'99 F355 Convertible top help | FerrariChat
Discussion in '348/355' started by anton1932, Sep 11, 2023.
  1. anton1932
    anton1932 Rookie
    Jan 11, 2023
    11
    Anton Danilovich
    Hey guys. I'm having issues with my convertible top. All rams have been rebuilt. Take a look at the video and let me know what could be causing part of the shown frame not landing where it should during the close operation. I do have the canvas off. Maybe I'm missing tension from the canvas itself? I read that the elastic straps might have something to do with proper top operations.
  2. Petrolhead#32
    Petrolhead#32 Formula Junior
    723
    NorCal
    Petrolhead#32
    I've had all sorts of issues with my top (mine is also a 99 355S). I decided to convert it to manual. One because I drive it mostly with top down, and two because it's not that hard to do it manually. I'm quite happy now and I was super frustrated with the electronic issues. My 2 cents...
  3. Qavion
    Qavion F1 World Champ
    14,259
    Ian Riddell
    I currently have that issue with mine. I don't know if I let the fluid get too low and, either...
    a) the left ram didn't extend/retract properly and it bent the frame
    b) air got in the system and is not fully retracting the cylinder
    I can manually assist the fork to mate with the pin (as a temporary measure) to get the roof up until I figure out what's wrong.
    If you made sure the first rib (from the window) went up (as the roof was coming down), you shouldn't need the elastics.
    Always make sure that the engine is running so that the hydraulic motor/pump can run at the correct speed/pressure.
  4. Lionworks Auto
    Lionworks Auto Formula 3
    Oct 16, 2013
    1,023
    Worthington OH
    Ed
    It would be wonderful to know how to do this! Many have said it’s impossible but obviously it’s doable. Any insights?
    Petrolhead#32 likes this.
  5. Qavion
    14,259
    Ian Riddell
    Many? I haven't heard of anyone saying it's impossible. There are videos on YouTube showing people who have done it and how to do it.
  6. anton1932
    anton1932 Rookie
    Jan 11, 2023
    11
    Anton Danilovich
    Thanks for sharing all the info, gents. I just had my hydraulic rams rebuilt, so maybe the system needs to be bled a bit more. I have a few things to try and will report back with a resolution.
    Qavion likes this.
  7. Gialllo uno
    Gialllo uno Formula Junior
    Jul 5, 2014
    345
    Reisterstown, Maryland
    Mark
    I have seen in paperwork for cars that were serviced when a shop would bleed or replace the Convertible Top Fluid that they bleed it multiple times over several days. I personally have not done it, my top works......awkwardly like all tops, so the car is in my garage covered with the top down and as the weather changes it will go up etc. Typically, in most convertibles you would leave the top up, but I think this is an exception.
  8. Petrolhead#32
    723
    NorCal
    Petrolhead#32
    my local mechanic here in NorCal has done it many times. But I really don’t know the details. I can connect you to him if you’d like
  9. anton1932
    anton1932 Rookie
    Jan 11, 2023
    11
    Anton Danilovich
    Please share your mechanic's info. I'm in NorCal as well. Thank you!
