A couple issues with my new-to-me F355 | Page 3 | FerrariChat
Discussion in '348/355' started by Julia, Jan 7, 2025.
  1. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    493
    London
    Steve C
    Finally @Portofino you state this misinformation came from your tech and you are based (sometimes?) in Yorkshire. Perhaps you would share the name of the garage so that it can be avoided by other folk sometimes based in Yorkshire, like me!
  2. redwedge
    Sep 30, 2012
    493
    London
    Steve C
    @Julia If you have no cats, unplug the cat ECUs and take the slow down bulb out of the dash.
    Julia likes this.
  3. Julia
    Julia F1 Veteran
    9,456
    Houston
    How do you feel about .... yellow? :)
    ryalex likes this.
  4. Julia
    Julia F1 Veteran
    9,456
    Houston
    Thank you!
  5. Qavion
    Qavion F1 World Champ
    14,672
    Ian Riddell
    He does understand this, Steve, but he theorised (or his tech did) that a MAF issue (or other single sensor sensor issue) on a 5.2 might cause an overtemp (through wrong fuel mixture commands) on both banks, causing both banks to shut down (which he believes is illegal in the USA).
    Before we condemn his tech, Portofino has already stated that there was a remote possibility that he may have misunderstood what his tech was saying.
    Portofino and redwedge like this.
  6. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    970
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    See post #35 which accurately interpreted what I was try to get across .
    In simple terms
    “A very experienced tech informed me on the 5.2 cars situations can and do arise whereby they loose spark ( for what ever reason ) but continue to inject fuel , while the bank is operational .This I think can occur on one jug or more .”
    Obviously this is when there’s a malfunction of some form , be it components or wiring issues , ECU brain farts .
    Then there’s the U.K. EU modal variation with US - this can’t be ruled out leading to different experiences by the techs both sides of the pond .
    Maybe with the 5.2 s as I said earlier they are a slower out of the blocks cutting the fuel ?
    I have always suggested buying a cheap IR gun running these cars , both 2.7 / 5.2 and use it , if you have OEM , stock car and a flickering SDL .
    Tech was London based FWIW . Better anonymous.
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    The bottom line is that if you lose spark on one or more cylinders fuel will be cut off if, and only if, the cat temperature monitoring system senses an over heated condition. There are no other provisions to cut off fuel. 2.7 or 5.2, doesn't matter which.
    The other thing is that running rich (with full spark) won't typically (if ever) result in elevated exhaust temps because under a rich condition there is no O2 left in the exhaust and therefore no way the extra fuel can ignite. Furthermore, running rich generally results in lower exhaust temperatures to start with.
    Finally, @Julia, don't disconnect the cat ECU and remove the bulb from the dash. I wouldn't do that to a Toyota much less a Ferrari. Do the right thing and find the problem and fix it.
    Julia and INRange like this.
  8. redwedge
    Sep 30, 2012
    493
    London
    Steve C
    You will feel it through your arse though and should have the car recovered if it's not running on 8 cylinders, or if you're completely stuck, disconnect the injectors on the affected cylinders.
    I suggested this ONLY if there are no cats fitted.
  9. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    Yes, an option if you know which cylinders were the problem.
    I realize that was the case. I just don't believe in band aids.
  10. Julia
    Julia F1 Veteran
    9,456
    Houston
    I filled it with fresh gas the other day and took it for anither drive today. Same intermittent sdl. I'll try to work on it some next week.
  11. Julia
    Julia F1 Veteran
    9,456
    Houston
    #61 Julia, Jan 13, 2025
    I finally got time to mess with it some today. I was planning to try swapping in my old, working cat ECUs. However, when I looked at the blue car's cat ECUs, I noticed they were green on the inside, like the new ones on my yellow F355. So I figured that the ECUs had already been replaced and probably weren't the problem. So I unplugged and replugged the blue car's ECUs, the ones I could easily reach, anyway, and took it for a drive. You wouldn't think such a simple thing would fix the issue, but the light didn't come on, and I drove 25-30 miles, my longest drive yet in this car. Hopefully that's all it was and it's fixed now.
    Side note: Boy, that Fabspeed exhaust system sure is LOUD at certain revs!
    Thank you all again for your wonderful help!
    bobzdar, 308 GTB and Qavion like this.
  12. 1Superleggera
    1Superleggera Formula 3
    1,830
    North East
    Scott
    Congrats on the beautiful car!
  13. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    Yay! :)
    It's times like this when I'm glad I have an F355 Challenge. I get CHECK ENGINE lights that come on if I'm idling for more than a minute and go off when I get out on the track. They come on and go off within ten seconds of each other.
    That's normal for my car which has gutted catalytic converters and has had its rev limiter raised to 9,000 RPM. Air/fuel mixture was set rich at idle.
    I disregard those check engine lights and consider my engine banks "synchronized" when lights come on and go off within 10 seconds of each other. :D
    Barry
  14. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    #64 johnk..., Jan 13, 2025
    Some day people will listen to me. :D
    Post #6.
    Glad to hear all is good, for now. ;)
    308 GTB likes this.
  15. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
  16. Portofino
    Sep 17, 2011
    970
    Portofino
  17. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,956
    Richmond
    Pete
    Easy fix! When I did my major, I used contact cleaner on all of the connectors and then put a dab of dielectric grease in to prevent corrosion.
    308 GTB likes this.
  18. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    Yes!
