360 - A/C comp not clicking in | FerrariChat
360 A/C comp not clicking in
Discussion in '360/430' started by rizzo308, Jul 23, 2021.
  1. rizzo308
    rizzo308 F1 Rookie
    BANNED Silver Subscribed
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    Hey guys
    My A/C sh#t it's self so i had it rebuilt i refitted it and tried to engage the comp as we were re-gassing it
    but the comp would not kick in. Fuse and relay behind the seat and main A/C fuse nxt to battery all good but still no power to the comp.
    Is there a mystery fuse some where else along the line. TIA
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,021
    Isle of man- uk
    Compressor clutch will not engage if not enough gas pressure, try a temporary link wire on the pressure switch mounted at the drier. This will get it running if that switch is not made due low gas pressure.
    If this does not work check for power at the connector at the compressor clutch
    John_K_348 and one4torque like this.
  3. rizzo308
    rizzo308 F1 Rookie
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,021
    Isle of man- uk
    #4 mike32, Jul 23, 2021
  5. 24000rpm
    24000rpm F1 Rookie
    test the pressure crudely by using a small screwdriver to press down the schrader valve(by the brake fluid reservior) a little bit to see if r134a is coming out. It should be having a big noise like you are deflating a tire. If you don't have enough pressure then your ac ecu won't give power to the compressor
    flash32 likes this.
  6. rizzo308
    rizzo308 F1 Rookie
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    Yeah mate that plug is of Number 14 on the parts diagram you posted.
    Cheers
  7. Qavion
    Qavion F1 World Champ
    14,648
    Ian Riddell
  8. rizzo308
    rizzo308 F1 Rookie
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    Hi Ian
    So it’s blue and yellow.
    Cheers
  9. Qavion
    14,648
    Ian Riddell
    #9 Qavion, Jul 23, 2021
    According to the wiring diagrams, it's blue and orange/white on the middle wires.
    i.e. pin 2 and 5 (pin 1 is unused)
    Wiring diagram here
    https://www.dropbox.com/t/gnz3XSmL0grAyFrc
    i.e. item 21B
    If you remove the plug and jumper the wires, just be aware that this will inhibit the radiator fans.
  10. rizzo308
    rizzo308 F1 Rookie
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    I jumped the 2 wires on the pressure switch and glad to say that my comp is now engaging. Thanks to all you guys for your help much appreciated.
    Qavion likes this.
  11. Qavion
    14,648
    Ian Riddell
    So either a faulty switch or low gas?
  12. TheMayor
    107,635
    Vegas baby
    Running the compressor without gas is bad for the compressor, which is why that switch is there. So this needs to be determined.
    Qavion likes this.
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,021
    Isle of man- uk
    Best to get a gas charging set with the suction and discharge gauges on, that will give you the gas pressure in the system. When the compressor has been off for a while the 2 gauges will read the same. Once running the suct will drop and discharge rise. If you do not have enough gas in system then the pressure switch will operate to protect the compressor by stopping it. ( hence the need to link it out to get gas into system.)
