A/C compressor oil questions | FerrariChat
Discussion in '308/328' started by stevel48, Jul 14, 2010.
  1. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Steve (85 308 Owner)
    So does all the oil reside in the compressor?
    If so how much and how do you change it?
    Need to recharge my A/C.
  2. BigTex
    79,406
    Houston, Texas
    Bubba
    The oil charge goes in thru the fittings with the gas.......I'm reaching back from memory but it's not much .......4 oz.????
    PM Sean F. he just rebuilt his system, unless someone psts with Shop Manual info...
    The oil type has to match the refrigerant.....R12....R134.
  3. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    There is also oil in the comp. itself - which oil are you ref. to?
  4. Tokyo Drftr
    Tokyo Drftr Formula 3
    Jan 18, 2009
    2,461
    UA-USA-JP
    Ро&#1081
    i don't really know how critical it is........but the comp. oil is different for R12 and R134. I just use what is recommended. I think due to some natural bleed off into the ac system?
  5. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    PAG oil works for both R12 and 134A. There is a fill plug in the compressor and you can check how much is in the unit. If you had blown a seal or condenser then you most likely blew the oil out of the system. You can also use an oil charge can of freon instead of filling through the compressor. The oil will circulate through the system and lubricate the compressor. In the earlier days the oil used for R12 was only compatible with R12. The new PAG oils works with both.
  6. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    I'm thinking duracool but was wondering if i need to replace the oil in the system too.
  7. Steve King
    Feb 15, 2001
    4,367
    NY
    Looking at the Duracool site it appears it is compatible with PAG or mineral oils . That is for Duracool 12a , so just read their info and do what it says. I never used the stuff so don't have to much info on it.
  8. david bentley
    david bentley Karting
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    I have had Duracool in my 1965 Mustang for 6 years...works great
