A conspiracy. No. Appears an alternative alarm module. | Page 2 | FerrariChat
Discussion in '360/430' started by vrsurgeon, Oct 24, 2010.
  1. tazandjan
    39,417
    Curt- I will PM you the US address of another person who can clone fobs, but you will have to provide your own Euro fob. I believe they have actually found a Euro Ford fob that works over there, too.
    The alarm siren is common to all the models with the 3 fob alarm system. I had a couple of 355 owners who would not believe that and actually spent $500+ to put the old siren with the crummy battery in their cars. Here is a list of the cars the improved, $330 alarm will fit. Basically everything with Motronic 5.2 or newer through the Superamerica and 360 CS. Missing in the list is the 5.2 456, but it works on them, too.
    http://www.ricambiamerica.com/product_info.php?products_id=207296
    Taz
    Terry Phillips
  2. 2000 456M
    2000 456M F1 World Champ
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    I'm about to plunk down my money (always looking for a cheaper fix!). Does the annoying LED still stay on when the siren has been replaced? And do you hear any chirps when you lock the car?
  3. vrsurgeon
    vrsurgeon F1 World Champ
    16,631
    Charleston, SC
    Curt
    LED for me was GONE! and for the first time... one chirp with lock, two with unlock by the key fob.. (may be other way around tho)
  4. fatbillybob
    Aug 10, 2002
    29,483
    socal
    How COOl is this. Got link for the eBay vendor.
  5. tazandjan
    39,417
    Curt- This is what is great about FChat. Owners sharing information that saves us money and frustration. Great job.
    Taz
    Terry Phillips
  6. vrsurgeon
    16,631
    Charleston, SC
    Curt
    Any way I can contribute to the community. :)
    Curt
  7. DrDoug
    DrDoug Formula Junior
    Dec 4, 2009
    384
    San Jose, CA
    Doug T
    Curt, Great job and thanks for sharing your information with the community. I probably wouldn't have taken the time or had the balls to try out the alternate alarm on my car but I applaud and appreciate your efforts. I'll remember this thread when my $330 alarm unit goes out in a few years.
    Doug
  8. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
  9. Jason Crandall
    Jason Crandall F1 Veteran
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
    I don't think I want to fix mine......... I don't want the car to go "beep" every time I lock and unlock the door. I seem to accidentally set off my alarm sometimes unlike I have ever done in any other car I've owned. so....
    Maybe I won't fix it. Is there a down side other than I won't have an audible alarm on the car?
  10. Mattnshilp
    Mattnshilp Karting
    Nov 19, 2010
    91
    NJ
    Matt
    #35 Mattnshilp, Nov 29, 2010
    I have a 1999 360 and my light is solid red and I have no sound from my alarm, so I want to do this...
    I just ordered GM part #15213135
    http://www.gmpartsgiant.com/parts/gm-alarm-15213135.html
    Where do I put it and how do I connect this thing once I get it?
    -Matt
    PS - I can't believe I'm gonna put a GM part in my Ferrari. I'm gonna get smitted for this, I just know it!!!
  11. vrsurgeon
    16,631
    Charleston, SC
    Curt
    That's the deal.
    You open the front bonnet.
    You remove the panel with the tire inflator on it. You probably need to remove the panel on the drivers side of the car covering the fuses and relays as well.. just for clearance. (3mm hex wrench)
    The alarm siren is on the right hand side of the open compartment. You turn it to face it downward and unplug the connector. You then remove or loosen the 2 10mm nuts that hold it in (can be a tight fit with you hand contorted), one nut needs to be removed, tyhe other nut slides out on the groove of the siren.. you'll see what I mean. slide the siren out, replace it with the new.. plug it in and put the panels in the car back in.
    Pretty simple. Takes about 20-30 min the first time. (Alarm may chirp when you first put it in.. )
  12. DrDoug
    Dec 4, 2009
    384
    San Jose, CA
    Doug T
    One other piece of advice. The screws which are removed to take out the compartment covers in the trunk are of different lengths. On the advice a previous poster, I drew out a simple diagram on a piece of paper and put the screws out on the diagram as I removed them. It made it simple to replace each screw to the appropriate hole when reassembling. I found that I did not need to complete unscrew either of the bolts holding in the alarm module. Just loosen the nuts and slide off the alarm module (I figured this out the second time I removed the alarm siren...trust me it is a pain to replace the alarm siren if you completely unscrew the nuts). Lastly, cover the fenders and trunk of the car and don't wear any jeans or such with metal buttons or zippers exposed because you are going to leaning over the fenders and you don't want to scratch them up.
  13. bill.jones
    bill.jones Karting
    May 29, 2009
    64
    Adelaide, Australia
    Bill Jones
  14. Buxton
    Buxton Formula Junior
    Oct 31, 2010
    484
    B Buxton
    Can you relocate the batteries to make it easier to change in the future and prevent corrosion contamination when they leak?
  15. ttdang123
    ttdang123 Formula Junior
    Nov 28, 2009
    706
    North San Diego CA
    Tung
    Yes, you can.
    Many have done and posted the instructions but at the end (especially now - using this $80 alternative GM module), it is a lot more hassle than it is worth to relocate (IMO)
  16. Mattnshilp
    Mattnshilp Karting
    Nov 19, 2010
    91
    NJ
    Matt
    OMG I hate GM Parts Giant!!!
    I ordered the part and they screwed up my order 3 times. Now I get an email that it's backordered!!!
    My car is totally apart at the audio guy so it was a slam dunk easy install!
    -Matt
  17. transcup
    transcup Rookie
    Jun 8, 2010
    9
    Has anyone in the the UK or Europe tried thispart number below in a 360 and it works?
    In Europe there's an Opel/Vauxhall Omega part GM 09 231 886 BW that looks very similar but has not to my knowledge been tested
  18. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    I have ordered from them three weeks ago and still had not received it, as they told me aslo that the part is backordered !!!
    Moreover, they asked me for a VIN number without which they can not order this part, apparently... What a BS !!! Still hopeful that I will receive it one day...
  19. vrsurgeon
    16,631
    Charleston, SC
    Curt
    You know the guy that I bought mine off of on ebay.. perhaps if you guys want to contact him and see if he has any in stock? Maybe has a few that just aren't on ebay?
    ebay username: sav3b2
    store: Vettwrecks Corvette Parts
    perhaps his website? http://www.vettwrecks.com/
  20. Mattnshilp
    Mattnshilp Karting
    Nov 19, 2010
    91
    NJ
    Matt
    Thanks, that was awesome advice! I contacted him and he had one left. Got it for $55- shipped.
    Thank you!!
    -Matt
  21. vrsurgeon
    16,631
    Charleston, SC
    Curt
  22. Schumi76
    Schumi76 Formula Junior
    Feb 15, 2006
    329
    NC
    Marco
    How did you come up with the fact that a GM alarm siren might work on a Ferrari ???
    Just wondering ??? Kudos and way to go !!! ;-)
  23. vrsurgeon
    16,631
    Charleston, SC
    Curt
    Looked the same. Made by Bosch, same connector, figured it's just a siren and a noisemaker... also figured the worst case it blows a fuse..
    ...or an alarm module and I'm SOL. :)
    Saw one on ebay for 40 bucks and figured what the heck.. Cut it open and the batteries were same as old unit. Board was different though. I thought there had to be common components used across the board.
    Plugged it in and it worked. :)
  24. vrsurgeon
    16,631
    Charleston, SC
    Curt
    Let me amend that i searched on Ebay for a Bosch alarm module and the GM part came up nice and cheap. Ebay and Google. The solution to 93.7% of lifes problems.
  25. Schumi76
    Feb 15, 2006
    329
    NC
    Marco
    I hear you !!!! Thanks for letting us know about your findings.
