A/C only works on coldest setting F430 | FerrariChat
Discussion in 'Technical Q&A' started by Joegnsx, Jan 6, 2013.
  1. Joegnsx
    Joegnsx Formula Junior Owner
    Dec 1, 2012
    958
    Valrico, FL & Franklin, NC
    Joe Gliksman
    I am new and posted this on the 430 section--just bought a 2005 430 and the A/C seems to work fine with thermostat on lowest setting but does not cool at all at any other temp setting. Compressor shuts off. One suggestion was there may be dust in the cabin sensor, which I will check -- other ideas are appreciated. I looked through about 250 posts about a/c before starting this thread, so please don't complain about another a/c thread--I tried! Thanks
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,702
    South East
    Jimmie
    I'm sure this isn't the case here but one of the most common issues for new owners is the a/c off button being off not on - is it worth trying again with the big buttons on auto and just leaving it a while set at around 65 F - also double-checking the recirculation switch position to be 'released'
    On some models of that era there's an a/c reset procedure to be used after battery-off which I think involves just max & min temp - I cannot recall the exact details
  3. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,456
    Dublin, Ireland
    Greg
    JoeG,
    I'm sure I've read of similar complaints in the past. It's not an area of great interest to me so I haven't retained a link for it. I've a feeling the issues may have been down to a faulty thermostat.
    Sorry I can't be of more help. Will post again if I should happen to find a relevant thread.
  4. Joegnsx
    Dec 1, 2012
    958
    Joe Gliksman
    Looks like its the climate control module
  5. tazandjan
    tazandjan Three Time F1 World Champ Lifetime Rossa Owner
    39,310
    Joe- If you go to ferraridatabase.com, you can download an F430 workshop manual, which has a whole section on the A/C system. Assuming, of course, you do not just have the controls misset.
  6. stevew3765
    stevew3765 Formula Junior
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
    At least yours works....:>(
