A/C questions--please help! | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by FamilyCar, Jun 1, 2016.
  1. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    #26 andyww, Jun 20, 2016
    Good info. The 507 and 508 do seem to be fine with R134a though, so not sure what they changed in the 5H14.
    I had a problem finding a gasket set for the 508 when I recently rebuilt one. There were none in the UK at all so I ordered one from the US and it was wrong. Luckily a "new old stock" compressor came up on Ebay so I used that instead.
    I was sceptical anyway whether the large ring seal on the faceplate would ever re-seal properly as the surfaces seemed not to be in sufficiently good condition.
  2. afterburner
    afterburner F1 Rookie
    3,501
    Switzerland
    Urs STEMMLER
    The compressor is fine as long as you use Sanden's SP-15 or SP-20 oil.
    I haven't opened one so I don't know. However I have contacted Sanden and they do not recommend to run it CCW as it will be very noisy, have a reduced life span and void the warranty.
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,996
    Isle of man- uk
    Re NW328 Video, this is very good and answers a lot of the initial question so it looks like you get a new belt on the compressor and get the gas charge checked. From what is on the video it is unlikely u have damaged the compressor but it may be overcharged. As the compressor turns, assuming it does with the clutch energised it is not locked up internally. Will be interested in the final result
  4. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Yes sure. What I meant was what they changed to make them more compatible with 134a than the 507 and 508.
  5. afterburner
    3,501
    Switzerland
    Urs STEMMLER
    #30 afterburner, Jun 20, 2016
    The difference between the two gases is their requirements re the chemistry of the lubricant. R12 lubricants aren't compatible with R134a.
    By changing the designations ex factory, Sanden and its clients can very easily distinguish between the older R12 compressors and the current series.
    Mechanically, there is no change necessary as far as I know. Whether they have mechanically changed something I don't know but suspect so as the Sanden representative I contacted was very clear about not using the SD5 compressor CCW. He strongly suggested me to use an SD-508.
    I have previously converted my Mondial's original R12 York compressor system to R134a many years ago (with Esther oil), and the current SD-508 was an R12 NOS unit I am running with Sanden SP-20 oil in a R134a system. No issues whatsoever re the use of the compressor.
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,996
    Isle of man- uk
    Is it correct you have to change the hoses under the car if u change the system to 134a ?
  7. afterburner
    3,501
    Switzerland
    Urs STEMMLER
    No, I don't think so. I didn't... you would have to change all other hoses too if that was the case.
  8. PAP 348
    Dec 10, 2005
    100,234
    Mount Isa, Australia
    Pap
    Nah, no need to change any hoses.
  9. FamilyCar
    FamilyCar Formula Junior
    790
    Seattle, Wa
    Peter Goodall
    Here's an update for your consideration and comment.
    In speaking with a co-worker that is also into cars, I recalled that one of the bolts holding the compressor to the bracket was loose, so it is quite likely that the tension was not correct and the belt did just break without being caused by internal compressor problems.
    I have tried turning the compressor while holding it in different positions, in case a broken connecting rod or such would be swinging into the way. No apparent problems. In fact, if I turn the compressor as fast as I can with a speed (crank handle) wrench I can feel the five pulses as each piston begins to build a small amount of pressure, I'm feeling pretty confident it isn't damaged internally.
    I spoke to one of the service technicians where I work, and we can evacuate and re-charge it here with R-12. We have the equipment and people with the skills and certifications, so all I have to do is provide the R-12 and maybe a case of beer. I have bought R-12 on eBay which should be adequate for the system assuming we draw it down and hold a vacuum on it for a while, which should also identify major leaks.(2.65# capacity per the owner's manual).
    A new dryer is on it's way.
    I'm not replacing the hose seals, since that is opening a can of worms and the technician stated that if it has some charge left after 8+ years it doesn't really have a problem. I have read that the R-134 is more prone to leaking, however.
    That's the plan going forward. Unfortunately I leave for a two week vacation tonight so I'll be away from it for a while.
    So here's my final (I think) question: What to do about the oil? Because I won't be able to take the compressor out and drain it when we do it here in the parking garage to see how much oil to add, the idea of an oil charge makes sense to me. I've also read that pressure loss=oil loss. At the same time, the technician said that with a slow leak that wasn't as true, and that you should be able to spot residue if it is coming out--which I haven't. I know there is some in it because it sprayed all over my arm.
    Do I add some oil assuming it has leaked somewhere and some will get drawn out during evacuation, or assume it is all in the sump and collecting in various low spots while the vacuum is pulled over it? System capacity appears to be about 6oz (.175L) and cans of it come in 2 or 4 oz that I've seen.
    Thoughts?
    Thanks so much for all the discussion. I value all the contributions.
  10. ken qv
    ken qv Formula 3
    Oct 25, 2006
    1,925
    Florida
    Ken Roberson
    Look into DURACOOL- if it can keep my Countach cold it can keep Any car cold
  11. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    If the system is not open now there is no reason to open it. The dryer has not been exposed to moisture and therefore should be fine. You can make a case for opening an old system when you can easily change oil, "O" rings, and Schrader valves, but just changing the dryer and refrigerant is not sufficient cause to do so IMO.
    If you do open the system I would definitely change the dryer and Schrader valves. I would also change every "O" ring I could access without tearing the car apart (on a Mondial that may not be very many). They are clearly not leaking much now, but "O" rings harden due to age/thermal cycles and the seals/springs in Schrader valves also weaken due to age. IMO not replacing those items when an older system is open would be wasting an opportunity to avoid future problems with the system.
    In other words, if the system is currently holding pressure there’s no need to do anything to it unless you want to take the opportunity to engage in some preventative maintenance. Otherwise, just top the system up with R12 and enjoy (assuming the compressor turns out to be working okay). If you do open the system use that as an opportunity to perform as much preventative maintenance as possible, in hopes that will keep you from having to open the system again any time soon.
    As to oil, it is not uncommon to see systems with too much oil in them because everyone who opens it feels like they ought to add some. At the least this significantly reduces the effectiveness of the system. At the worst it can hydrolock the compressor. If you don't see any evidence of oil leaks and you're reasonably certain that the system has not been opened/tampered with in the past, the safest course is probably to avoid adding any oil. If you're concerned about the inevitable oil loss from connecting and disconnecting the manifold gauges, adding ~1/2 oz of the original type oil (presumably mineral oil) would be fine, but do not mix types of oil.
  12. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Good advice above.
    Not 100% sure but I would expect a car of this age would use all flare fittings and would not have O rings on the joints. No need to open up the system without good reason.
    Older A/C systems used "proper" pipework which lasts. Modern cars use quick-assembly systems which leak after a couple of years.
  13. staatsof
    96,244
    Fuggetaboutitland
    Bob
    Thanks Ken for posting this.
    Duracool Direct On Line Shopping © 2004 - Duracool Refrigerants Inc.
    I used to be interested in Freeze12 which no longer manufacturers their R12 replacement. That one was not a propane based substitute. Do you know about this one?
    I still have 3 cars with R12 based systems all of which would not do well with a R134a conversion which also soon will be hard & expensive to find. So when my 24 cans of R12 run out I'd like to think about a replacement such as this. Perhaps a big canister of it too!
  14. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,996
    Isle of man- uk
    If u have got this far, put a belt on the comp and give it a run as you have not lost the gas . Any oil or gas u lost over your arm is such a small %age it is not worth bothering about. In regard to the drier if you do not notice any chilling over it then leave it alone. It should be cool on the inlet and outlet, if the inlet is cool but the outlet is cooler then it is getting dirty, so the liquid F12 is expanding over it and you get the chilled effect when you should not. You would also get a higher discharge pressure.
    Re the 134 i think the modification is to fit hoses with special non leak liners- the original hoses are too porous for 134-my dealer offered to convert mine but i stayed with the original as it was an expensive mod
  15. staatsof
    96,244
    Fuggetaboutitland
    Bob
    Over here any big truck/hydraulics service shop can make up new AC hoses custom sized even reusing your original fitting if that's a requirement. The newer stuff is better and not as bulky. It's not terribly expensive either. I did some last year.
  16. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    Several months ago there was a similar article on AC systems right here on FC and the following link was posted about how two "good old boys" charged an early 80's F100 p/u with R152A also known as computer duster spray. It is funny but if you watch it to the end it actually works. I don't subscribe to it but it is fun to watch. :)
    https://www.youtube.com/watch?v=dl4qOySVru0
  17. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    The proper hose for R134 is called "barrier" hose. Needed to keep the smaller molecules from saturating and leaking out which it will do in your older hoses. If you decide not to replace the hoses you may find topping off more than usual.
