A/c compressor question york style | FerrariChat
Discussion in '308/328' started by LotusS4, Aug 7, 2017.
  1. LotusS4
    LotusS4 Karting
    76
    Long Island, NY
    #1 LotusS4, Aug 7, 2017
    Thank you for all the previous water pump pulley tips and advice. My next hurdle is the a/c compressor, I order a New York style and started to switch clutch and other parts over and it seems the right angle hose adapters and fill ports have a different type of seal from one compressor to another. The old compressor is Aspera and new one is york(but not 100%), has anyone else come across this while changing theirs and what did you do?
    Thank you
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,572
    San Carlos, CA
    Mitchell Le
    You get new hoses made up.
  3. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    YORK/TECUMSEH COMPRESSOR TUBE O TO ROTOLOCK A/C FITTING ADAPTER 1954
    Bought my compressor on eBay direct swap came with the fittings they insert in the new compressor.
  4. LotusS4
    LotusS4 Karting
    76
    Long Island, NY
    Thank you!! Just ordered 2 of them!
  5. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    #5 waymar, Aug 7, 2017
  6. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,033
    Summerfield, NC
    Tom Jones
    The compressor is not correct. Not only are the fittings incorrect but the suction and discharge ports are are not in the correct locations. The original hoses won't fit worth a hoot.
  7. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,338
    Encino, Ca
    Carl T
    Yes you are going to have issues with mounting and connecting hoses with the ports located where they are . The Aspera is not OEM so seems as if the compressor has already been changed once before?
  8. LotusS4
    LotusS4 Karting
    76
    Long Island, NY
    hmmm. ok, i missed that and not in front of car at moment so not sure how much room i had on hoses, I didnt realize the aspera wasnt oem :-( I feel like I should know this answer but tracing the hoses, The suction hose should go to where and discharge to where?
    Thank you
  9. LotusS4
    LotusS4 Karting
    76
    Long Island, NY
    actually, im guessing if the hoses could even make it that the suction and discharge being reverse will not pump correctly when the belt is turning?? so I need to pull out and change the unit out for correct one?
  10. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Not sure about your year car. My 1982 308GTSi used this one as plug and play. No issues runs great. Just make sure LH or RH suction. OEM clutch mated direct.
    Universal Air Conditioner (UAC) CO 0020GLC A/C Compressor $147
  11. ferrarioldman
    Jun 19, 2002
    1,033
    Summerfield, NC
    Tom Jones
    I would recommend NAPA part # 258108. They call it a rebuilt unit but the last 3 I received were brand new compressors as no rebuilt units were available.
  12. ferrarioldman
    Jun 19, 2002
    1,033
    Summerfield, NC
    Tom Jones
    The Aspera was the originally installed compressor up until the late 328's and than came tagged as York. Aspera is basically a York under another name.
  13. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Why dont you USA guys change over to the Sanden as used on Euro cars? I believe brackets are available? Even the Chinese Sanden clones work well.
  14. BigTex
    79,380
    Houston, Texas
    Bubba
    The York unit was also used on the 911.
    They are plentiful (or were when new) and now as noted the supply has been used up!
    The Sanden is a more efficient unit and less drag on the engine.
  15. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Also the York seems like a very big unit, the Sanden is relatively easy to deal with when changing timing belts.
  16. BigTex
    79,380
    Houston, Texas
    Bubba
    Agreed, most who have converted were quite pleased.
  17. yelcab
    Nov 29, 2001
    13,572
    San Carlos, CA
    Mitchell Le
    I love to get some brackets for Sanden conversion. Please point the way...
