good idea..
  23. Qavion
    Qavion F1 World Champ
    13,857
    Ian Riddell
    Are brake rotors suitable for vapour blasting? It's amazing how gentle but effective this is on metal parts. They look like new after treatment.
