A couple of my recent projects | FerrariChat
Discussion in 'Collectables, Literature, & Models' started by lucky_13_2002, Oct 8, 2010.
  1. lucky_13_2002
    lucky_13_2002 F1 Rookie
    Nov 26, 2006
    3,026
    Colorado
    Michael
    Here are two models a just recently completed.
    Ferrari 360 Modena and Spider tuned up by Hamann. They are made to replicate Richard Hamann's personal Ferraris, which he used to prototype the parts. The seats in the Spider are my moldings and now they have backs and Daytona inserts.
    It was a shame I had to repaint the entire cars just because of the gas cap on the cars.
    MODENA
    SPIDER
  2. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,976
    MD and NE
    Robbie
    I want to see the pics, but too lazy to click 25 different links... I'm sure they look good...
    Save us the trouble and SUBSCRIBE....:D
  3. Latsyrc
    Latsyrc F1 Rookie
    Jun 23, 2008
    2,798
    Utah, USA
    Travis
    They look VERY good! Nicely done on the paint finish!
  4. lucky_13_2002
    Nov 26, 2006
    3,026
    Colorado
    Michael
    I was subscribed many times, but everytime I let it expire and them am too lazy to resubscribe. LOL
    I'll fix it.
  5. lucky_13_2002
    Nov 26, 2006
    3,026
    Colorado
    Michael
    OK, so I did subscribe again, but it is not showing it. What is wrong?
  6. toddjw73
    toddjw73 F1 Rookie
    Feb 5, 2004
    3,506
    Nor-Cal
    Todd Westbrook
    Contact Rob and see if he can find the problem.
  7. Hawaiian35
    Hawaiian35 Formula Junior
    Dec 4, 2007
    668
    Ewa Beach Hawaii
    Robsky
    For some reason I'm diggin' the Spider more than the 360 coupe. For me if that is my Modena I would color match the wing and the add on spoilers on the bottom red. That would look aggressive!
  8. Vito
    Vito Formula Junior
    487
    Dutchess County, NY
    Lucky - Would you mind sharing some information about your painting & body finishing? What brand of paint did you use? What was your process of painting, polishing & finishing? Thank you for your comments.
  9. lucky_13_2002
    Nov 26, 2006
    3,026
    Colorado
    Michael
    It is automotive duplicolor grey primer followed by Tamiya Italian Red (TS8) and then topped by Tamiya clear coat. The red was sanded with 1000 grit before the last wet coat of red. At the end the final clear coat was wet sanded with 2000 grit followed by 3M rubbing compound and then tamiya polishing compound. Everything was waxed with Meguier's Tech Wax.
    Hope this helps.
  10. Vito
    Vito Formula Junior
    487
    Dutchess County, NY
    Yes - Thanks
  11. Vito
    Vito Formula Junior
    487
    Dutchess County, NY
    By the way Lucky, how many coats of red did you lay down on the car before you wet sanded for the first time with the 1000? I've had good luck with a wet polishing cloth system that begins with 2400 & goes to 12,000 grit. It's very tedious though as there are 8 different steps from the 2400 to the 12,000. The final finish is a liquid polish.
  12. PAP 348
    Dec 10, 2005
    100,234
    Mount Isa, Australia
    Pap
    #12 PAP 348, Oct 11, 2010
  13. lucky_13_2002
    Nov 26, 2006
    3,026
    Colorado
    Michael
    thank you for posting those.
    I am in the process of making some Novitecs also.
    Here is the headache with the Capristo exhaust
    Two large diameter plastic tubes with different size are glued together
    Then they are stuffed with epoxy putty
    and industrial solder is run through them
    Thin strips stirene are glued on
    and then are sanded thiner and rounder and everything is sprayed black primer
    after the exit pipes are bent and cut, a little fitting is made from plastic and little extrusions are made that later would fit into the other part
    the cats from f430 are modified and fitted to some more solder.
    And a comparisson with the crap that comes in the model
    and a little test fit :D
  14. lucky_13_2002
    Nov 26, 2006
    3,026
    Colorado
    Michael
    Ok, I am subscribed and the pics still come just as links.....What am I doing wrong?
  15. lucky_13_2002
    Nov 26, 2006
    3,026
    Colorado
    Michael
    #15 lucky_13_2002, Oct 14, 2010
    OK guys I tried everything I can think of and it does not want to upload the pics from imageshack. Please help me.
  16. DutchDude
    DutchDude Formula Junior
    Jun 4, 2004
    267
    The Netherlands
    Ruud
    I really admire your skills and creativity Michael. Looks very good!
    Can't help you out with the uploading issues though, sorry.
  17. Simon
    Simon Moderator
    Moderator Owner
    Aug 29, 2003
    6,893
    Switzerland
    Simon
    #17 Simon, Oct 15, 2010
