A choice to make: respraying my door | FerrariChat
Discussion in '360/430' started by Jacky, May 1, 2009.
  1. Jacky
    Jacky Rookie
    Mar 9, 2009
    25
    some bastard fellow use a key or some sharp object to draw a fine line of about 1.5m from my left door to the rear wheel area.
    I sent my car to my dealer who took a look at my 430. He advised using some polish to clean it. It will make the fine scratch not so noticeable. He does not recommend spraying because he is always a big fan of Factory paint.
    Should i repraying just the door and the rear so that the scratch line is completely gone? Is it really a big matter to have some part of the car with a new coat?
    sigh...
    ppl who vandalise others' properties (be it car or other stuff) should be punished.....
  2. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    if the scratch is just in the clear coat, you can usually polish it completely (or almost completely) out. Re-spraying can be tricky. What color is your car?
    Ray
  3. Jacky
    Jacky Rookie
    Mar 9, 2009
    25
    my dealer said it is scuderia red, not sure which red. Orangy in daylight.
    I will send for polishing first. will post results later.
    thanks
  4. masar
    masar Formula 3
    Aug 19, 2007
    1,367
    Czech republic
    Petr
    Rosso Scuderia, i dont think you will get rid of it without respray. If its only door = the paintshop can spray the full part = it will not be noticable at all. I would respray it, just chose good paintshop. Make pictures of the scratch and save them for future........
  5. Derek Trotter
    Derek Trotter Formula 3
    1,790
    Cambridge, UK
    #5 Derek Trotter, May 1, 2009
    I would go with Masar's reply, I'd be continuosly annoyed about the scratch not being completely polished out :).
    And yes, the b*st*rd who did it should be "bobbitted".
  6. henryr
    henryr Two Time F1 World Champ
    22,414
    Atlanta
    Juan Sánchez Villa-L
    get it resprayed by a top notch shop.
    i am less than impressed with the "factory" paint job on various models i have seen over the years....... so i don't know what your rep is in awe over.
  7. SergioAutoform
    SergioAutoform Karting
    Nov 22, 2008
    122
    Beirut/Lebanon
    Serge Sulahian
  8. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    if the scratch is just in the clear coat, you'd be surprised how much you can get out with polishing. If the scratch went down to the primer or beyond the clear coat, then all the polishing in the world won't fix it.
    Ray
  9. Oengus
    Oengus F1 World Champ
    been down that road.
    go for a re-spray, you wont be happy unless you do. :)
  10. rtajaly
    rtajaly Karting
    Mar 26, 2009
    111
    This is why I don't park my car anywhere (except for my garage).
    Your vandal will get his dues too--Karma works in mysterious ways. I could see how a car can get scratched from people posing with it for photos and having their buttons and zippers rub against it. But to scratch somebody's Ferrari is unforgivable. Most of the people on this site would have him waterboarded, or worse.
    You should try polishing the scratch first. If you can still see any of it, then apply a synthetic polymer like Liqui-Tech. After a couple of days, you can apply the polymer again. Every time you apply it, it will fill in more of the blemish, and you'll add protection to your paint in the process.
    If all of the above fails, you're still only out about $100 or so. Then you can have it resprayed. And if you do get it resprayed, like others here have mentioned, make sure to use the best body shop you can find.
    A good body repairman is an artist--an uncompromising perfectionist. You will know the difference.
  11. flipdowt
    flipdowt Karting
    Dec 13, 2008
    204
    Mahopac,New York
    John Flip
    take rays' advise first.bring your car to a detail shop and have them try to buff out the scratch.it might be a clear coat scratch and could be polished out with a medium grit compound.if its into the paint you need to respray,and yes,who ever did this intentionally should have all their fingers fall off
  12. brokenarrow
    brokenarrow F1 Rookie
    Sep 25, 2006
    3,737
    Txass
    Bill
    Generally, if you can put your fingernail in it, it needs to be sanded and painted. I would certainly let a pro try to get it out before doing any painting. But make no mistake, I'd fix the problem.
  13. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    #13 RayJohns, May 1, 2009
    I use this stuff and it's amazing for removing light to medium scratches. Like I say, if it didn't go beyond the clear coat and down into the paint, then this stuff will make even the most terrible looking scratches disappear. If the scratch looks light grey, then it's usually just the clear coat. Depends on how hard the SOB pushed when scratching.
    Anyway, you can get this stuff from Auto Zone, etc. Just rub a little on a micro fiber cloth and go to town. It helps to follow up with a polishing liquid of some sort, such as a cleaner/waxer, or maybe even a fine cutter type liquid. Then finish with some sort of wax or detailer.
    I have used this stuff with a circular buffing wheel on a DeWalt grinder - works great. Just don't do too much and burn the paint or anything. You can get the same results by hand, it just takes a little longer.
    Ray
  14. Jacky
    Jacky Rookie
    Mar 9, 2009
    25
    thanks to all for the replies. I just sent in the car to my trusted workshop. They used to fix my R8 and the paintjob is fantastic.
    Just got a SMS from the boss. Not necessary to respray. collection in 4 hours.
    will post picture shortly.
    thanks again.
  15. lung7707
    lung7707 F1 World Champ
    Jan 13, 2002
    15,967
    Honolulu, Hawaii
    Rupert 9.0
    If its orangy in daylight...chances are its Scuderia Rosso.
  16. Jacky
    Jacky Rookie
    Mar 9, 2009
    25
    hi
    here's the update:
    my workshop did an amazing job. I cannot see the scratch at all but a faint grey line under magnifying glass.
    i am a happy man once more.
  17. utah997
    utah997 Formula Junior
    Apr 24, 2007
    399
    Utah
    Doug
    Before and after pics??
  18. rizzo308
    rizzo308 F1 Rookie
    2,780
    Perth, Australia
    riggio
    I'm with you brother is sad state of affairs when you cant leave your baby parked alone
