a/c problems | FerrariChat
a/c problems
Discussion in '456/550/575' started by Streetking, Oct 6, 2007.
  1. Streetking
    Streetking Formula Junior
    Jan 20, 2005
    263
    Austin, TX.
    SW
    Ok I don't drive the 550 much, so I took it out yesterday. The A/C was not blowing cold. I took it to a local shop and they did a evac/ recharge. The air coming out of the vents smelled bad.. then about 3 hours later, didn't work. Anyone else had this problem? I did a search and most everyone that had a/c problems replaced their compressor but no one complained about any kind of smell..
    SW
  2. dsd
    dsd F1 Rookie
    Nov 19, 2006
    4,271
    Northern Virginia
    Could possible be a clogged line in your system (drain or evaporators). When you run the AC is water dripping under the car?
    How bad is the smell? Is it like old gym bag (which could be mold)?
    Best,
    dsd
  3. Streetking
    Jan 20, 2005
    263
    Austin, TX.
    SW
    Thanks, I will check..
    SW
  4. Protouring442
    Protouring442 F1 Veteran
    Sep 5, 2007
    8,723
    Harriman, TN
    One Stupid SOB
    Have your shop look at it again, could be an evaporator leak, though they should have spotted this in the evac/recharge.
    Shiny Side Up!
    Bill
  5. Sfumato
    Sfumato F1 World Champ
    Nov 1, 2003
    10,194
    Llanfairpwllgwyngyll, Anglesey, Wales
    Angus Podgorney
    SW:
    There are 2 lines up in front that can leak, dump freon. Happened to me. New lines are not cheap, but fix problem. Sudden failure not uncommon, not easy to find problem. HTH
    L
  6. Racer98
    Racer98 F1 Rookie
    4,766
    Encino.
    K-Fence.
    It's soo annoying to find the problem, but the best way to scout out the problem with a leaky A/c system is to next time take it back to the shop that did the A/c recharging and ask about using an "oil Die' this is injected into the a/c system will scout the source of the leak out, but I would check with the service manual from Ferrari if this is allowed, now the good news is if the leak is with in the engine area then it will be easy to find but if the leak is under the dash then it will require pulling things a part,
    questions for you:
    1) The smell of the A/c when its turned on smell like
    a-celery
    b-coolant
    c-???
    2) when you turn the a/c on can you hear a loud clicking noise and the engine RPM's dip a bit
    3) Sitting on idle at a stand still does the engine temp get to high wile
    good luck.
