99 F355 spyder rattle | FerrariChat
Discussion in '348/355' started by hank, Jun 21, 2006.
  1. hank
    hank Rookie
    Nov 30, 2003
    3
    I get this rattling sound coming from either the exhaust or the wire mesh grill that covers the engine compartment. Has anyone else had the same noise and how did u fix it ? I just put on a tubi exhaust a year or so ago and it still makes the sound, so i am leaning towards it being the metal grill, rattling against the hood frame. Thoughts?
    hank
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Check your exhaust clamps. Both of mine were cracked.
  3. ActionFigure
    ActionFigure Formula Junior
    Sep 2, 2005
    440
    Cary NC
    Matt
    On my 98 355 I get a major rattle when the car is cold and idling. Seems to go away once everything heats up and expands. It sounds like it is exhaust related. It is really bad when the engine is cold and idling very low like when backing up and letting out the clutch and not really using the gas.... at that really low idle it rattles something fierce. Had the car up on a lift and everything seemed to check out OK. It also does it when hot and letting out the clutch without enough gas, but not as bad as when cold.... thoughts?
  4. Monteman
    Monteman Formula 3
    2,345
    Santa Barbara, CA
    Monte
    It's your exhaust bypass valve and a fairly common problem. My 98 did it, replaced it with another one..still rattled. Wired it open and...poof!....rattle gone and the car sounds better (but louder). Lots of posts about how to do it on the web site. Just do a search on 355 bypass valve and you''ll find out plenty on how to fix it.
