360 - A/C condenser fan access | FerrariChat
360 A/C condenser fan access
Discussion in '360/430' started by 78bonanza, Jul 7, 2022.
  1. 78bonanza
    78bonanza Formula Junior
    Apr 1, 2018
    350
    Jim Cear
    What do I need to remove to access the AC condenser fan to see if it is working ?
    AC fuse blows shortly after AC is turned on . My indy said to check it before any disassembly of compressor lines
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Have you checked compressor clutch, is that on same fuse
  3. 78bonanza
    Apr 1, 2018
    350
    Jim Cear
    Yes . It’s working ,until the fuse blows
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    #4 mike32, Jul 7, 2022
    Test the clutch coil for a short, if its blowing fuses you have a short somewhere. You can put a separate supply to it with an inline fuse and see if it blows.
    Looking at the drawing it shows the AC condenser but no fan, are you sure it has its own fan or is it in series with the cooling water radiator so the one fan is cooling both.
  5. 78bonanza
    Apr 1, 2018
    350
    Jim Cear
    Yes I just looked at the diagram and didn’t see a separate fan either . I think the AC guy I spoke to gave me a generic AC answer so I doubt that’s the problem as the car has no temperature issues otherwise .
    I’ll check the clutch coil . I hope it’s that easy.
  6. Qavion
    Qavion F1 World Champ
    14,290
    Ian Riddell
    In summary:
    The RH fan is a combined engine/AC fan. Fuse for the fan is in the forward luggage compartment.
    The only thing on the AC fuse is the compressor clutch. Fuse is behind the driver (LHD car).
    Disconnect the compressor clutch connector and see if the fuse still blows.
  7. 78bonanza
    Apr 1, 2018
    350
    Jim Cear
    #7 78bonanza, Jul 7, 2022
    Why didn’t I think of that ? :(
    Time to do timing belts anyway. May as well do it all while I’m there.
    Qavion likes this.
