A/C recharge problem/question | FerrariChat
Discussion in '348/355' started by gobble, Apr 24, 2015.
  1. gobble
    gobble Formula 3 Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    So I just took my car to the local indie shop to have refrigerant put back into the system. They put in 1.75 pounds of R134 which is the spec we found. When the AC runs the high side is seeing 400+ pounds of pressure and he was looking for a fan to run and it is not. Does anyone have any insight into how this system works and why the pressure might be so high?
  2. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    29,162
    socal
    Works like any other. How much oil was put back in if any? Got good airflow to the condenser? You guys did suck it out and leave a vacuum on before recharge right?
  3. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    If the a/c condensor fan is not working, the system will run hot and you will see high pressure on the high side.
    Check the fuse for the a/c condensor fan. The fan should come on as soon as you turn the a/c on.
    If the fan doesn't come on, it could be a blown fuse, relay/wiring problem or the fan buggered.
    Hope this helps to put you on the right track.
  4. gobble
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Thanks guys. The machine did take it down to a vacuum for around 15 minutes or so (I wasn't counting) then he added the Freon. I assume he knew to add oil but I'll ask.
    The fan wasn't working. The first thing he did is shine a flashlight down on the driver's side fan and it wasn't spinning. I believe the condenser sits behind that fan. My knowledge of AC is limited and I knew to take this to someone with the right equipment, but I should have also taken the service manual.
    I'll start checking fuses and relays and try to see why that fan isn't coming on.
  5. bmxracer50
    bmxracer50 Karting Owner Silver Subscribed
    Jan 25, 2009
    240
    Orlando
    Michael
    Condenser and fan live in front of the car. Peep down the hole in the right side of the front bumper. You'll see the condenser. When the fan is running, there is plenty of noise and suction at that inlet in the bumper. Check the front of the condenser for trash. I found some fossilized paper napkins blocking mine up. Fan won't run if the pressure switch doesn't see adequate pressure.
  6. gobble
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Is that true on a 355? This diagram appears to show it behind the left side fan.
    http://www.ricambiamerica.com/parts_catalogs.php?V=diag&I=1463
  7. NSXn355
    NSXn355 Rookie
    May 3, 2014
    48
    Northern NY
    Bill
    Evaporator is in the front and is part of the heater unit. Condenser is located at the driver's side rear as stated previously. Take a look in the climate control section of the owner's manual which has a layout of the system.
  8. bmxracer50
    Jan 25, 2009
    240
    Orlando
    Michael
    When am I going to learn check which car everybody drives before I go spouting off? it's as if we share this forum.... I stand corrected: 348 up front. 355 in da back.
  9. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    LMAO!!!! The OP wants to devalue Ferraris that are worked on by DIYers, but then asks a bunch of DIYers for advice?!? How IRONIC is that? I love it!!!
    I got some advice for the OP - Take it to a Ferrari dealer and have them give you the answer you are looking for, and pay them a 4-figure bill for it so you can "maintain" the value of your vehicle. ;)
  10. gobble
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Why would you think that? I just did my own major. I wouldn't have it any other way. I don't think that should affect the value one bit and besides I didn't do all that work so the next guy can enjoy it.
    Go back and read what I posted in that other thread.
  11. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    I just re-read the thread, and now realize that you were being sarcastic about making DIY 348/355 models salvage titles....and for that I apologize for my original comment in this thread.
  12. gobble
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Forgot I made that comment. Yes was being sarcastic.
  13. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Definitely get that fan going mate, will definitely solve the problem you are having.
    As soon as that a/c clutch 'kicks in', that a/c condensor fan should work also.
    It's not like an engine thermo fan that is controlled by engine coolant temp.
    The a/c condensor fan works the entire time the a/c is running.
    With the fan running, it keeps the a/c condensor cool which lowers a/c refrigerant temps which lowers the pressure in the system.
    The high side pressure should sit around 250-300 psi. You will see higher "high side" a/c pressures in Summer and lower "high side" a/c pressures in winter.
  14. gobble
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Thanks. I actually found the fan fuse was blown so I replaced it and the high pressure went down to 200+/-. Funny thing though is I couldn't see that the fan was spinning. It was only 40 degrees out so we thought that might be the issue. This was just testing it at home with a gauge set.
    I'm supposed to run back to the shop tomorrow that did the recharge and we'll see what pressures they see. The weather is supposed to be warmer tomorrow.
    The big question is why did the fan fuse blow.
  15. S-T48
    S-T48 Formula Junior Silver Subscribed
    Oct 30, 2008
    575
    Stevenson Ranch, CA
    Question,, wouldn't low refrigerant also cause the condenser fan not to come on?
  16. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Too easy mate, knew that would have fixed your problem.
    Why did the fuse blow? Who knows man, fuses can blow with NO explanation.
    Have seen it all over the years. I wouldn't stress too much about it.
    The a/c high pressure switch will cut the a/c out before it blows a hose/oring if the pressure climbs too high.
    If you notice the a/c is not performing well, check to see/hear that fan running. If it's not, then check that fuse again. If it's blown again then it sounds like that fan motor might on on it's way out or you have a wiring problem.
    I think you will be fine though.
    Nope, the a/c condensor fan always turns on when the a/c clutch kicks in.
    If it's low on refrigerant, the a/c clutch will not kick in so the fan will not come on.
  17. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    In the aviation business, we used to blame this on fruitrons. What is a fruitron?
    A. A gay electron that goes around blowing fuses.
  18. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Lol, dear me. :eek:
  19. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,624
    San Carlos, CA
    Mitchell Le
    These fans are well known for blowing fuses because they are old and draw more current. Once they start blowing fuses, you replace the fan as preventive maintenance.
  20. Volair
    Volair Karting
    Apr 11, 2013
    241
    Carmel, Indiana
    Bart
    On my 1990 348s, I noticed that even though the A/C clutch kicks in, and the car is blowing cold air (see the refrigerant through the sight glass, etc.) the condenser fan does NOT run all the time but cycles on/off. I always wondered whether this is due to low refrigerant.
  21. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Probably the only explanation for it. :)
    Are you sure the fan doesn't cycle on and off with the a/c? ;)
    When the a/c comes on, the fan comes on.
    When a/c cuts out because it reaches it's desired temp set by the thermostat, it will turn the fan off.
    The a/c will still be blowing cold air as the evaporator is still cold.
    When the a/c turns back on again, the fan comes on again also.
    The condensor fan cycles on and off with the a/c compressor. Well, that's how 99% of these old style a/c systems work.
    Newer cars have condensor fans that cycle at different speeds and come on and off when required. Not sure if that's how the newer Ferrari a/c systems work, but 'normal' cars are different these days.
  22. S-T48
    Oct 30, 2008
    575
    Stevenson Ranch, CA
    Mine does the exact same, hence my earlier question. I'm no expert, but I'm assuming the fan on/off is dependent on the refrigerant temp. I'm saying this because when the car is in motion, even at 30mph, there is enough airflow to do the job of the fan. This is similar to the engine cooling system. Why needlessly run the fan when your doing 70 mph on the freeway.
    Now, here is my theory. If the refrigerant is low, it does not produce enough heat to cause the fan to come on.
  23. Volair
    Volair Karting
    Apr 11, 2013
    241
    Carmel, Indiana
    Bart
    100% positive the condenser fan and compressor do not come on together and 100% sure on my car the compressor runs by itself.
  24. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Mine definitely comes on when I turn the a/c on.
    The only explanation I can think of is that your cars might still have R12 gas in the system and the wiring is different to my car.
    The condensor is very small in these cars and not very efficient to run R134.
    By law in Australia, we have to run R134A. Since 1990 this has been the rule.
    R12 systems run cooler than R134A. To run R134A the same, you have to fit a bigger condensor. Notice how big the a/c condensors are in new cars these days? Well, here in Australia anyway. We run R134A and the a/c condensor is almost as big as the radiator in every car these days.
    The 348 has a very small cavity space for the a/c condensor, so not much room to fit anything bigger unfortunately.
    I am wondering now if my fan turns on each time because it's wired to do so because I have R134A in my car. My car is a Euro spec, might have been wired differently to your US spec cars which would have came with R12 from factory. And you guys can continue to use R12 these days also which is great.
    If the fan doesn't run all the time the a/c pressures would go through the roof and shut the compressor off. Especially here in my climate and with R134A.
    And I actually I had a blown condensor fan fuse many years ago, just remembered. The a/c would cycle on and off so I knew there was a problem.
    I put some gauges on it and the high side pressure went through the roof. I walked around the front and noticed the fan wasn't working.
    Found a blown fuse. Replaced it, started it again and it was ok after that.
    If you guys are running R134A and the fan only works when it wants to, then it still sounds like the system is wired differently to a Euro spec car like mine.
    Very interesting stuff anyway.
  25. S-T48
    Oct 30, 2008
    575
    Stevenson Ranch, CA
    Yes, mine is R12. Interesting...
