'98 550 on Copart | Page 2 | FerrariChat
'98 550 on Copart
Discussion in '456/550/575' started by 4re Nut, Jan 18, 2012.
  1. niftyfivefifty
    niftyfivefifty Formula Junior
    366
    PacNW
    It appears it does have a clean title, and no accidents reported. I will run a Carfax next.
  2. rhern213
    rhern213 Formula Junior
    Jan 8, 2021
    576
    Miami, FL
    Richel
    Total loss but clean title huh? My Florida buddies sure know all the tricks.
    Ferrari55whoa likes this.
  3. OrmondStar
    OrmondStar Karting
    156
    Lake Mary, FL
    Richard
    Perfect example of “buying the seller”
    I’ve seen some pretty shady cars offered by this dealer over the years and wouldn’t set foot in their lot.
  4. root
    root Formula Junior
    472
    Bay Area, Ca
    Clean as in no ketchup or coffee stains on it.
    rhern213 and Ferrari55whoa like this.
  5. JohnnyRay
    JohnnyRay F1 Rookie
    2,905
    Central FL/NW WI
    Again, it just looks bent in the pix...
  6. niftyfivefifty
    366
    PacNW
    I don't think it would have been totaled over a bent control arm. The force that bent it likely compromised the frame integrity.
  7. JohnnyRay
    JohnnyRay F1 Rookie
    2,905
    Central FL/NW WI
    Control arms often bend the frame before they go themselves. Remember, they are generally triangular - the strongest shape...
  8. franschman
    franschman Formula Junior
    Dec 18, 2017
    350
    Holland
    Bart
    I doubt the frame is bent, it is immensely strong. Wishbones are pressed steel (very thin steel) and welded.
    But something is seriously wrong and at least in Europe it probably won't pass any MOT. Makes you wonder why they take the trouble of fairing the body and painting it (cheaply, see pic of left hand bonnet hinge) and not fix the suspension while that is so obviously damaged. Replacement parts are not that expensive and the whole front suspension is simply bolted in.
  9. niftyfivefifty
    366
    PacNW
    I would imagine the insurance companies have a system that assesses micro-damage to a frame after a hit of a certain force, and the speed of this one landed it in the totaled zone, no inspection required. Which makes one wonder what the title status was after the incident, and if the brief trip to PA washed it. Or even more likely, the next move to Kansas. At this point it is probably a better candidate for a GTC replica.
  10. rhern213
    Jan 8, 2021
    576
    Miami, FL
    Richel
    I had a Honda 15yrs ago that I bought as a rebuilt title, which clearly said so in both the carfax and physical title. However, when I actually registered the car to my name and received the physical title later in the mail, the title showed as clean. That left me believing the rebuilt label on the physical title itself is just a checkbox the clerk at the title office marks when sending it to the state. So they must have accidentally not checked off that it was a rebuilt title. To which in that case I'm sure someone with a connection can just slip $100 to the title clerk to "accidentally" not check the box.
    In either case the carfax should specifically say it was issued a salvage title on the Arkansas title issue.
    It was a total loss, so the insurance company had to take the car back themselves and issue it a salvage title under their name.
    It leads me to believe the carfax report is not showing all the correct info. I've seen several times when one reporting agency like carfax does not show a specific issue and another agency like say autocheck does show the detail.
    If it's not a carfax report issue, I don't know how it's possible they washed it on the history report. Or even why they would go through the trouble if the report already shows it was a total loss anyway.
    I'd like to think someone spending $100k+ on a car would do their homework, but many have been tricked into much worse so who knows. Hopefully we won't be reading a post soon of a horror story.
  11. root
    root Formula Junior
    472
    Bay Area, Ca
    Only clue is the record dated 2/8/2012 and the explanation provided in the Glossary yet Autocheck still shows clean title with well above average autocheck score.
  12. rhern213
    Jan 8, 2021
    576
    Miami, FL
    Richel
    Wow, that's even worse
