A cheap ODB2 Scanner that can Adjust PIS for a 360/F430 | FerrariChat
Discussion in '360/430' started by Michael360CS, Nov 24, 2024.
  1. Michael360CS
    Michael360CS Rookie
    Jun 15, 2023
    46
    Naples, Florida
    360Luv
    Hi,
    I'm looking for an inexpensive ODB2 Scanner that can manually adjust the PIS setting on a 360. Normal Guy Supercar loves the Launch X431 Pro S3+ and uses it in his videos on 360s and F430s, but I am hoping to find something cheaper than the Launch for around $1000. I'm hoping there's something out there for around $200 that can adjust the PIS. Got any ideas of what would work?
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,878
    Central NJ
    Dominick
    What year TCU
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,878
    Central NJ
    Dominick
    The thinkdiag2 used same software ...I assume you have a CS tcu
  4. Michael360CS
    Michael360CS Rookie
    Jun 15, 2023
    46
    Naples, Florida
    360Luv
    It's a 2004 360
  5. Michael360CS
    Michael360CS Rookie
    Jun 15, 2023
    46
    Naples, Florida
    360Luv
    It's a 2004 360
  6. Michael360CS
    Michael360CS Rookie
    Jun 15, 2023
    46
    Naples, Florida
    360Luv
    The ThinkDiag2 would be great if it worked for adjusting the PIS as it is only $127 on Amazon.
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,878
    Central NJ
    Dominick
    It should work ... Just understand if it doesn't the launch won't either
    Buy it and try it ..if you need help PM your number
  8. Michael360CS
    Michael360CS Rookie
    Jun 15, 2023
    46
    Naples, Florida
    360Luv
    Thanks so much! Being able to adjust PIS myself will definitely let me fine tune the shift points better than my my repair shop bc it's a matter of taste and personal preference as to exactly where it should be.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,878
    Central NJ
    Dominick
    Just do it "hot" and don't be too aggressive with it
  10. Michael360CS
    Michael360CS Rookie
    Jun 15, 2023
    46
    Naples, Florida
    360Luv
    I know! I'll be moving the number by the smallest increments in-- .01 units -- and very slowly!
    flash32 likes this.
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,878
    Central NJ
    Dominick
    The factory suggested range is 4.5 to 5.5 for a non CS TCU
    Slightly engagement at 1025-1075 appox
  12. Michael360CS
    Michael360CS Rookie
    Jun 15, 2023
    46
    Naples, Florida
    360Luv
    Oh man, I didn't have my glasses on this morning and wrote ODB2 instead of OBD2. Can a moderator fix that?
  13. Michael360CS
    Michael360CS Rookie
    Jun 15, 2023
    46
    Naples, Florida
    360Luv
    Right now I think it the engagement is happening at too high an RPM
    flash32 likes this.
  14. Michael360CS
    Michael360CS Rookie
    Jun 15, 2023
    46
    Naples, Florida
    360Luv
    So, I got the ThinkDiag2 and it worked for a few weeks, then it stopped working for reading the PIS on a Ferrari 360. The program would simply crash over and over during the PIS read.
    I'm going to switch to a "Launch" OBD2.
    Can someone tell me what the cheapest "Launch" brand OBD2 that will work for reading and writing PIS data to the car?
  15. Mario Andretti
    Mario Andretti Formula 3
    1,774
    Boston
    What platform are you using the software on? Iphone, android? On my Samsung phone, it just got updated yesterday and it works fine for all my cars, not just Ferrari... The Ferrari software on the application also got an update and I installed it..
    flash32 likes this.
  16. Michael360CS
    Michael360CS Rookie
    Jun 15, 2023
    46
    Naples, Florida
    360Luv
    I’m using it on iPhone. So the few times it hasn’t “crashed” during reading the PIS today, it gives me a crazy reading of 162 for the PIS which is simply wrong.
    I also think the app updated before I used it and was functioning fine before the update, so maybe that’s what the issue is. I’m not sure, but I’d definitely like to get a “Launch” OBD2
  17. cpep
    cpep Formula Junior
    438
    new york
    CHARLIE
    #17 cpep, Jan 6, 2025
    I have this (but I have a 430) and may work for you also. Cheapest you will find to do what you want to do. You will need the diagzone software and I have the info for the guy that sells it. No affiliation so you deal with him through whatsapp to get the software. Works great for me and other forum members. Just realized it's out of stock. They had them a month ago but I guess they caught on. Try searching for it and eventually you will find one.
    https://www.vopmart.com/2016-original-launch-x431-easydiag-2-0-for-android-ios-2-in-1.html?srsltid=AfmBOooFs0_cmINpq_RPVMPjB3n9MgJBc_hHiujrqTvokw3LK5fZlRN4
  18. Vegas CS
    Vegas CS Formula 3
    1,180
    Vegas
    James
    I used Thinkdiag2 app on my iPhone to adjust my 430 after it received a 360Trev ECU reprogram. Worked great, no crashes.
