997.2: Experiences and choices | FerrariChat
Discussion in 'Porsche' started by Jack-the-lad, Aug 18, 2024.
  1. Jack-the-lad
    Jack-the-lad Seven Time F1 World Champ
    I’m interested in owner experiences with the 997.2….especially comparing the base, S and GTS versions, manual transmission and coupe versions only. You can see in my profile the various Porsches I’ve owned. My research tells me that the 997.2 is the sweet spot for value in the “911” range right now, and I’m going to begin looking.
    How do the various versions compare? What are the best options? Are there any particular model years to avoid? Aside from the usual items, are there any specific concerns to look for during a PPI?
    Any knowledge or ownership experiences you can share would be appreciated.
    Thanks!
    Texas Forever likes this.
  2. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,556
    Lake Villa IL
    I had a 95 993 carrera then a 997.2 base.
    All the 997 did is make me miss the 993.
    It wasn't super smooth at low rpm, especially when cold. IMO due to the direct injection.
    Not sure if the oil separator was failing but would occasionally billow a plume of oil smoke on start up.
    Not a fan of the "integrated dry sump" (wet sump) oiling compared to the dry sump 993.
    It seems the S cars are more prone to bore scoring. I would have the bores scoped during PPI.
    I believe bore scoring is the standout issue, and it can be a big one. I've read of some high pressure fuel pump failures as well.
    Not a bad car overall but much happier back in a 993.
    Bullfighter and Jack-the-lad like this.
  3. zygomatic
    zygomatic F1 Veteran
    5,003
    Washington, DC
    Chris
    Hi Jack - I’ve had a 997.2 of some sort in my garage for almost a dozen years now, and I’m happy to share what I know. My biggest question for your is: what do you plan to do with the car? Is it going to be a weekend driver? Daily? Will it see the track? Autocross? A lot of the answer in comparing the base/S/GTS comes down to what you would like to do with the car.
    In terms of model years to avoid: I know a few folks, including myself, that had their ‘09 Carrera S motors drink oil. So I tend to avoid the first year (09) cars. Not a hard and fast rule, but I can tell you that the ‘10 and ‘11 I’ve had did not burn a drop.
    My cars have been very robust: really it has been “add gas, change oil and brakes” for most of the cars’ lifetimes. So I don’t think there’s anything super-special to watch out for on a PPI. People like to look at the Over-Rev report, I think it gives a good idea of how the car has been treated — although don’t be scared if you see a few Range 1s and maybe some Range 2s, unless they’re very recent (Porsche likes 50 hours since an overrev before they say it didn’t damage the engine).
    In terms of options, a lot will go back to ‘what do you want to use this car for’ — so what are you thinking?
  4. Jack-the-lad
    Thanks.
    The S would be the preferred configuration. The GTS is probably a bit too hard core. No modifications. Driving would strictly be pleasure, tours, etc. No track days. My choices would be Sport Chrono, PASM, sport exhaust, but to be honest I’m not fully aware of the range of options available. I’m not very interested in upgraded sound or navigation systems. Can’t be too choosy on colors for a used car, but black is out.
  5. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,507
    Indian Wells, California
    Jon
    I think Porsche now offers the PCCM updated head unit for the 997, so I wouldn’t worry about the old audio/navigation options.
    I did this for my 964, which had an aftermarket CD player when I bought it. Easy decision.
  6. Jack-the-lad
    Were the center-lock wheels from the GTS available as an option on the S?
  7. zygomatic
    5,003
    Washington, DC
    Chris
    I don’t believe so, although the 5 lug wheels were an option on the GTS. I’ll say this: center locks are a bit of a PITA. I’ve been told the 2nd and 3rd gen are better, but if you do your own maintenance, the CLs may quickly become the bane of your existence. (This is based on the need for either an expensive torque gun or a very long wrench to torque the wheels to spec. Which, per Porsche, on 1st gen should be done with the wheel off the ground.)
    MacNugget likes this.
  8. zygomatic
    5,003
    Washington, DC
    Chris
    Last I knew - and it is worth double-checking - the PCCM upgrade was only available for the 997.1 version of PCM. PCM 3.0, which the 997.2s run, should be up next. I’ve heard 2025 rumored, but I’m not holding my breath there!
    Bullfighter likes this.
  9. zygomatic
    5,003
    Washington, DC
    Chris
    I think an ‘S’ is a good specification, though I woudn’t sleep on a nice Carrera. If I remember correctly the 0-60 times weren’t worlds different (0.2 or so seconds different) between the models.
    If yours is going to be a tourer/pleasure driver, I’d look for either the “power comfort” seat (which I think is 10 or 12 way adjustable) or the Adaptive Sport Seats as an option. The difference between the two seats is mostly the side bolstering. Sport seats will “hug” you more. Whether that’s comfortable or not will depend on how they fit you. I’d recommend trying both.
    I shy away from the base seats, at least in their standard “bucket” form. They had, to my mind, far too “flat” a bottom, which meant you slid around more than you do with the “power” seats. The easiest way to know which seats a car has is the “sport bucket” seats have a silver height adjustment lever (it’s not powered) next to them. They weren’t my favorite seats.
    If you can find the Power comfort seats that are also ventilated, go for it. I liked the ventilation for road trips.
    And if you can find one with the “leather option” - that makes the cockpit a particularly nice place to sit.
    In terms of performance: With the “S” you will get PASM - Porsche’s adjustable shocks. I wouldn’t shy away from a base car that doesn’t have it. In my experience Porsche’s suspensions are very well-judged. However, PASM will give you the ability to run a DSC unit with coilovers. It’s something track folks have done a lot in the past decade, and many people who primarily street drive are doing it with their cars, too. People rave about the improvement on what is already a very good setup. This isn’t something I’d run out and do immediately, but something that’s good to keep in mind if you feel the handling needs modification.
    PSE (Porsche Sport Exhaust) - this is really personal taste. A lot of people like the extra aggressive note that comes with Porsche’s valved exhaust. Others think it, like the stock exhaust, is too quiet. It’s worth listening to cars with and without PSE to see what you think. If PSE isn’t for you, there are LOTS of options to make the car sound louder / sportier / give it a different sound. (Note: the 997.2 stock is a pretty quiet exhaust). Generally speaking, this option has good re-sale.
    In terms of handling, it sounds like the sports suspension isn’t high on your list. No big deal there, really. If you can find a GTS it might be worth trying just to see what you think of it. It is stiffer, but - and again this is my opinion - I didn’t think it was too terrible for longer drives. Note that the Sports PASM (terrible acronym) comes with a mechanical limited slip differential. That won’t make much difference for road tripping, but it will give you bragging rights.
    And, finally, Sport Chrono / Sport / Sport +. My take on these is that they’re largely marketing “fluff” on a manual car. Sport + doesn’t really do anything for manual cars (it does however really change the way the PDK responds). Sport just makes the throttle “touchier” — that is you get a greater “opening” with less pedal movement. Some folks will tell you it makes the engine make more power. It doesn’t. You just think it does because you’re getting more response for less pedal travel. The biggest argument I’ve heard for Sport/Sport + is that they make heel/toe shifting easier. This is true, but I did plenty of track days in a 997 without Sport/Sport + and it heel/toe shifted just fine. As for the “wart” (the chrono clock), I found I really didn’t much use it for anything except occasionally timing myself on my way to work. I’d say if you like the look, go for it, but I wouldn’t pay a premium for any of these options. (Note: Sport Chrono probably will help resale. I got a few $K off one car because it didn’t have it)
    The one option I might pay extra for, if I could find it, would be x51 power kit. This is standard on the GTS. You don’t get a lot of additional power (+23hp) but you get a slightly higher redline and (what felt to me) like a broader torque plateau. The issue here: it is VERY rare to see an “S” with the x51.
    Above all, the 997 is a really solid platform - enjoy yours!
  10. Chupacabra
    Chupacabra F1 Rookie
    3,382
    Behind a drum kit
    Mr. Chupacabra
    My thoughts exactly on the base car. Nearly as fast and powerful as a .1S, which I had and found to be more than enough car, especially for what you describe as your intended use.
    I also wouldn’t shy away from a .1S. A good PPI will likely reveal all you need to know, and if you go ‘07-08 (even ‘06, really) there’s little to worry about. They can be had for, in many cases, 1/3 less than a comparable 997.2S, too. Unless of course you are willing to go PDK, which makes all of the .2 cars a lot easier on the wallet.[/QUOTE]
  11. Island Time
    Island Time F1 World Champ
    11,358
    E. TN
    David
    My 2 cents…
    Sport Chrono plus is the way to go. The “fun” button makes the power instantaneous. Noticeably so. In my opinion, it’s makes it a different car. More fun.
    Good luck. Enjoy your car.
    Jack-the-lad likes this.
  12. Jack-the-lad
    That’s the first thing I look for….after MT.;)
  13. MacNugget
    MacNugget Formula Junior
    371
    Tejas Hill Country
    Sport Chrono is vital for a PDK or turbo car, but if you're shopping manual transmissions I don't think it really matters much. It's nothing more than a throttle remap to make the accelerator pedal more twitchy in a manual transmission car. It adds no power or actual performance benefit.
    You can even add it after the fact without the goofy chrono dial on the dashboard if you find a car you otherwise like which lacks the feature. https://www.suncoastparts.com/product/9X7SM.html
  14. Texas Forever
    Texas Forever Eight Time F1 World Champ
    80,536
    Texas!
    My biggest concern is the seats. I'm looking for a touring car. I don't want any side boosters. You probably need to salesman to decipher the Porsche code, but I believe you want the 18-way sport seats.
    I also drives me nuts when people lower a car. I'm more concerned about dead skunks in the middle of the road.
  15. Rory J
    Rory J Formula 3
    May 30, 2006
    1,119
    Sport Chrono also allows the PSM (stability control) to be put into sport mode, which loosens up the parameters and allows a little more slip. Definitely best to find a car without and add through the dealership, so you don't get the "dash wart" timer.
    I highly recommend a car with PASM and full leather interior. Those were two must haves when I was shopping.
    Texas Forever and Jack-the-lad like this.
  16. Jack-the-lad
    Thanks for that. Until now I didn’t know that Sport Chrono could be retrofitted. Good to know! All of my 911 ownership was with the air cooled cars, so I have some learning to do. I did have a Boxster RS60 with Sport Chrono though.
    “Dash wart.” Good one!:D
  17. vrsurgeon
    vrsurgeon F1 World Champ
    16,251
    Charleston, SC
    Curt
    This thread makes me miss my 997.1. I miss that car. Love love my 991.. but the 997 (.1 or .2) has a certain end of era je ne sais quoi. Manual with attention to bore scoring..
  18. Chupacabra
    3,382
    Behind a drum kit
    Mr. Chupacabra
    I know what you mean. Wish I could keep them all.
    I drove a 991.1 Targa 4S manual not long ago. At one point, I looked at the salesman and said, “I know it is NOT…but it feels slow.” His response was, “You’re the second person to say that.”
    Jack-the-lad and vrsurgeon like this.
  19. Jack-the-lad
    This thread has been very helpful.. Thanks to all contributors. Please keep the comments coming.
    These subjective comments are interesting. Can you expand on them?
  20. Chupacabra
    3,382
    Behind a drum kit
    Mr. Chupacabra
    #20 Chupacabra, Oct 1, 2024
    My take is that the extra weight, both from the AWD and the top of course, is certainly something you feel, and when coupled with the enhanced (overkill, IMO) NVH reductions in the 991, it just makes the car seem sluggish. I suppose a software tune could help; throttle response is particularly uninspiring to me and the clutch, as with most newer cars, is too damn light.
    Regarding VrSurgeon’s 997 take, I’ll allow him to expound…but for me, the post-997 cars, non-GT at least, have become too comfort oriented and have left some excitement behind. Beautiful, capable, great cars, no doubt. I’m not saying I wouldnt have one, but if you are coming from a more classic Porsche mindset, the 997 is probably going to be peak watercooled for you.
    MacNugget and Jack-the-lad like this.
  21. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,533
    Toronto / SoCal
    Rob C.
    I had a 2010 4S as a daily driver and quite liked it. It was a highly optioned car and I would push to find a car with full leather interior. It looks a lot more upscale than the stock interior which can look cheap. The 997.2 is holding its value because of how rare they are. Production was quite low for Porsche during this period and the rarity is what is keeping prices strong.
  22. Chupacabra
    3,382
    Behind a drum kit
    Mr. Chupacabra
    I’ll second the full leather. It is a nice option, though somewhat tough to find in an already limited selection. In my 996TT, it makes a HUGE difference. 9x7 interiors are already better, and the full leather puts it over the top.
    Full leather in coco = YES. :)
  23. donv
    donv Two Time F1 World Champ
    24,886
    Portland, Oregon
    Don
    I kind of want a 997 Carrera 4 with a 6-speed manual. My thought is to put a ski rack and winter tires on it and use it as a winter daily driver.
    At one point, I wanted to order a 992 and configure it for that purpose, but the waiting lists were just too much, so I gave up. However, I think I could make what I want out of a 997 and probably be happier.
    The only issue is the interior. Porsche interiors were (and to some extent still are) too darn monochromatic! I want tan seats and a black dash and steering wheel, is that too much to ask? Apparently it is.
  24. Rory J
    Rory J Formula 3
    May 30, 2006
    1,119
    I completely agree with you and Porsche Sonderwunsch (Special Wishes) is your answer. Bring your checkbook.
    I was happy to find a car with a full leather black/gray two-tone interior as a factory option on my 987.2. Lower dash, seat middles, center console in gray, the rest in black. That's still not a big difference in color, but the gray is light enough to eliminate the cavern feeling of all black. My old 944 S2 was black/linen which was also nice.
    Chupacabra and Jack-the-lad like this.
  25. Jack-the-lad
    I agree. I had many air cooled 911s from 1966 to 1989. Every one, regardless of paint color, had black interior except one which was special order dove grey. Black is so boring and uninteresting. I’ll never have another unless offset by contrasting carpet, seat inserts, etc.
