99 spider battery location | FerrariChat
Discussion in 'Technical Q&A' started by lotustt, Dec 27, 2004.
  1. lotustt
    lotustt Formula 3
    Aug 28, 2002
    2,026
    TRM
    Where exactly is the battery located? I checked the manual but still having problems finding it. I want to put a trickle charger on it. The diagram doesnt really look like the area it claims it to be. Any ideas? Thanks
  2. lotustt
    lotustt Formula 3
    Aug 28, 2002
    2,026
    TRM
    lost the edit feature. meant to mention this is for a 355. thanks
  3. f355spider
    f355spider F1 World Champ
    18,053
    Homer,
    Right front wheel well. Remove wheel, then there are four or five screws you must remove on the foward panel. A few contortions, and it will slide out. Check the fluid level while you are at it.
    You can attach the battery tender pig tail to the battery, and run it up into the trunk for easier access.
  4. lotustt
    lotustt Formula 3
    Aug 28, 2002
    2,026
    TRM
    Hey, thanks Hugh G Rection for the info.
  5. f355spider
    18,053
    Anytime my friend.... ;)
