355 - 97 Spider Window Switches are Backwards | FerrariChat
355 97 Spider Window Switches are Backwards
Discussion in '348/355' started by C-speed, Aug 5, 2022.
  1. C-speed
    C-speed Karting
    Jul 13, 2022
    171
    Crescent Kao
    Hello!
    I have a strange issue with my window switches on the driver side. I just bought a 97 spider (US) and the left switch controls the passenger window and the right switch controls the driver. I thought this was odd so I consulted the owners manual and it shows that indeed, they are backwards!
    Is it a simple case of swapping the plugs behind the door panel or swapping the switches around?
    Thanks.
  2. Mike Morrissey
    Mike Morrissey Formula 3
    1,143
    Denver, Colorado
    Mike Morrissey
    The bezel is held in with a tab on each side and was likely replaced at some point, as the tabs tend to break. The wiring connectors most likely were reversed at one point. The diagram shows the switches to be equal to each other and would allow you to leave them in the bezel positions and simply reverse the harness connectors.
    308 GTB likes this.
  3. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    Yes, just pop them out and flip them around, should be fine
  4. C-speed
    C-speed Karting
    Jul 13, 2022
    171
    Crescent Kao
    Thanks for all the help guys! I took the door panel off and switched the plugs around. All better now! YAY!
    Carmellini, Qavion and Mike Morrissey like this.
