A/C compressor upgrade for BB512 | FerrariChat
Discussion in 'Technical Q&A' started by 412monzaindy, May 26, 2010.
  1. 412monzaindy
    412monzaindy Formula Junior
    Mar 8, 2005
    877
    Ontario Canada
    PBI
    The York A/C compressor on my BB needs to be rebuilt. My questions is, does anyone know of an upgrade that can be done for the BB512.
    Will a TR compressor fit?
  2. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    The Boxer OEM compressor cools fine. It's the air delivery that is insufficient...
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,709
    South East
    Jimmie
    If its the same compressor as a 308 then there's new ones readily available for maybe five hundred bucks and/or loads of articles in the 308 section about optimising the system with or without changing it
  4. BigTex
    79,406
    Houston, Texas
    Bubba
    #4 BigTex, May 26, 2010
    These comments are steering you right...I'd make sure the bearings/seals/reed valves are good in the compressor.....THEN:
    Pull and examine fans and gaskets in the blower boxes.
    Pull vents and renew diverter flaps (often leather, dried and peeled by now.)
    Clean the evaporator coils with HVAC coil cleaner, same with the condenser coil in front of the radiator. Check or change the dryer and expansion valve....
    Finally, replace/renew any and all foam strip seals around the radiator/condensor, against the hood, all the stuff the seals against air migration and forces it the flow thru the radiator/condensor supports.
    Then you'll have it optimized. But because of the large glass areas, it may still not keep up with direct sunlight.
  5. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    Geez, Al, didnt know youre into auto ac now, eh?? Howd you learn all this? have you been yanking dashboards on 308's for this....LOL?
  6. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    I take it you will be using R12 for that, right??
  7. BigTex
    79,406
    Houston, Texas
    Bubba
    There's scars on my back , brudda!
    And as far as a working system in my cars, I roll the windows down and tell them to disrobe......
  8. 412monzaindy
    Mar 8, 2005
    877
    Ontario Canada
    PBI
    The systems has been recharged using R134. All of the seals and rubbers are new.
    The fans work well.
    As a matter of fact I don't think there is anything left to replace on my car. ( oh, oh I am wrong, the compressor needs bearings it is just starting to emit a little noise)
    It reminds me of my first Ferrari, a 1980 308 which was a little better than the 512BB but not much.
    Thanks everyone for all your help, I will be asking my wife to disrobe and have a cool suit for any other passengers.
