A/C Compressor Help | FerrariChat
A/C Compressor Help
Discussion in '348/355' started by mmrankin, May 19, 2006.
  1. mmrankin
    mmrankin Rookie
    34
    Dallas, Texas
    Mark M. Rankin
    My A/C compressor does not engage when I turn on the A/C. I looked for the 12 gague brown wire, but could not find it nor could I find the fuse that I read about in the archives. Anyone have any suggestions? Are there fuses/relays I should check? I only found 1 relay for A/C in the owners manual.
    Thanks in advance,
    Mark
  2. mmrankin
    mmrankin Rookie
    34
    Dallas, Texas
    Mark M. Rankin
    Update: Ok, so I found the brown 12 gauge wire and it already has a 30 amy blade-type fuse on it. The fuse is in good working order.
    Here's the substance of the problem: When I turn on the A/C, the front fan in the bumper in the front of the car does not come on. The compressor does not kick in, but I get a lot of air blowing from the vents. It's not cold, but it's there.
    Is there a relay I should check or is there a wire I can put a load on to turn on the compressor and the fan up front to see if there is another problem?
    Final question: Does anyone have a diagram of what the relays and fuses are up front in the top passenger side?
    Thanks!
    Mark
  3. Janzen
    Janzen Formula Junior
    Oct 25, 2005
    420
    Oklahoma/Texas
    Janzen
    #4 Janzen, May 21, 2006
  4. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #5 No Doubt, May 21, 2006
    That's normally empty. You install a 10 amp fuse there to trigger the ABS diagnostics.
    Here's mine, empty:
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    AC compressors have a pressure safety switch; not enough freon pressure and they won't kick on. I don't know if that safety switch would cause your front AC fan to not kick on, though, so that may or may not be your problem.
  6. Janzen
    Oct 25, 2005
    420
    Oklahoma/Texas
    Janzen
    Thanks-
  7. mmrankin
    mmrankin Rookie
    34
    Dallas, Texas
    Mark M. Rankin
    "AC compressors have a pressure safety switch; not enough freon pressure and they won't kick on."
    Thank you No Doubt. I also received the same advice from Daniel at http://www.ricambiamerica.com/. Great advice and, $174 later, it's cold as can be. I'm amazed!
    Also, evidently the front fan does not kick on unless the compressor is running so a little freon and there we went!
    Best wishes.
    Mark
  8. Ricambi America
    Sponsor Owner
    ... and on a Sunday, too! Mrs. JRR is delighted. :(
  9. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Cool. Glad to learn that you are driving in style/comfort again.
