98 355 Oil Consumption - Valves? Help! | FerrariChat
Discussion in 'Technical Q&A' started by Ricard, Jul 9, 2005.
  1. Ricard
    Ricard Formula Junior
    Jan 23, 2004
    867
    Donington Park
    Richard C
    Hi
    I recently got an amazing deal on a 98 355 Berlinetta (no chance to have an inspection!) ... I thought about it long and hard before taking the plunge and, given the amazing price I got it for, risked it. I figured the cosmentic condition of the car, its history and the price gave me room for a serious-ish maintenence bill if/when the need arose (i.e. when I discovered why it was so cheap!).
    Well, I think I have found it...It appears to be consuming 2L of oil per 100km. That is 10x the official figure of 2L per 1000km max. There are no visible leaks and, strangely, there is no exhaust smoke (a little white vapour from RHS tailpipe at start up but no particles in it and soon vanishes, figured it was just water from the cats?). Looks like a relatively new muffler is on the car as I easily polished the inside of the tailpipes and after 100km the inside of them is a light grey/white uniform colour both sides.
    I think that I have a valve guide problem, the car is booked in for full service including belts on July 25th - so the leak down test will answer the question then and, with the engine out, I guess I'll get whatever done.
    My questions are:
    1) Given the facts above can any of you offer advice as to what the problem might be - valve guides (possible but unlikely on 98 car) or what else?
    2) What will the remedy entail?
    3) Any idea of rough cost to remedy (I have read $135x40 for valves - would it also need heads, or given the oil consumption level could it just be a couple of valves)?
    4) Just how high is the above oil consumption, should I leave the car in the garage until the service (it drives fine, sounds fine, feels fine, no visible problems apart from the oil disappearing!)?
    The car originally came from Germany, has done about 19,000m (which looks genuine given the interior condition and agrees with the complete annual road tax record), has not been used for the last couple of winters and has only done about 1500km in the last year. It's last service was 4 years ago when the belts were done, this isnt a problem regarding the mileage but is obviously an issue re-lack of annual services. Hence my booking it in for a full service now. Having said all that the car appears to be in excellent shape, responsiveness of engine, smooth throttle feel, excellent gear selection etc.
    I am a bit of a worrier and am not looking forward to the wait between now and the end of the month, any ideas would be gratefully appreciated!
    Many thanks, great community...deep breath...
    ps.Just checked, Assembly number indicates early 98 (a lot earlier than steel valves) more evidence I guess.
  2. Ricard
    Jan 23, 2004
    867
    Donington Park
    Richard C
    OK having read some more I think I can answer my own questions to save you guys doing the same. If you can add anything then please do.
    a) Early 98 with this heavy oil consumption points at valve guide problem most likely.
    b) Oil consumption is high but not terminal, having said that as the engine is running sweet now apart from oil issue, dont drive it before service to save any other problems occuring.
    Cost of replacement is approx $14000 (£8000) including main service/belts.
    Car will be fine after - if valves replaced with steel ones.
    About right?
  3. matkat
    matkat Formula 3
    Mar 18, 2003
    1,840
    Scotland
    Dave McGuire
    The only comment I can give You is in reference to the white powder on the exhausts,this was covered previously on the board and points to the "Cats" breaking down sorry to be the bringer of bad news but if My memory serves Me correct they are very expensive but the goodish news is They do have(I think)an eight Year Ferrari guarantee so fingers crossed You are within the period.
    Dave Mc
  4. Ricard
    Jan 23, 2004
    867
    Donington Park
    Richard C
    Thanks for that! :) There isnt any real "powder" that wipes off, so I guess its just starting (does look like ceramic coating though - maybe something for next year) however done a search and the Fuchs metal cat insert seems best option and price cool so thats least of my worries.
    One other question, should the oil level be read when the engine is hot or cold? I imagine cold but read somewhere that level should be between min and max when hot...it helps to talk, thanks guys.
  5. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Are you sure your measuring the oil quantity correctly? 2 liters in 100Km? Lets see here, a liter is just over a quart, and 100Km is about 62 miles, so, a quart of oil in about 30 miles? That car would have to smoke something awful I would think. The worst I have ever had personally was a Chevy that burned a quart in about 75 to 100 miles, and it layed out a constant trail behind it, as well as fouled plugs. The last bad car I had was a MB 300E that was using a quart in 400 miles, and it would smoke at long intersections. I just would imagine that valve guides that worn and allowing that volume of oil loss would smoke noticably on a hard downshift with high vacuum on the intakes.
    In the ensuing days before your service, perhaps a few oil changes with some strong detergent oil may eleviate some of the trouble. On that MB, I used Gunk engine flush (kerosene?), changed the oil/filter, and then never added oil, but drained and changed both oil/filter after it was down a quart, and it went right up to 3000 mile oil changes with no oil consumption within two oil/filter changes. Probably the rings were dirty from poor service by the previous owner.
  6. mondial86
    mondial86 Formula Junior
    Nov 1, 2003
    298
    MA
    David Holmes
    As I read your post I wondered if you are checking your oil correctly and when I saw your above post I was right ,you are not sure about the 355 oil checking procedure!This is how it is done (all in the Manuel) Run the car until it is good and hot ,drive it for 15 minutes ,get it good and hot.Shut it off on level ground ,open engine cover ,with rag in hand remove oil cap ,wipe it off ,put it back in ,remove it and look at the level!!You can screw the cap in ,or not .by not screwing in the cap you will see a lower reading ,just do it the same way each time so your readings are consistent
    I check my oil every time I use my car and I have a 1995 355 and use very Little oil not even a qrt.. between oil changes. For your interest I just looked at the COLD oil level ,the car has not been run for 5 days and you can not see any oil on the dip stick. none it is dry!Go run your car and check the oil the right way and let us know what you have!
    If you have been adding oil because you have been checking the car cold than you need to get it out(THE EXTRA OIL) and start all over again too much oil in a 355 or any car is not a good thing!
    DAVID
  7. Ricard
    Jan 23, 2004
    867
    Donington Park
    Richard C
    Thanks for the above. I have been thinking the same myself, the car feels fine in every way except the vanishing oil, I was foxed by the lack of smoke. I have stood there looking at the oil filler cap and trying, praying that i was doing something wrong when it just dawned on me, "dry sump", "header tank" ... I think far too much and have such an active imagination, this car was such a bargain that I am subconciously searching for "whats wrong" ... I am measuring the oil level cold and just found the right bit in the handbook!
    I REALLY should know better having raced/mechaniced my own single seaters. Now all I have to be before I start it again is remove all the excess Shell 5w40 oil that I have stuck in! little bit of knowledge etc...thanks for your advice guys, got there in the end. I'll carry on the search for whats wrong with it ;)
    Thanks a lot David, you posted just as I did, so didnt read your post before the above, I feel a REAL idiot. I looked at the handbook before hand but its so long I initially only saw the first bit about fluid amounts and it saying the distance between marks is about 2L. What a relief, at least i'm a happy idiot now :) Rookie is the right word, or perhaps nervous ned!
  8. mondial86
    Nov 1, 2003
    298
    MA
    David Holmes
    Glad to help!
    DAVID
  9. f355spider
    f355spider F1 World Champ
    18,045
    So, was this just a case of overfilled oil? What is the build date on this car? High oil consumption can be masked at the tailpipe by the efficiency of the catalytic converter.
  10. Ricard
    Jan 23, 2004
    867
    Donington Park
    Richard C
    Believed high oil rate was due to my not measuring the level correctly, i.e. the oil is still in there!!!
    The Assembly number is early enough in 98 to be pre-Steel valve guides though - so there is the chance of that issue cropping up, i'll know more after the service at months end.
    I will drain down this week & report back. :)
  11. f355spider
    18,045
    Just remember to check the oil hot, and right after shutdown.
  12. 348SStb
    348SStb F1 Rookie
    Indeed, checking the oil level in a Ferrari is not like checking the oil in most other cars.
    You need to check it after the engine is at operating temperature (been running for 20 minutes or more).
    You need to check it IMMEDIATELY upon shutting off the engine. Some even say you should do it with the engine running.
    Sorry to post information that was already covered, but I wanted to make it crystal clear to anyone else who might be reading! :)
    Orginal poster -- I'd have those valve guides analyzed when the engine comes out of the car in a few weeks.
  13. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    I checked the oil in my 355 for the first time since I've owned it a few days ago...it just doesn't use any! Anyway....I worked out that it takes 2 mins after shutting down the engine before the reading on the dipstick starts to change...so there's no SUPER hurry in doing so. However, the difference in level can appear to change by a litre between the oil being warm and properly hot. Make sure the engine oil is at full operating temperature when checking the oil. Strangely, this really means you can't check it accurately before a drive, you have to check it after.
