A/C - heater fans not working | FerrariChat
Discussion in '348/355' started by angelis, Apr 11, 2008.
  1. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    It's been an intermittant problem, but today the AC system stopped working.
    The control panel appears to be working ok. No warning lights.
    The fans don't work on any setting. Cold, heater or outside air. Not blowing at all.
    Could this be a compressor problem?
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Check your hidden fuse and fuse holder first. Change them out just for grins even if they look OK.
    Look carefully and closely at the buttons on your cockpit panel in case one is jammed down a bit.
    Check your ground wires that are behind your left side air vent.
  3. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    I'm thinking it's a loose wire somewhere.
    A couple of times it's stopped, I've hit a pothole and it's started up again.
    All working okay at the moment.
    Damn italian electrics!!!
  4. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    I have a few threads about my A/C. The last one might be the solution.
    Can´t help you to find it but it is there somewhere.
    Maybe the fan motor stopped working as in my case.
    Good luck!
    //B//
