A/C not working well - condenser fan intermittent | FerrariChat
Discussion in '360/430' started by Jagbuff, Jul 4, 2018.
  1. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    Happy 4th of July everyone!
    Decided to take the CS out for a drive today (only 3rd time this year :( ) and had a rather uncomfortable experience as the A/C just wasn’t performing as it should especially in stop and go traffic. I checked the lo and hi pressures and they seem to be in the ball park (maybe a tad high), but I did notice that the A/C condenser fan is only running intermittently – like it turns on for about 5-10 secs every couple of minutes.
    My memory is failing me, isn’t it supposed to run continuously? Could the fan relay be going out?
    Thx for suggestions!
  2. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    No, it is not supposed to run continuously even when the ac is turned on, but you would think once triggered to turn on it would run more than a few seconds. That doesn’t seem right.
  3. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Your fan motor might be failing or the A/C control unit has gone bad
    Yes the fan should run continouosly
  4. HektikArab
    HektikArab Rookie
    35
    Samuel Allouche
    hey buddy sorry to contact you this way can you inbox me
  5. hessank
    hessank Formula 3
    1,928
    Canada, Florida
    Fred
    Is your AC compressor cycling in sync with the intermittently running fan?
    That would point to the Freon as read by the PS
  6. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Misunderstood your issue.
    Not evaporator fan but the condenser fan.
  7. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    A/C compressor in not cycling out, just the fan. It is noisy but still seems to function ok when it is triggered. Checked the following:
    Checked the Hi/Lo pressure and they are in the right range 13.5 to 2 bar when compressor on.
    The condenser is very hot so the system is operating.
    I pulled the boot cover to check the lines, the line to the condenser is very hot while the return is barely cool.
    I checked the relay R2 which controls the fan, it is energized so there is power going to the fan circuit though I presume the trinary switch/ECU controls on and off function.
    Not really sure where to go from here other than evacuating the system, replacing the receiver dryer and recharging the system? Any other thoughts?
  8. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,954
    The Cold North
    Tom
    Your r134 level is low. Evac and recharge to proper weight..and check for leaks.
  9. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    Will do, probably time to replace the receiver dryer too!
    THX!
